ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Wheels and Tires
  TireRack
      12-01-2007, 09:23 PM   #1
kbh
kbh's Avatar
Philippines
31
Drives: Porsche Cayman S/BMW E92 M3
19's wheel offset-please help
Hi there,
I'm Keith from the Philippines. I just got a 2nd hand 2004 2.5l Z4. I need help for the best wheel offset for our cars. I'm planning to buy Hamman anniversary rims or DPE sl5 wheels. But i don't know what's the offset for this. I'm planning to go with 19x9 front and 19x10 rear will this fit? I really want a wide lip for the rears to give an aggresive look
Also from what i researched from bmw z4 forums is that the H&R spirngs will give a really low drop. I'm planning to buy Eibach springs with Koni shokcs or H&R coilovers. Any of you guys have this setup? Can you guys post some pics of the drop so i can have an idea what will i get
Many thanks to you guys.
here is my newly acquired weekend car
my race car (nissan silvia) with bmw m5
my show car lexus is250TT (supra engine) with jerri lee playboy playmate cover
      12-02-2007, 02:40 PM   #2
OH FO SHO
OH FO SHO's Avatar
15
Drives: z4
ballin in the P.I. been seeing a lot more z4's up there.
Jeri Lee
as far as offsets im guessing between +38 - +42 should be ok
'03 3.0i z4: tiag ext., red int., SMG, sport, premium
HAMANN exhaust l HAMANN front lip l 19" Miro type 366 (HAMANN edition race replicas) l RPI air scoop l KW v2 coilovers
-*MY PICTURE THREAD*-
      12-02-2007, 06:15 PM   #3
ianbiz
Back in a BMW
ianbiz's Avatar
Drives: 2015 335i Msport
I spy intercooler.
Those are some sick cars
Ian
      12-03-2007, 01:35 AM   #4
kbh
kbh's Avatar
Philippines
31
OH FO SHO,
the offset you gave me is for the front and rear already? do you have exact offset numbers that is tried and tested for a 19x9front and 19x10 rear setup?
ianbiz,
Thanks for the compliment, the silvia has a bigger turbo and bigger intercooler setup you can't see it in the picture.
      12-03-2007, 03:55 AM   #5
GP20
Drives: Z4M, F80 M3, 991.2 GTS
Those offsets won't work with a regular Z4, especially lowered on H&R springs.
A front 8.5" wid rim with an offset of ET35 is basically at the cut-off line before the tires would rub the inner front bumper plastic liners. With an 9" wide rims, you'd need something with an offset of ET 42, and even then there's a great chance that the inner part of the wheels would rub against the front struts housings.
I had 19x9.5 ET42 (rear rims) SSR GT3's on my '04 Z4 3.0i lowered on H&R springs and it seemed to be another 7~8 mm before the tire would rub the edge of the rear fenders. With an 19x10 rim, you'd need something closer to ET50 than ET42, in which case, again, you risk having the inner wheels rub again the shocks.
My recommendations would be to go with 8.5" front rims and 9.5" rear rims at the widest.
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      12-03-2007, 08:45 AM   #6
kbh
kbh's Avatar
Philippines
31
GP20,
Thank you so much for the reply. I know 19x8.5 and 19x9.5 will surely fit the Z4 roadster because my friend has AC wheels on his car with that size. I'm jjust hoping that 19x9 and 19x10 will fit on the z4 because i want a wider lip and low disk look. BUt then again i don't want to have rubbing issues. So i guess i would end up buying the 19x8.5 and 19x9.5 as you said.
So the perfect offset (meaning no need for spacers) is 19x8.5 et35 and 19x9.5 et 42? Just making sure before i buy the wheels. I want to have almost close to the fender as possible to give me a good stance. Thank you in advance
here's my friends z4 here in the phil - all out AC setup
http://www.ogieabastillas.smugmug.co...07011#56467277
      03-12-2009, 08:50 PM   #7
Twisted Six
CarbonFiber Engineer @ ZeroMassMotorsports
Twisted Six's Avatar
Drives: Z4si-coupe
Originally Posted by kbh View Post
GP20,
COuld you inquire as to your friends offsets with his car for me ?? Beautiful ACS-4 !
      08-29-2009, 01:40 AM   #8
ngheolienmi3n
Drives: 2004 z4 SMG
Sorry to bring up an old thread but I also have H&R springs on my Z4 with 19x8.5 et 35 in the fronts and I am rubbing whenever i hit a dip or bump (even small ones) and also on hard cornering. I have 235/35/19 tires. What should I do to fix this? Remove the fender liners? Change camber settings? There is not even one finger gap between the tire and the fender. I'm just afraid that if I hit a big bump the tires would hit the fenders and mess the car up.
      08-29-2009, 05:17 AM   #9
GP20
If I were you I'd dump those H&R springs and swap for some Eibach's or go with height adjustable coilovers. The H&R springs really slam the ride for the non-M Z4 and cause all sorts of issues. You can also try different wheels and go with less aggressive front offsets.
2016 BMW M3
2008 BMW Z4M coupe
      08-29-2009, 12:12 PM   #10
ngheolienmi3n
Drives: 2004 z4 SMG
would changing the tire size to 225/35/19 help with the issue? I just love the low look of the H&R and I do not want to change them out.
      04-14-2018, 07:19 PM   #11
iShimy
iShimy's Avatar
New Zealand
Drives: Z4 E86 3.0si
Hi I have a set of Vossen CVT Gloss. The rears are 19x10 ET50. It is rubbing the black inner guard. If I remove are their any issues?
      04-14-2018, 11:25 PM   #12
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Why not do the simpler solution and just add a 5mm spacer to clear the rub?
      04-17-2018, 01:21 AM   #13
StigJ
StigJ's Avatar
Norway
333
Drives: '06 Z4 Coupe & '14 F30
10mm spacers would be perfect. My 10x19 are ET41 and fits perfectly.
zpost
