03-22-2014, 11:18 PM | #1 |
Rep 693
Sport Mode that you toggle vs. Sport Mode by sliding the shfter
Hey guys...
Can someone explain this? What is the difference between toggling into Sport Mode from the toggle switch on the center counsel vs. sliding the shifter over to the side and going into S (which I'm assuming is also Sport Mode)? I know that you can manually up/down shift while in the S mode, but you can also just leave it in the S mode and it will shift automatically....just like toggling it to Sport Mode and leaving the shifter in normal position. What mode are you in if you toggle the switch to Sport Mode and then slide the shifter over? Sport Sport Mode? Then how about Sport+? Sport+ Sport Mode???? So confused. Z. |
03-23-2014, 03:21 AM | #2 | |
Rep 16
I hope i helped |
03-23-2014, 03:43 PM | #3 |
Rep 693
Ok. Then let me ask you this: If I toggle into Sport Mode (gearbox, Chassis, DTC, etc), and then slide the shifter into Sport Mode ( which only does gearbox), is sliding into Sport Mode do nothing because toggling into Sport Mode already put the gearbox into Sport Mode? I mean, you can't put the gearbox into Sport Mode twice.
Z. |
03-23-2014, 05:40 PM | #4 |
Rep 16
I am not sure about that because there isn't any sign but as far as i know if you get the toogle switch in sport or sport+ you get everything firmed up except of the gearbox so you can't put it twice....
