05-03-2014, 03:51 PM | #1 |
Rep 3,071
Pre Warranty Expiration Oil Test/Analysis
So my warranty ends in two months and I thought getting an oil analysis might be worth while. Do I simply pay a shop to change the oil and save me some? How much do I need and what shops do you guys recommend. What does this cost? Would you bother if you had a bmw extended warranty?
Previous BMW: 16 M4, 13 M6; 14 M235i, 12 BMW M3; 11 BMW M3; 08 BMW M3; 08 BMW Z4M; 04 X3; 02 M3 Convertible; 02 M3; 00 M Roadster; 94 325 convertible; 92 325i Convertible; and 85 635csi
My Car Photo Blog: http://carfisheye.blogspot.com/ |
05-03-2014, 04:20 PM | #2 |
Perception is King
131
Rep 1,703
Go unto Blackstone's website and they send you a Free kit and when you get your oil changed have um put some oil in the container from Blackstone and you send it to them with $25 and they'll send you your oil analysis.
Perception and Reality are Two totally different Things.
05-04-2014, 07:05 AM | #3 |
Rep 3,071
ibmike, thanks, ordered test kit. i see they have all kinds of "extra tests" Does anyone recommend extra test for the rod bearing issue?
05-04-2014, 08:18 AM | #4 | |
Rep 4,488
Also ask whoever does the drain to drive it around first to heat up the oil and then capture oil from the middle of the drain if possible. As the card that comes with the kit will say, that's preferable (but not required, and shouldn't influence the readings relevant to rod bearing wear). After that, I found USPS took forever to send it to Blackstone, but once it got there the test was conducted quickly.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
05-04-2014, 08:39 AM | #5 |
Rep 3,071
The next question is if the test reveals issues, how will bmw respond. Has anyone tried to make a warranty claim based on the test?
05-04-2014, 09:51 AM | #6 |
Rep 6,863
The test won't be able to tell you definitively if there is an issue or not. And no, BMW will not do anything about it as there won't be anything to do. What warranty claim could you make? If your car is in fine working order what do you expect bmw to do?
05-04-2014, 11:03 AM | #7 | |
Rep 4,488
But an oil analysis definitely wouldn't be enough to get bearings changed under warranty.
05-04-2014, 11:09 AM | #8 |
Rep 9,032
Someone here paid for a bearing inspection somewhere, then showed the bad bearings to BMW and eventually got them covedered.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
05-04-2014, 03:09 PM | #9 |
Rep 3,071
My view is get analysis, if they suspect something bad, notify BMW and have further testing done. I am sure an oil drain then scope could clarify. Also, if you notify them in warranty and they deny, then post warranty they fail (within a reasonable time and without any post claim evidence of abuse) makes for a good legal argument to get coverage.
05-05-2014, 12:08 AM | #10 | |
Stop the hate, get a V8
3850
Rep 8,625
You should be getting TBN and TAN on every analysis regardless. Without them, you have no clue if the change interval is correct for your particular motor and driving habits. As others have said, an oil analysis can produce false positives. It can also make things look peachy when there are major problems. Even Blackstone will tell you that it is not a highly-accurate indicator of engine health.
Past: 2011.5 M3 sedan ZCP |
05-06-2014, 05:08 PM | #11 |
Rep 468
Agree with dparm. A single oil analysis has limited value unless there is Gross damage / degradation. The real value is a trend over time of multiple tests to see how fast things may or may not be wearing.
