05-01-2014, 10:43 AM | #3 |
Rep 979
EDIT: I actually use MTL, not MT-90. I misread the OP post, sorry.
Shifts are crisper and I don't have the annoying first to second gear crunch anymore. Cold shifts are also improved. Last edited by italyix; 05-02-2014 at 02:54 PM.. |
05-01-2014, 02:20 PM | #4 |
Rep 102
Just switched mine out with MTL, feels just fine thus far. About the same as stock when cold, and a bit better when warm
05-02-2014, 09:05 AM | #5 |
Stop the hate, get a V8
3850
Rep 8,625
Red Line's application guide is saying you need to use their D4 ATF.
MT-90 is about twice as thick as D4. I wouldn't use it -- would probably generate a lot of extra heat in the trans and have some really poor shift quality. The factory fill is MTF-LT-2, which is basically a 75w80 GL-4. Red Line does make a comparable product called MTL.
Past: 2011.5 M3 sedan ZCP |
05-02-2014, 11:50 AM | #7 |
Bad Lieutenant
232
Rep 3,517
Redline's MTL rocks!
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
05-02-2014, 12:37 PM | #9 |
Rep 12,310
Good feedback guys, thanks. I went with OEM during last swap and was pretty happy with results. I never did have issues with my gearbox, and it seems like fresh fluid made it just ever so slightly smoother. Might try Redline next time.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
05-02-2014, 02:34 PM | #10 |
3850
Rep 8,625
The reason you can get away with using D4 ATF is because the Red Line basestocks are very stout and sort of behave like a thicker fluid than they really are. I would definitely try the D4 if you don't want to use the OEM stuff.
05-02-2014, 05:13 PM | #11 |
Rep 1,260
Great feedbacks! Thanks....oh, and sorry i didn't make my original post clear...but I was referring to our 6 speed manual transmissions. I believe the D4 is for the autos.
I'm getting a bit of "notchiness" going into 3rd...even when warmed up. I inquired about the MT-90 because it is thicker and that it may help synchronize better. Feedback from people who has used the MT-90.
05-02-2014, 05:24 PM | #12 | |
Rep 5,506
Auto Detailing Enthusiast!
05-02-2014, 05:29 PM | #13 |
Rep 368
I recently changed my oil to Royal Purple. After about 500 miles, so far so good. It definitely smoothed out the notchiness in 2nd and 3rd gears, especially during the warm up period.
I may try the Redline D4 ATF next to see how it compares.
05-02-2014, 09:58 PM | #15 |
Rep 545
I put together a few resources for use by the students in my power train class. Thought these synchronizer and fluid links might be helpful to those here.
Using the Proper transmission Fluid Most modern manual and dual clutch (DCT) transmissions use friction lining on the inside surface of the synchronizer rings (blocker ring). The friction material is like automatic transmission clutch material. The synchronizer design requires a different specification fluid than older transmissions using bronze only synchronizers. Here are several resources that will help you with how the synchronizer system works and why lubricant selection is important. Flash animation of shift synchronizer operation by Tom Birch http://tombirch.com/3/flash/Synchronizer_Operation.swf Carbon friction linings in Automobiles http://www.sulzer.com/en/-/media/Doc..._koester_e.pdf Synchronizer friction materials (see pages 32-33) http://www.hoerbiger.com/upload/file...chronizers.pdf Potential of Sintered Friction Linings in Synchronizers http://www.hoerbiger.com/upload/file...onizers_en.pdf Friction Lining Solutions for Synchronizers http://www.hoerbiger.com/upload/file...onizers_en.pdf Redline Synthetic Manual Transmission Fluids http://www.redlineoil.com/content/fi...uct%20Data.pdf Redline Manual Transmission / Manual Transaxle Lubricant TECHNICAL INFORMATION http://www.redlineoil.com/content/fi...ech%20Info.pdf Redline Gear Oil Tech http://www.redlineoil.com/content/fi...ech%20Info.pdf |
