03-16-2014, 10:09 AM | #1 |
Rep 468
Scissor lift experience
Am thinking of buying a lift from these guys:
http://www.ezcarlift.com/ There was an old thread that mentioned them from a couple of years ago (http://www.m3post.com/forums/showthr...or#post9673917), but was wondering if anyone else has experience with them? |
03-17-2014, 04:01 AM | #2 |
Rep 714
My friend got one and I helped him put it together. It's pretty good, the hammer drill method to lift it is kinda weird at first but he got used to it
I would recommend it
2008 Alpineweiss III E92 M3
Amuse/Varis/CAE/BBS/BRIDE IG: Integraxtr |
03-17-2014, 06:41 AM | #4 |
Rep 10,616
Looks easy to me, and the portability would be helpful to some. For the price, you can buy a 2 post lift that will go all the way up, which is what I did.
There is a cheaper quick low lift version that does not go up quite as high for half the price, but the 4000 lb model is not out yet (it is coming): http://www.bendpak.com/Shop-Equipment/QuickJack/ |
03-17-2014, 06:42 PM | #5 |
Looking
252
Rep 460
^ Waiting forever for bendpak to make a version that will fit cars with jack points longer than 50 inches.
Cheaper and no cross bar (unlike ezcarlift) in the middle that might get in the way of some things
@DCxGarage
IG: |
10-25-2014, 11:17 AM | #6 | |
Rep 256
2013 Coupe | M-DCT | Alpine White | Fox Red | Carbon Leather Trim SOLD
Forza Michael!! |
12-27-2014, 07:38 PM | #7 |
the me
342
Rep 319
The quick jack looks interesting, anyone try it yet?
01 Z Coupe, 5MT, SB, not much else
08 M3 Coupe, 6MT, JB, not much else 21 M2c Coupe ,DCT, SOM, not much else |
12-28-2014, 01:46 PM | #8 |
Rep 5,483
I'm planning on getting the bendpak and storing it on the floor in my truck's parking space (truck has plenty of ground clearance to drive over it stacked on top of itself.
The 5000lb model maxes out at 50.5" between the jacking points and my M3 is almost exactly 50", really more like 49 centerline to centerline. So no unnatural acts necessary to make it work My garage is in the lower level with living space above, more than 1000sf but not much headroom.
04-13-2015, 10:44 AM | #9 |
Rep 1,679
I bought the 5,000 lb model (BL-5000) last week and set it up on Saturday with a friend (forum member Dogbone). Took about 2 hours from unpacking to lifting, being very precise with everything. Once done, plugged it in, lined it up under the jack points and it worked like a champ. I raised the car the full 24" and left it there overnight, no leaking, no issues. Only complaint is that when disconnecting the compression fittings a small amount of ATF fluid leaks from each one (about 1/4 tsp). Not a big deal, but it's important to keep a rag handy because that stuff is slippery!
04-13-2015, 02:58 PM | #10 |
the me
342
Rep 319
Thanks, on my list of new tools needed.
04-14-2015, 10:57 AM | #11 | |
Rep 112
And what was the cost of the model you purchased? Shipping Cost? Did you order direct or from a distributor?
04-14-2015, 11:40 AM | #12 |
Rep 1,679
I ordered from Autozone online because they had a 20% discount running (which I was shocked applied to the lift). After discount the unit was $1,039.99 plus tax ($93.60) and shipping ($100), so total came to $1,233.59. It was drop shipped from the manufacturer.
04-14-2015, 12:06 PM | #13 | |
Rep 3,988
Does the install require drilling or anchoring into the ground?
04-14-2015, 12:18 PM | #14 |
Rep 1,679
10-23-2015, 04:40 PM | #15 | |
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
Thinking of getting this in the DC version to facilitate fast tire rotation. Any problems with setup? Seems like you need a lot of time to get it first set up, and parts (teflon tape, air compressor, etc)
'06 BMW M3 ZCP 6MT | JRZ RS Pro + Hyperco 650/750 | Epic Tune | Brembo 355mm BBK | too many to list
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB Porsche 992 GT3, 991.2 GT3RS, 718 Spyder instagram.com/titomanlio |
10-23-2015, 05:06 PM | #16 | |
Rep 1,679
Setup takes about 90 minutes but from there it's a piece of cake to use. Only problem at the track is that it's a real attention grabber. |
10-23-2015, 08:56 PM | #17 | |
Rep 10,616
10-23-2015, 09:00 PM | #18 |
11817
Rep 23,187
I have the ezcarlift because I got it used for 600 bucks and love it. Wish I had room for 2 post lift but make due with it and can't complain. Lift time is slow and can't use it on my x5d because of weight.
10-23-2015, 10:43 PM | #19 | ||
Rep 1,679
10-23-2015, 10:56 PM | #20 |
Retired Curmudgeon
2985
Rep 4,047
This would have been handy as hell when I was racing! I don't like jack stands.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
10-23-2015, 11:03 PM | #21 |
11817
Rep 23,187
10-24-2015, 07:22 AM | #22 | |
Rep 10,616
My point was more that I would be done before you even got set up with your fancy portable lift. But I think those lifts are great and would be helpful for doing more involved projects at the track or even in a small garage that lacks the space or height for a real lift. Also as you get older lifts are nice. I got a 2 post 4 or 5 years ago. |
