BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
      04-02-2014, 05:24 PM   #1
Yoddha
Yoddha's Avatar
Drives: 2013 E92 M3
2013 BMW M3  [0.00]
Angel Eyes
Hey guys,
I tried looking this up but no one had a direct answer to my query. On the iDrive system, I am aware that you can turn off your angel eyes through settings in the "lighting" menu...however, I noticed that ever since I installed the LUX H8 V4s, the option in the lighting menu doesn't actually turn off the angel eyes unless my main switch on the left of the steering wheel has the main lights off. This is the case during the day and at night, is there any way I can fix this? Cheers for the help fellas
      04-02-2014, 06:03 PM   #2
grantmax
Drives: 2011 M3 ZCP
If the LUX H8 v4s are LED bulbs, this is likely because an LED bulb without a restictor gets a constant stream of power.
The license plate bulbs on my e46 M3 were swapped to LED and would remain illuminated for 2-3 minutes after locking the car.
      04-02-2014, 07:57 PM   #3
roastbeef
roastbeef's Avatar
Drives: E92 M3
This
Instagram; @roastbeefmike
      04-03-2014, 12:41 AM   #4
Yoddha
Yoddha's Avatar
Drives: 2013 E92 M3
2013 BMW M3  [0.00]
They aren't LED though that's what makes it odd
      04-03-2014, 03:07 PM   #5
grantmax
Drives: 2011 M3 ZCP
Maybe you have a problem with the wiring harness. I'd give the vendor a call.
      04-03-2014, 03:35 PM   #6
Amirsm3
Amirsm3's Avatar
514
Drives: 2011 Space Grey e90 M3
Lux uses 8 Cree LED's in their V4 kit, btw.
2011 e90 M3 Space Grey DCT ZCP- eAs, BMW Performance, Agency Power, Macht Schnell, iND, Milltek, Volk, Challenge, Stoptech, Ohlins
BMWCCA:518970
      04-03-2014, 03:50 PM   #7
jhbrennan
Drives: 2012 E92 M3
The Lux H8 does use LED's. From their website:
The LUX H8 V4 angel eyes use 8 of the newest Cree LED’s to offers unmatched brightness while its patented pending design makes both the inner and outer angel eyes as bright as possible. The new patented pending heatsink has a single flat side which correlates with the connector side of a standard H8 bulb, allowing for easier orientation when installing
      04-09-2014, 11:28 AM   #8
LuxAngelEyes
LuxAngelEyes's Avatar
It sounds like you have your DRL Lights on.....
The LUX H8 V4 bulbs will only turn on when there is power applied to them, so they will operate exactly the same as the stock halogen bulb. The lights cant turn on by themselves so it sounds like the DRL lights are turned on which would make them angel eyes on all the time.
m3post
