04-26-2014, 08:11 PM | #1 |
Rep 124
Purchasing an M3, but no bass!
Hey guys, I went to go look at an M3 today and purchased it. It's a 2011 and Mineral White. I immediately fell in love with the car. One of the things I noticed though was the upgraded stereo system. It has the upgraded stereo system, but one of the things I noticed was no bass at all in the car. I went through the settings and reset the audio levels and even tried turning it up, but still nothing. I was wondering if this is a major issue, or something minor. Thanks guys!
04-26-2014, 08:19 PM | #2 |
postimus minimus
31
Rep 94
Drives: M3 addiction
My 2010 has the standard system and has fairly impressive bass with the stock under seat woofers, I would think the upgraded system would out do them or at least match it in the bass department. Was the upgrade a retro fit? Maybe the previous owner has a system and disconnected the stock woofers.
04-26-2014, 08:27 PM | #4 | |
Rep 124
04-26-2014, 08:42 PM | #5 |
Rep 6,696
Drives: F30 340i
second time this week i'm saying this. the e9x had a good run
04-26-2014, 09:42 PM | #9 |
Rep 124
04-26-2014, 10:52 PM | #10 |
Rep 504
Probably a problem with your amp. Mine cut out a couple times on hot days, but eventually came back on. Wouldn't say its a common problem, but ive heard this before.
2008 M3 BRP 2:08.4 Big Willow 1:37.8 SOW CW 1:29.0 Chuckwalla CW 2:07.4 LS 1:46.7 ACS 2:00.7 2010 GT-R BRP 1:55.3 Big Willow 1:32.0 SOW CCW 1:23.4 Chuckwalla CCW 2:02.5 Chuckwalla CW 2:00.1 LS 1:41.2 ACS 1:50.6 |
04-26-2014, 10:57 PM | #11 |
Rep 124
It was about 60 degrees when I went to go look at the car, and the car hadn't been started in 2 days. I think it might be an amp problem. That was my first thought.
04-27-2014, 07:55 AM | #14 |
Rep 313
Perhaps the previous owner had a separate sub/amp to give his hip hop more low end. If they did, they could have cut the factory harness to accomplish this. I would check to see if the woofer under the front seats are actually still hooked up and playing. If you turn your stereo up pretty good, you should be able to hear or feel with your hand to see if the driver is playing. Good luck.
04-27-2014, 09:24 AM | #15 |
Rep 3,482
If it's not there "at all" then you could have a loose connection. Did the level of bass change when you adjusted it in the iDrive menu? If the low range isn't distorted in any way, shape or form ...you're just being nit picky.
2011 e90 M3 Space Grey DCT ZCP- eAs, BMW Performance, Agency Power, Macht Schnell, iND, Milltek, Volk, Challenge, Stoptech, Ohlins
BMWCCA:518970 |
04-27-2014, 11:25 AM | #16 |
Rep 2,940
I have at times felt like "where's the bass?" with my enhanced premium sound. Once I even put my hand down over the sub to make sure I could feel some vibration coming out of it.
What I have found is that the system is definitely capable of bass, but if it isn't in the recording, you can't easily add more bass, especially deeper bass. After listening to some tracks with heavier bass, it was definitely there. Of course, it will never sound like a 12" aftermarket unit in a sealed trunk box.
Audi S6 * Audi S3 * Porsche Cayman GTS
--Former BMW M3 owner |
04-27-2014, 12:05 PM | #17 |
Rep 124
It didn't change at all. I even put on se heavy bass songs and went to the menu to change the bass level and I noticed no difference at all between the lowest and highest setting.
04-27-2014, 12:07 PM | #18 | |
Rep 124
04-27-2014, 12:08 PM | #19 | |
Command Sergeant Major of the Army
142
Rep 639
http://www.m3post.com/forums/showthread.php?t=428114 Your mileage may vary.
2018 F82 M4 ZCP
2015 F13 M6 ZCP (gone) 2013 F10 M5 (gone) 2008 E90 M3 (gone) |
04-27-2014, 12:34 PM | #21 |
142
Rep 639
Respectively disagree...with the proper settings on the EPA of course.
2018 F82 M4 ZCP
04-27-2014, 01:30 PM | #22 | |
First Class Privates
29
Rep 437
That would be my guess. Aftermarket subs removed and sold before the car was sold.
| Matte Black Grilles and Side Vents | Painted Reflectors | Remus Race Exhaust CF Tips | CF Emblems | 19" Volk TE37 | KW | More to come...
