BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
EXXEL Distributions
      06-04-2014, 03:14 PM   #1
Interlagos-Bimmer
Sweden
Drives: M3 E92 Interlagos MT
CEL Code P136P
Hi!
Got a CEL and limp mode the other day and pulled some codes today.
I have code P1605, it is a general code that basically tells that there is several faults present and that power is restricted = limp mode
I also have a code P136F which I have no idea what it means, not a single relevant hit on google...
I´m turning the car in to my BMW dealer in the upcoming days. Any of you have an idea what the code means?
Car has rough idle and feels a bit hesitant when getting on the throttle.
My car is stock other than an akra slip on.
If any of you have a clue, please chime in!
      06-05-2014, 06:38 AM   #2
dparm
Stop the hate, get a V8
dparm's Avatar
Drives: C7 Corvette GS, AMG C63 S
http://www.m3post.com/forums/showthread.php?t=928325
Past: 2011.5 M3 sedan ZCP
      06-05-2014, 07:16 AM   #3
Interlagos-Bimmer
Sweden
Originally Posted by dparm View Post
Hi!
Already checked that awesome thread, no mention om my code P136f
Thats why I started a new thread.
Thanks for your reply
      06-05-2014, 11:27 AM   #4
dparm
dparm's Avatar
It seems to be a catch-all code that's a symptom of another problem. I would take it to the dealer as it is labeled as "critical".
      06-05-2014, 01:17 PM   #5
Interlagos-Bimmer
Sweden
Ok, thanks for your time and help!
Going to the dealer next week. Kind of worried there is a major problem...
Where did you find out what the code meant? In my non-expert experience the car should display several fault codes making it easier to troubleshoot.
Again, thanks for your help!
      06-05-2014, 02:14 PM   #6
dparm
dparm's Avatar
It's merely my interpretation of the wording in that thread I linked to. I agree that it is not very descriptive and you'll need a BMW-specific tool to read the exact error.
      06-11-2014, 09:43 AM   #7
Interlagos-Bimmer
Sweden
Got a call from BMW dealer today.
Fault codes due to a faulty ignition coil.
Not sure whether code p136f is related to ignition coil.. let med get back about that.
      06-11-2014, 10:04 AM   #8
kenwelch
Drives: 2008 E92 M3 M-DCT & 2017 440GC
Code p136f
BMW Fault Code Description VS-Text
M ignition coil, cyl. 3
BMW Fault Code (dez)
11113
BMW Fault Code (hex)
0x2B69
Calculated value Y/N
No Info.
Component
No Info.
Customer perception comments
CC message Engine speed limited Reduced power MIL after engine runs 2x
Fault debouncing
No Info.
MIL illumination/CC message/emergency program
MIL
Monitoring criteria
Idle: Combustion miss SA: Offset outside tolerance range
Possible Fault Causes
Internal malfunction in M coil
Remarks
Idle is stable: No KH intervention, all cylinders switched on, no miss detected, camshafts synchronous, K_VR_DIAG_LAM_MAX > lam_ist_mw_bx > K_VR_DIAG_LAM_MIN and deviation from tz_grund_bx < K_VR_DIAG_DTZ_MAX, tmot > K_VR_DIAG_TMOT_MIN and toel > K_VR_D
Repair procedures (plant/service)
Interchange ignition coils:
1.If the malfunction migrates with the coil, then the coil is defective
2.If the malfunction remains at the same cylinder, check the ignition wire and power supply. If no fault is present in the ignition wire or the power supply: Replace DME
Signal information
No Info.
Subcomponent
No Info.
System test
No Info.
Temperature conditions
No Info.
Terminal conditions
Terminal 15
Time conditions
No Info.
Voltage conditions
none
      06-16-2014, 12:25 PM   #9
Interlagos-Bimmer
Sweden
Originally Posted by kenwelch View Post
Code p136f
11113
0x2B69
No Info.
Component
No Info.
Fault debouncing
No Info.
MIL
Monitoring criteria
Remarks
Signal information
No Info.
Subcomponent
No Info.
System test
No Info.
No Info.
Terminal conditions
Terminal 15
Time conditions
No Info.
Voltage conditions
none
Exactly what was wrong. New ignition coil in my car.
Thanks for all the help!
m3post
