03-30-2014, 10:02 PM | #1 |
Rep 1,201
Closed my trunk while the batteey was disconnected. what do i do :/
Hey guys, so I was installing extended paddles and I closed the trunk while the battery was disconnected. I have no pass through and I have a 2010 so I don't have a key hole on my trunk. O tried jumping it from the front since the negative terminal was still connected but that didn't work. Any idea if there is a mechanical switch to get in? Any help here! :/
03-31-2014, 08:47 AM | #3 |
Rep 6,149
This is just a guess but if the positive battery terminal is not resting up against metal in the truck you might be able to put a charger or jumper cables on the positive terminal and ground under the hood. This may then allow you to press the trunk release and get inside the trunk. Hope all works out well for you.
**Looks like you may have tried this already and if so I am not sure why it would not work.**
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
03-31-2014, 08:51 AM | #4 |
Rep 714
Sorry to hear about your situation. Maybe try take apart the trunk pop switch and see if there's a way to pull the cable from there?
There's also a method of powering the trunk pop wire to pop the trunk but that'll involve cutting the wire sleeve Good luck!
2008 Alpineweiss III E92 M3
Amuse/Varis/CAE/BBS/BRIDE IG: Integraxtr |
03-31-2014, 10:17 AM | #5 |
Rep 3,387
Situations like this make me glad I have a key hole under the trunk lid. If you've already tried jumping and it didn't work, if I were in this situation, I'd remove the rear seat back to pull the day-glow emergency release in the trunk.
03-31-2014, 10:49 AM | #6 | |
Command Sergeant Major of the Army
142
Rep 639
Just thinking outloud...don't shoot me if it's a stupid idea.
2018 F82 M4 ZCP
2015 F13 M6 ZCP (gone) 2013 F10 M5 (gone) 2008 E90 M3 (gone) |
03-31-2014, 12:14 PM | #7 | |
Rep 3,387
And you essentially just repeated what I said right above you |
03-31-2014, 12:14 PM | #8 |
Rep 1,201
I thought jumping would work, but I have no idea why it wouldn't. Maybe the positive needed to be connected and the negative unconnected? Not sure. Also, I don't have ski hole so I can't get into the trunk and pull the release
03-31-2014, 12:17 PM | #9 |
Rep 3,387
You *can* get into the trunk, you just have to remove the rear seat back.
03-31-2014, 01:20 PM | #10 |
Rep 1,201
How would I do that in an e93?? My rear seats can fold down, but there is a grey felt wall behind it with a little cubby in it. There are also two insanely long screws going through the felt, so I wasn't comfortable pulling them out unless I knew what they did.
03-31-2014, 02:07 PM | #11 |
Rep 3,387
You never mentioned you had an E93. You sig says 328i. Is the top up or down?
03-31-2014, 02:12 PM | #12 |
Rep 1,201
03-31-2014, 03:29 PM | #13 | |
142
Rep 639
Good to know on the keyhole in my stillstock E90.
2018 F82 M4 ZCP
03-31-2014, 03:44 PM | #14 |
Rep 3,387
03-31-2014, 06:01 PM | #16 | |
Rep 1,201
Assuming it looks like this, looks like there is no way to get into the trunk in a convertible :'( |
03-31-2014, 06:02 PM | #17 |
Rep 1,201
Yea, well the roof is also electronic, and I can't get power to get any electronics on. I tried jumping the car's front terminal with another car but the car was still dead. Can't open the roof either
03-31-2014, 06:39 PM | #18 |
Rep 1,381
did you connect them properly, the correct way, and made sure the terminals were clean and have no contamination? and was the other battery fully charged? i can't see why jump starting the car wouldn't work. then again, I can't see why those Einsteins at BMW would not add a mechanical key in the first place either? How much cost savings did they accomplish?
03-31-2014, 07:10 PM | #19 | |
Rep 174
Post #4 seems on point: http://www.e90post.com/forums/showthread.php?t=690147
But you'd obviously want to confirm the wires match up and the whole thing sounds sort of sketchy... Quote:
04-01-2014, 12:55 AM | #20 | |
Rep 1,201
Yea! So I read through that thread since I'm basically in the same situation. So I just had roadside assistance tow my car to the dealership :'( Hopefully they can do the trunk release wiring trick like Post #4 Thanks for all the ideas guys! |
