ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      11-17-2007, 02:30 PM   #1
Chaseme
Euro fanatic
Drives: VW MKV Rabbit
What brake pads is everyone using on the Z4M?
I tried searching here and the other BMW Z-sub-forums but couldn't find the answer that I know is there.
My father's brakes are starting to squeel and we think we should get some new pads for that and just new pads that will reduce brake dust.
Thanks in advance,
Chase
Chase
      11-17-2007, 06:38 PM   #2
sales@ESSTuning
sales@ESSTuning's Avatar
391
Drives: ESS M3 / M4
Im using the Axxis ULT pads because the brake dust was driving me
      11-17-2007, 09:14 PM   #3
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
OEM...i noticed my left front one was starting to squeel today when i'm come to a stop. I'm thinking that it just needs some cleaning tho...
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
      11-18-2007, 06:53 PM   #4
Chaseme
Euro fanatic
Hey Roman,
How much have those pads been cutting down on dust? How is the performance/wear compared to OEM? Do they ever squeel? And lastly; where did you purchase them from?
Best regards
Chase
      11-19-2007, 08:50 AM   #5
sales@ESSTuning
391
Drives: ESS M3 / M4
Originally Posted by Chaseme View Post
Hey Roman,
Best regards
Dust is at a 0 now. My wheels stay cleaner then my car between washes. Pedal feel did not change much at all and they do not squeel at all.
I ordered them from here
http://www.**********s.com/product.a...-e46-brakes021
      11-19-2007, 11:30 AM   #6
BimmerZealot
Drives: 2019 BMW X3 xDrive30i
Had Hawk HPS Brake Pads on my E46 330. Loved them, my wheels weren't gunmetal (from Brushed Aluminum) 2 days after wash anymore. Only thing was squeak with aftermarket pads which can be embarrassing.
      11-27-2007, 07:45 AM   #7
Da Geez
Drives: MY07 Z4 M Coupe, MY04 325i
I used to own an exceptionally modified Suabru WRX, and found Porterfield R4-s pads to be best. They're not for track use unless you like molten pads, but they're the best pads I ever drove and are very rotor friendly.
Neither Axis nor Hawk pads compared well at all.
      11-27-2007, 02:24 PM   #8
jmillet
jmillet's Avatar
64
Drives: 2023 Hyundai IONIQ 6 SEL AWD
PF or Akebono
I used both the Performance Friction Z-rated pad and the Akebono ceramic pad on my former 2000 E36/8 Z3 M Coupe with good results; nice linear brake pedal feel and low dust.
I plan on replacing the stock dusty Textar pads with the Akebono Euro Ultra P/N EUR946 front ($55) and EUR683 rear ($62) from Rockauto.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      12-04-2007, 02:22 PM   #9
sixspeed
Z4M CSL
sixspeed's Avatar
Drives: Alpine White Z4M Coupe
Pagid RS29s on the front, still on stocks at the rear, but will swap them out when they wear through.
      12-11-2007, 04:05 AM   #10
1q2w3e4r
Breakfast at Tiffany's
1q2w3e4r's Avatar
24
Those are the exact ones you ordered? The stock M3 pads fit up with the M Coupe/CSL brake setup without any dramas? So the calipers are the same I take it and the rotors are just larger correct?
How would you compare the performance of them with the stock setup?
      12-11-2007, 08:38 AM   #11
sales@ESSTuning
391
Drives: ESS M3 / M4
They dont have a listing for the Z4M so you have to order the pads designed for the ZCP competition M3. To me the brakes feel the same as the stock pads.
Same set up.
      01-16-2008, 08:11 PM   #12
The HACK
Midlife Crises Racing Silent but Deadly Class
The HACK's Avatar
1821
Drives: 2006 MZ4C, 2021 Tesla Model 3
Calipers are not the same. The MZ4/M3 Competition Package brake calipers has larger front piston diameter than the regular E46 M3 brakes. However, the BACKING PLATES are the same.
The "prongs" on the back of the inboard brake pad on the MZ4/M3 Comp. Pack uses the same setup as X5 4.4 pads (but X5 4.4 pads are different backing). If you buy pads designed for the M3, you can bend the prongs out slightly to accommodate the MZ4. Otherwise it may make a squealing noise or knock when the pistons release.
      01-18-2008, 09:05 AM   #13
Da Geez
Does anyone know a reliable way to specifypads other than as for a MY07 M Coupe? I know we've got the competition brakes from the M 3 Coupe, but which year?
      03-17-2009, 10:27 PM   #14
Jacques79
Drives: 2006 M Roadster
So what are the best pads to buy for an Z4 M in order to eliminate breake squeal when coming to a stop sign or red light?
      03-18-2009, 09:41 AM   #15
jragan
Imola Lover
jragan's Avatar
Drives: 2007 Imola Red M Coupe
You're never going to fully elimate squeal. You drive a sports car so you get sports car side effects (like brakes that squeal).
His: RIP-"Ruby" E86 ///M Coupe: Pics Track Pics Short Vids Long Vids
Hers: 997-1 C4S: Pics
      03-18-2009, 10:16 AM   #16
Z4MCJJ
Z4MCJJ's Avatar
Drives: Z4MC
I use stocker pads. They sqeal only toward the end of track sessions and then stop squealing when they cool down a bit. Saturday was the only time I noticed a bit of fade as they heated up, but nothing too serious. My brake system is fully stock except for ATE super blue brake fluid.
      03-21-2009, 09:51 PM   #17
JCz04Bimmer
JCz04Bimmer's Avatar
32
Drives: 06 Z4MC
Ferodo DS2500 F&R for the street and I swap DS3000's up front for track duty. They are NOT cheap pads but the DS2500's are phenomenal street pads and the DS3000's are quite competent on the track. You just need to bed the DS2500's in properly to avoid some terrible squealing.
      07-08-2009, 09:47 AM   #18
Aurelien_D
Drives: Z4 3.0
Pagid RS29 front and DS2500 rear, with Castrol RBF 600 brake fluid on ATE disc.
      07-08-2009, 10:03 AM   #19
RussRamz
M Slut
RussRamz's Avatar
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
Pagid RS29 all four corners with a Stoptech brake kit.
You have to be 100% behind someone before you can stab them in the back.
David Brent
      08-21-2009, 04:43 PM   #20
Phillarius
Belgium
Drives: Z4MC
I'm running the DS2500 on the front, and after a few miles my wheels (csl's) are all red of brake dust. Has somebody else had this problem?
These are my third pair of front disks in 28.000km. The previous disks where both curved.
      08-24-2009, 10:08 AM   #21
xjeeper
Drives: M3
Akebono Euro.
Ran them on my M3 and now run them on my MC. LOVE THEM, zero problems and almost no dust.
Interlagos Blue over black extended leather E86 M coupe.
0-60 in 4.21 (calculated from E.T.) 1/4 mile in 13.1 @ 106. Bone stock.
      08-24-2009, 02:27 PM   #22
JCz04Bimmer
32
Drives: 06 Z4MC
I've run the DS2500's on my 330Ci and on my Z4M and have never had any dusting how you describe...
|www.onehotlap.com|Real People|Real Cars|
zpost
