      04-10-2017, 04:51 AM   #111
Tollefsen
Tollefsen's Avatar
Norway
45
Drives: BMW 1M
Hi,
Does any of you have the TUV documents for the 1m kit BMZ MN01?
I have this kit on my car that I recently purchased but the TUV documents was missing. Need this document for the Norwegian "DMV".
If some of you have this, a colored copy would have been very helpfull.
Thanks.
BMW 1M 2011. Akrapovic Evo exhaust w/wireless kit, AR design DP, , Wagner EVO I IC, Cobb chargepipe, Turbosmart Diverter valves, AFE GT Momentum intake, MMP inlets, Cobb Accesport with custom Buraq map, BMS oilcatch can, Setrab 2nd oil cooler, Rogue short shifter, Ohlins R&T suspension, Brembo 18z brakecaliper w/Ferrodo DS2500 pads, Recaro CS seats
      04-15-2017, 12:13 PM   #112
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
I just checked, no TUV documents with my US-spec kit, sorry. Have you contacted Ohlins directly? I'll bet they could email you a PDF of what you need.
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
      04-18-2017, 02:18 PM   #113
Tollefsen
Tollefsen's Avatar
Norway
45
Drives: BMW 1M
Thanks for checking.
Ohlins can provide this but I need to "apply" and pay for them to send it to me. So therfore wondering if some of you had this document. It is the same document for all 1M kits.
      05-04-2017, 10:04 AM   #114
T1M
Australia
196
Drives: AW MY12 1M
Hey guys, can anyone tell me what camber is approximately on the front with the recommended 17mm ride height drop? How much +/- adjustment is there? I'd like to achieve -2 to -2.5 level, can this be done without camber plates?
      05-04-2017, 10:41 AM   #115
Tollefsen
Tollefsen's Avatar
Norway
45
Drives: BMW 1M
Hi, just had alighment done. Mine is lowered around recommended from Ohlins and they managed to get -1.5 camber without pulling the pins. Not sure how much extra you get when pulling the pins, but i belive you need camber plates to reach more than -2.0 camber
      05-06-2017, 09:40 PM   #116
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
When I had my 1M I was able to get -2 just by lowering the front about 1" over stock.
      05-08-2017, 02:49 AM   #117
Tollefsen
Tollefsen's Avatar
Norway
45
Drives: BMW 1M
Really, did you pull the alighment pin to get -2?
      05-08-2017, 04:17 AM   #118
T1M
Australia
196
Drives: AW MY12 1M
Yeah, figured as much, thanks for the confirmation.
That's a lot of drop though! Front clearance especially with a lip would be minimal.
      05-09-2017, 01:22 PM   #119
HP Autosport
Drives: F80 M3
My car was low with a SleK lip.
      05-07-2024, 03:50 PM   #120
Tews
Drives: 2010 135i, 2019 Ram
Originally Posted by PeteA View Post
If I remove the lower sleeve on the front strut will this kit work on a 135i with a M3 rear camber link conversion?
[EDIT] - Emailed Harold. That's a negative, but, he can do custom kits for people who do the conversion as Ohlins sell struts separately
Does anyone have Harold's contact info? I have a 2010 135i and a chance to buy a full set up R and T for the years 11-13 1M. If I'm reading this thread it will not work.
However, I've read other threads stating the set up will work? Now I'm confused.
Any insight is greatly appreciated.
      05-07-2024, 03:53 PM   #121
HP Autosport
Drives: F80 M3
Originally Posted by Tews View Post
Does anyone have Harold's contact info? I have a 2010 135i and a chance to buyba full set up R and T for s 11-13 1M. If I'm reading this thread it will not work.
PM, email or call us!
      05-07-2024, 03:55 PM   #122
Tews
Where can I find your number?
1addicts
