ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      12-04-2007, 09:04 AM   #1
F87LUV
F87LUV's Avatar
Drives: '16 M2, '23 GT4
2023 Porsche GT4  [5.00]
2016 BMW M2  [8.66]
Stock sport suspension vs aftermarket
The OEM parts are on backorder which will hold up repairs from my accident so the body shop asked if maybe Id like to upgrade now and itll be faster so now im looking at tein springs/koni... is it worth it? I may consider eibach or h&r springs but im not looking to really drop my car... more concerned about handling.
IG: Trackinheels
      12-04-2007, 09:15 AM   #2
GP20
Drives: Z4M, F80 M3, 991.2 GTS
What parts of the suspensions are you talking about that are backordered? What parts is the bodyshop replacing? Both front and rear axels?
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      12-04-2007, 09:18 AM   #3
F87LUV
F87LUV's Avatar
2016 BMW M2  [8.66]
rear shock/spring... oem is already over $200 which would cover the springs for the whole car...
IG: Trackinheels
      12-04-2007, 09:25 AM   #4
GP20
Eibach + Koni adjustable struts/shocks are a very good set-up. But you'll have to replace springs and shocks at all 4 corners at the same time and not just the rears. If you're planning to keep the car for more than 2 years, get Rogue Engineering rear-shock-mounts at the same time (it'll save you a lot of money and hassles in the long run).
Shox.com is just about the cheapest place you can find for the Eibach springs and Koni struts/shocks package. (no I'm not affiliated with shox.com)
2016 BMW M3
2008 BMW Z4M coupe
      12-04-2007, 09:33 AM   #5
F87LUV
F87LUV's Avatar
2016 BMW M2  [8.66]
"Rogue Engineering rear-shock-mounts at the same time "
why? what do they do? sorry if i sound stupid, with all the modding ive done, would you believe ive never touched stock suspension on any car!
IG: Trackinheels
      12-04-2007, 09:41 AM   #6
GP20
It's the metal plate that goes over the top of the shock shaft and connects the shock body to the car's subframe.
Part #8:
http://www.realoem.com/bmw/showparts...43&hg=33&fg=45
The stock rear-shock-mounts are known to crack easily with aftermarket suspensions. Heck, they're known to crack easily with STOCK suspensions. The stock ones are just really thin pieces of metals and the aftermarket ones are thicker and stronger. So essentially, if you upgrade the rear-shock-mounts at the same time, you pretty much will never have to worry about them cracking/failing for many many years.
2016 BMW M3
2008 BMW Z4M coupe
      12-04-2007, 09:54 AM   #7
F87LUV
F87LUV's Avatar
2016 BMW M2  [8.66]
Ooooooooooh........... everything i see is for the e85... is the e86 suspension diff or is it just the engine?
IG: Trackinheels
      12-04-2007, 02:16 PM   #8
sixspeed
Z4M CSL
sixspeed's Avatar
Drives: Alpine White Z4M Coupe
GP20, is that an issue on the M cars as well?
      12-04-2007, 02:29 PM   #9
GP20
I would imagine so. It's a well known issue for the E46 M3 and the stock RSM I took off from my Z4M looks just as skinny.
2016 BMW M3
2008 BMW Z4M coupe
      12-04-2007, 03:44 PM   #10
mister_roger
mister_roger's Avatar
13
Drives: 2003 Maldives Blue 2.5i
I can totally vouch for the eibach, koni suspension setup. To me, the height is just about perfect. Not Tooo low, but just enough to differentiate it from a sport suspension setup. Ride comfort is firmer, but under control. It's nice that the shocks are adjustable so that you can fine-tune ride for comfort/sport.
I didn't replace the Rear Shock Mounts when i swapped suspenions. Now that I think about it, I probably should have had those replaced/upgraded at the same time. It's been a little over a year, and I'm starting to hear some small squeaking sounds from the rear when I go over big bumps. Not sure where exactly it's coming from, but it sort of sounds like the rear shock mount area. Oh well.
2003 Maldives Blue 2.5i -- 18" M6 wheels, 12mm rear spacer, ///MZ4 front bumper conversion, Eibach lowering springs, Koni shocks, Hotchkis F/R anti-roll bars, Helene Performance air filter.
      12-04-2007, 04:34 PM   #11
GP20
Hey Roger,
We should get together sometimes and look at the noises on your car. I fixed my RSM noise by the way. I re-installed the top and bottom RSM metal washers and made sure the top nut was tightened properly and the noises went away. Also, did you remember if Truline re-used the RSM paper gaskets? Apparently, they actually serve a purpose in eliminating little noises.
Well if you pick up a set of RSM's I can just help you install them.
2016 BMW M3
2008 BMW Z4M coupe
      12-04-2007, 06:20 PM   #12
mister_roger
13
That would be cool Eric. I'll have to take you up on your offer when the weather gets a little better
No immediate hurry, as it's not really a bother right now, but eventually I'll plan on changing the RSMs out.
      12-26-2007, 01:57 PM   #13
sketchmunky
sketchmunky's Avatar
Drives: 2008 Z4 3.0si Coupe
I'm also thinking about getting the Koni/Eibach setup for my car. Do any of you guys know if the 03 to 07 Z4 suspension will fit on my 08 Z4 3.0si coupe?
      12-26-2007, 04:34 PM   #14
BimmerZealot
Drives: 2019 BMW X3 xDrive30i
it should fit as long as you dont get the Z4M suspension components. I dont think the sport suspension vs non-sport is different in terms of aftermarket pieces.
      12-29-2007, 11:48 AM   #15
Reach
gone baby gone
382
Drives: 2016 F80
Are there really any differences with the suspension components of the M vs non-M cars? I'd imagine the components are the same, but with stiffer spring rates and shock dampening.
      12-30-2007, 12:42 AM   #16
jmillet
jmillet's Avatar
64
Drives: 2023 Hyundai IONIQ 6 SEL AWD
Different
Check out the part numbers on realoem.com/bmw and you'll find the Z4 ///M suspension components are not the same as the Z4 components and are not inter-changeable.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      12-30-2007, 10:19 AM   #17
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
The M cars are also heavier thanks to the iron block and have a different weight distribution.
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
      01-02-2008, 10:35 AM   #18
vachss
Drives: Z4 Coupe
I'll take your old suspension parts
I have a Z4 coupe without the Sport Package. If anyone with the Sport pack is planning to upgrade their suspensions to an aftermarket system I'd be interested in your old BMW Sport pack parts (particularly the larger diameter sway bars) to upgrade mine. Just let me know. Thanks
      01-04-2008, 10:29 PM   #19
Reach
gone baby gone
382
Drives: 2016 F80
Different part numbers are natural as they would have different spring rates / shock combos for each chassis version.
My question is, do they use the same suspension type and mounting points? Does anyone have diagrams for the stock suspention for both the M and Roady?
Thanks.
      01-07-2008, 01:52 PM   #20
pbdm4k
pbdm4k's Avatar
Drives: 2010 335d
Thanks.
All the suspension mounts up the same way and shocks/springs from sport and non sport are physically identical. Difference in part numbers would attribute to their difference in valving and spring rates.
If you go aftermarket none of this matters as its all the same.
      01-07-2008, 02:41 PM   #21
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
You mean a perfect near 50/50 distribution?
M=Weight distribution, front/rear - Manual Transmission 50.2/49.8 %
3.0=Weight distribution, front/rear - Manual Transmission 49.7/50.3 %
      01-07-2008, 02:53 PM   #22
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Exactly...the weight distribution moves forward...
Best Website EVER!
zpost
