02-26-2014, 09:01 PM | #1 |
Rep 20
Pandora Integration Question
Anyone else find the Pandora integration extremely poor? I use a snap in adapter but have to either
(A) Launch BMW Apps on Phone, Plug In (if not already selected), Select ConnectedDrive*on iDrive, (wait), then go to More Apps, select Pandora, go to Radio, Select Pandora (B) Launch Pandora on phone, Plug In (longer wait) go to Radio, Select Pandora I've programmed some of the preset buttons to make this a little easier but it's annoying. If I shut the car down next time I have to replicate it all again. If I think move away from Pandora app on the iPhone it stops. Pretty poor integration. The integration in our $37K Honda Odyssey is*much easier to launch. Is it a SUE (Stupid User Error) or is this actually how it works? |
02-26-2014, 11:24 PM | #2 | |
Rep 2,105
That is the way it works though. Its not ideal and needs a overhaul but the problem is even though things may be improved it always needs to be backwards compatible to work with older equipment found in older vehicles. |
02-27-2014, 04:38 AM | #4 |
Rep 693
There are actually 3 different ways to use Pandora app that I am aware of (I use an iPhone 5S). This is while the phone is already plugged into the car.
1) BMW App (Gives full Pandora functionality) Start ConnectedDrive -> Launch BMW App when iDrive tells you to -> Go to Additional Apps -> Select Pandora 2) Pandora App (Assuming you don't have BMW App or don't want to use it, and give full Pandora functionality) Start ConnectedDrive -> Launch Pandora App when iDrive tells you to -> Select Pandora 3) Media Source (Gives limited Pandora functionality) Select Multimedia -> Select Plug-In -> Launch Pandora Technically, there's a fourth way using BT, but that' pretty much same as #3. What I would've liked is to select Multimedia -> Plug-In -> Select iPod/iPhone (or external source) or Select Apps -> Pandora or Stitcher, etc. and give full functionality. When a phone is connected iDrive should detect apps that iDrive supports, but this is not the case. We have to manually launch this from the phone, which sucks. Z. |
