BMW X5 and X6 Forum 2014-Current
      04-01-2014, 09:35 AM   #1
1230vani
1230vani's Avatar
Drives: G05 40i LCI
ventil on the tyre replacement
Hi guys, no clue what the actual thing is called, but its called ventil in German . Had tyre change done at non-BMW shop and they've changed the tires (to my old winter ones from E71), but trashed this part from my OEM wheels and put some black silicone one (or something like that). Really tried to order with BMW but they said it cannot be ordered from BMW as it ONLY comes with the car unless you order the whole indiv. tyre pressure system and ditch the sensor part (70 euros per wheel)!
Car has normal tyre pressure system (not individual one per each tyre) and they said that I got it on my wheels eventhough those metal looking ones usually come with the indiv. tyre pressure.
Enclosed photo of one of the forum members to see what I am talking about. Can anyone order OEM ones or has a way of getting them.
Of course this may be irrelevant to 99% of you out there, but I want to have this.
THanks!
      04-01-2014, 03:00 PM   #2
E90Fleet
South Africa
1312
Hello
It is called a "valve stem" in English
Let me just get your question correct:
Do you want the original BMW rubber one ?
Or do you want the original BMW metal one ?
Is it the whole vale stem you want or just the metal tip that screws on and off ?
You have a F15 X5 ?
You do not have the optional tyre pressure monitor, option code 2VBA ?
BMW if you are reading, I need a job, Please.
      04-02-2014, 06:29 AM   #3
1230vani
1230vani's Avatar
Drives: G05 40i LCI
BMW metal one, whole vale steam, car is F15 production Dec 2013 so no option 2VBA. Thanks!
      04-02-2014, 07:27 AM   #4
E90Fleet
South Africa
1312
Ok, part number is "36 10 6 867 147"
It is number 12 in the photo, which is the valve stem with all its parts.
Number 7 would be the valve stem and the pressure monitor
Don t worry if you have a different wheel than in the picture, the stems are all the same.
      04-02-2014, 09:11 AM   #5
1230vani
1230vani's Avatar
Drives: G05 40i LCI
THANKS A LOT! I THINK I JUST MAY LEAVE WORK EARLY TODAY
      04-02-2014, 09:17 AM   #6
1230vani
1230vani's Avatar
Drives: G05 40i LCI
Do you think it works without the pressure monitor? The very end of the valve system (part# 12) looks a bit different on the photo (not round as with part#6).
Thanks again.
      04-02-2014, 10:05 AM   #7
E90Fleet
South Africa
1312
Thanks again.
The end is different because it has a part where the pressure monitor can be fastened onto with a screw.
The rubber one does not have this hole for the screw, so looks rounder.
Similar to this picture
      04-02-2014, 10:35 AM   #8
1230vani
1230vani's Avatar
Drives: G05 40i LCI
You sure it will work without the whole system. Valve stem cost 46 euro per piece. Thanks again for your efforts!
      04-02-2014, 10:55 AM   #9
E90Fleet
South Africa
1312
I have never done it myself, but you did say your car had them on before.
I cannot see why it would not work.
      04-02-2014, 01:48 PM   #10
1230vani
1230vani's Avatar
Drives: G05 40i LCI
thanks again!
      04-02-2014, 08:50 PM   #11
2014_F15
Drives: 2014 X15 35d
Where do you get your parts diagrams?
      04-03-2014, 04:28 AM   #12
E90Fleet
South Africa
1312
BMW (Paid for ofcourse)
      04-03-2014, 05:33 AM   #13
w4termelon
France
24
Drives: BMW X5 F15 M sport 40d
to find every single diagrams of BMW parts, just type "bmw etk" on google..
      04-03-2014, 09:27 AM   #14
1230vani
1230vani's Avatar
Drives: G05 40i LCI
Dealer told me it won't work without the whole sensor package as the tip part has to go into sensor (which was a change in their opinion as of today). They've also told me they have no clue which ones I had on the wheel, they think it might have been plastic ones that got painted when the wheel was being painted which is just riddiciluos guess. In the end they provided me with a non OEM similar product. Anyways, thanks for your help. So no clue what exactly I had, but I know they were appearing to look metal (or were metal looking) and looked pretty cool.
      04-24-2014, 01:32 PM   #15
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
FYI, Valve stem is just a valve stem. The valve stem used for the TPMS is special because you can mount the sensor to the valve stem. Without the sensor attached, the valve stem will work and functional as regular valve stem.
How do I know, I sell and installed them.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
xbimmers
