      07-27-2012, 12:39 AM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Ohlins R&T for BMW 1M
This is the latest step in the Öhlins Racing automotive philosophy – Road&Track by Öhlins.
A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world.
The focus has been clear from the very beginning
– superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises are over!
2-year limited warranty on all of our products - worldwide.
General Features
*DFV (Dual Flow Valve)
*Rebuildable
*Corrosion salt spray tested (ISO 9227)
*2 year Limited Warranty
Front
McPherson Strut
*Single bleed adjuster
*Spring preload adjuster
(approx. 20 mm lower than standard)
*Coil Springs (rate 60N/mm)
*Height adjustable bottom mount to prevent preloading or unloading of the spring
*Dustcovers
*Use with original top mounts or camber plates
Rear
Conventional Shock Absorber
*Separate spring preload adjuster (approx. 20 mm lower than standard)
*Coil Springs (rate 110N/mm)
*Dustcovers
***Custom Swift Springs are also available with special spring adaptors***
***Compatible with NEW Vorshlag M3 camber plates***
***Kit due to ship in at the start of 2013***
Have a read at the positive reviews from 135i and 335i owners on the Ohlins R&T product:
http://www.e90post.com/forums/showth...ghlight=Ohlins
http://www.1addicts.com/forums/showt...ghlight=Ohlins
[u2b]http://www.youtube.com/watch?feature=player_detailpage&v=qkx5DD8QEwg[/u2b]
      08-22-2012, 11:17 AM   #2
HP Autosport
Drives: F80 M3
Ohlins R&T BMW 1M
Looks like the realease has been pushed to October now.
      10-09-2012, 12:29 AM   #3
sparoz
sparoz's Avatar
Australia
191
Drives: VO 1///M; Macan Turbo
Any updates?
Macan S Diesel - Carrera White
Macan Turbo - White
1///M - Valencia Orange
      10-09-2012, 05:41 AM   #4
Hobbe
Hobbe's Avatar
Sweden
11
Drives: AW E82 1M
Soon available for E46 M3 too.
Ohlin is using a club member's car.
AW E82 1M, 414 PS/636 Nm
Local tracks more fun than public roads
WWW.BMWSC.COM
      10-09-2012, 12:18 PM   #5
HP Autosport
Drives: F80 M3
Originally Posted by sparoz View Post
Any updates?
E46 M3 and E9x M3 kits will be available towards the end of the month. One of the kits will be at display at SEMA later this month as well.
      10-09-2012, 03:52 PM   #6
sparoz
sparoz's Avatar
Australia
191
Good news!
Macan Turbo - White
      10-09-2012, 05:33 PM   #7
Pete_vB
Pete_vB's Avatar
Drives: '69 GT3, GT4, 1M, 912
By the way, there are two solutions from Ohlins currently available for the 1M. Both are rather track focused. One is the solution mentioned in this thread developed by Ohlins USA, released a bit over a month ago:
http://www.1addicts.com/forums/showthread.php?t=625284
The other is likely an even higher end solution targeted at competition cars, available from Performance Shock Inc.
Both are probably more expensive than the upcoming R&T solution, but both are also likely higher performance for track work and competition applications.
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
      10-12-2012, 05:22 PM   #8
HP Autosport
Drives: F80 M3
Although both of those Ohlins based systems are excellent for track use on track or competition 1M/M3's, they are not recommended for street duty at all and will likely not carry any warranty.
For street duty and track days, Road & Track will be perfect and nearly half of the price.
      11-02-2012, 01:15 AM   #9
HP Autosport
Drives: F80 M3
Updated photos of the Ohlins E82 1M kit.
More technical info here:
http://www.m3post.com/forums/showthread.php?t=765106
      11-02-2012, 06:13 AM   #10
sparoz
sparoz's Avatar
Australia
191
Thanks harold!
Macan Turbo - White
      11-12-2012, 09:33 PM   #11
HP Autosport
Drives: F80 M3
Thanks harold!
You are welcome.
As soon as Ohlins USA gives us more information I will be sure to post here.
      12-13-2012, 07:46 PM   #12
HP Autosport
Drives: F80 M3
Ohlins R&T BMW 1M
Pricing and release date from Ohlins USA. For more info:
http://www.m3post.com/forums/showthr...5#post13153465
      12-25-2012, 07:45 PM   #13
schnite
Drives: E82 1M
why ohlins R&T cann,t adjuste soft or hard
      12-26-2012, 11:21 AM   #14
HP Autosport
Drives: F80 M3
Yes, these are damping adjustable.
      12-27-2012, 03:07 AM   #15
schnite
Drives: E82 1M
thank you for your recommendation.ohlins it,s perfect road and track.
      01-04-2013, 09:08 PM   #16
HP Autosport
Drives: F80 M3
You are welcome. You can't go wrong with this top notch quality coilover kit.
      01-15-2013, 05:19 PM   #17
HP Autosport
Drives: F80 M3
Firsthand look at the Ohlins R&T up and close!
      01-15-2013, 10:09 PM   #18
schnite
Drives: E82 1M
for 1m? made in japan?or made in sweden
      01-16-2013, 06:20 AM   #19
HP Autosport
Drives: F80 M3
Made in Sweden for the 1M or M3.
      01-16-2013, 08:34 AM   #20
Yellowceta
Yellowceta's Avatar
Drives: 2011 VO 1M
2011 BMW  [0.00]
Are they shipping yet, Harold?
1996 Trans Am WS6 (RiP)
2002 Trans Am Collector Edition WS6 - Not Stock @ 425 rwhp
2006 VW GTi - APR Goodies - Sold
2011 1M - VO Florida pick up 11/4/11 #554 of 740 - Sold
2017 ATS-V Stock
      01-17-2013, 06:52 PM   #21
HP Autosport
Drives: F80 M3
Here are some photos with the Swift spring upgrade.
Rear is easily done and we used the quick change rear spring kit so the main spring can be changed easily.
Front is a bit more involved when NOT using camber plates. An adaptor had to be custom made for the OE strut top mount to accept a constant ID coilover type springs, but as you can see the result is awesome and look very OE like. A shorter spring can be used to allow the highest lower spring perch position for wider wheel/tire clearance.
      02-03-2013, 11:11 AM   #22
Black Gold
Drives: M3
What is the minimum drop on the 1m?
It would be nice to be able to have a nice road / track handling upgrade without having to drop the car since I like the stock ride height.
Should also ride best at the max height.
Thanks, and can you go into more detail on the installation issues on the front? Does this apply with the out of the box kit with Ohlins supplied sprigs?
Thank you!
1addicts
