04-12-2014, 09:23 PM | #1 | ||
Rep 10,407
0W-40 vs 10W-60
No idea why the other thread got closed, perhaps useless insults while I was away... Anyway, just can't resist the immense falsities so here goes an attempt at a civil continuation.
regular_guy said Quote:
I never boast about my degrees. However, both that experience along with my experience as a professional mechanical engineer obviously inform my disposition, skepticism and appreciation for the things I do not know. I too have readily admitted my lack of formal experience in automotive engineering. My approach rather than being an expert on everything is acknowledging the good and relevant work done my other engineers. Things you and other clearly don't seem to want to acknowledge or even admit exist. Quote:
And just to remind you, your points to SFP were discussed and addressed one after the other, clearly demonstrating how various lubrication system components are optimized and how the viscosity of the oil is a relevant parameter that clearly affects the design. It's really too bad if you don't understand "optimized WITH" vs. "optimized FOR". It's not that subtle. As I stated before the nominal oil viscosity, at operating temperature goes directly into the calculations, equations, simulations, optimizations, testing, etc. for all of these lubrication components and systems. The resulting design decisions (i.e. actual component shapes/sizes) therefore depend on the particular value of the viscosity. Change the viscosity and in most cases slightly different parts would result. I really don't see how much more clear that can be.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | Last edited by swamp2; 04-12-2014 at 09:43 PM.. |
04-12-2014, 09:36 PM | #2 | ||||||
Rep 10,407
Well then there is BMRLVR who is so adept at misrepresenting what I have said....
BMRLVR said, Quote:
Again....There are quite small differences between these oil choices. The lower viscosity oil should offer some simplistically justified (perhaps over simplified...) benefits if there are cold start or running starvation issues. Although it probably will admit some minor disadvantages it seems like cheap insurance just in case these issue are more widespread than the DATA indicate. That being said, I also doubt that something as minor as this change will offer complete nor guaranteed protection against all instances of bearing wear. PERIOD, PERIOD, PERIOD. Not some part of that, not some twisted version of it. That and that alone is MY point of view. Quote:
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | Last edited by swamp2; 04-12-2014 at 10:47 PM.. |
04-12-2014, 10:48 PM | #4 |
Rep 10,407
^ Come on guys, don't get my thread in an attempt at civil and meaningful discussion/debate get closed. Please stay on topic.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
04-13-2014, 10:50 AM | #5 |
Rep 4,381
When I said that the new lubrication system for the S65 would be optimised for the weight of oil it intended to use, it seemed like a given.
But anyway, lets say we have a cut down S85 block on the table and our remit is to design a new lubrication system and a new low pressure VANOS system. Firstly we need a target oil flow rate, something along the lines of: W gallons/min @ X degrees temp @ Y bar oil pressure @ Z engine rpm. Temp is going to be around 100C and pressure around 4 - 6 bar. Lets say that the Goldilocks flow rate W is 10 gallons/min. To achieve this target we can adjust: The oil pump drive speed - decides several factors including the flow rate at low rpms. The oil pump output flow rate - has to be high enough that even with elevated temps (and some loss of viscosity due to oil shear) it would always supply oil at a rate above the oil pressure regulating valve setting to ensure the correct oil pressure is supplied to the VANOS system (not necessary at low rpm where the VANOS remains in the default position). The pressure regulating valve setting - this has to be within an acceptable range for the new low pressure VANOS system as well as the oil. The oil viscosity - which is in this case going to be 10W60. So here again was my point, having adjusted the above to produce the desired flow rate of 10 gall/min with Castrol 10W60 what would be the effect of using Mobil1 0W40 instead. Given that Blackstone reports give a viscosity for used oil of: 0W40 ~ 13.0 cSt @ 100C 10W60 ~17.5 cSt @ 100C Would the new flow rate be in the region of 10 x 17.5/13? (13.46 galls/min). ie no longer the ideal flow rate. Last edited by SenorFunkyPants; 04-13-2014 at 11:14 AM.. |
04-13-2014, 11:15 AM | #6 | |
Rep 381
From what I've been reading in oil reports, the 10W-60 shears down to 40-50 weight oil. How does an optimized oil system, for one viscosity of oil, compensate for this phenomenon? |
04-13-2014, 12:53 PM | #7 |
Rep 4,381
The 10W60 does indeed shear down quite quickly to ~ 50 weight and then remains very stable. If you look at the all the UOAs for this oil it remains in the range 17 to 18.5 cSt @ 100c over a wide spread of mileages. So I would guess that you would need to optimise for a 50 weight oil in this case (bear in mind that the Mobil 1 0W40 will also shear down to a lighter weight oil). As swamp has noted the system would need to be quite robust to changes in viscosity but nevertheless you can't get away from the fact that *if* the Mobil 0W40 is indeed about a third "thinner" then the flow rate will never be as optimum as if you used a 10W60.
04-13-2014, 01:14 PM | #8 |
Rep 381
so could there be a happy medium? I know there is a 5w-50 out there but I read there is too much zinc in that one. If I remember correctly, too much zinc is bad for our cats? Are there any other 5w-50 oils we can run that hasn't been mentioned? Or is it a rare species of oil?
04-14-2014, 11:23 AM | #10 |
Rep 1,459
Someone mentioned on my oil analysis that it, "looked like I was using the new TWS 10W/60 which is a lighter weight than the old product." Can anyone confirm if Castrol switched up the formula recently? I imagine this would have an impact on those wanting to switch to M1 due to the lighter nature of the oil.
I'm really torn on which to use next! |
04-14-2014, 12:37 PM | #11 | |
Stop the hate, get a V8
3850
Rep 8,625
A while back it was updated to be "Castrol Edge Professional TWS" (only thing the dealers carry now). The old stuff was called "Castrol TWS Motorsport". Here's some more info: http://www.m3post.com/forums/showthread.php?t=404920
Past: 2011.5 M3 sedan ZCP |
04-14-2014, 12:39 PM | #12 |
Rep 1,459
04-14-2014, 12:43 PM | #13 |
Rep 658
04-14-2014, 12:57 PM | #14 | |
Rep 1,459
04-14-2014, 01:02 PM | #15 |
Rep 5,506
Not to point fingers but it looks like BMW knew there was an issue with the regular TWS being too thick and changed the TWS oil formulation because of it.
Auto Detailing Enthusiast!
04-14-2014, 03:41 PM | #17 |
Rep 4,033
Is it this thread? If so it was not deleted, just moved to this section.
http://www.m3post.com/forums/showthr...=966429&page=6
16 F82 M4 DCT - ZCP - JB4 - 556WHP / 570WTQ
08 E92 M3 DCT - Bolt Ons - 60-130MPH 10.71s - 11.88 @ 118MPH - 377WHP ESS VT2-625 SC 60-130MPH 6.80s - 11.30 @ 129.3 MPH 586WHP / 379WTQ ESS VT3-750 - 60-130MPH 6.14s - 10.81 @ 135.13 MPH 690WHP/463WTQ Shift-S3ctor E92 M3 - 1/2 Mile Trap Speed WR - 174.13 MPH |
04-14-2014, 03:59 PM | #18 | |
3850
Rep 8,625
Why wouldn't they label it as 10w60? The SAE has defined ranges for the viscosities, so the oil could be lightened slightly and still be a 10w60.
04-14-2014, 08:56 PM | #19 |
Rep 6,863
04-14-2014, 10:17 PM | #20 |
Rep 922
I feel like we just got up and moved conference rooms and then carried on.
'11 Black/Black GLK350 (Wife)
'19 Black RAM 1500 Big Horn Night Package '11 Loaded AW Fox Red/Black/Black Carbon Leather ZCP E90 M3 (Halloween Delivery) |
04-14-2014, 11:28 PM | #22 | |
3850
Rep 8,625
Yep. Like I wrote in the other threads, these discussions make my head hurt. I'm flabbergasted.
