02-21-2014, 02:33 PM | #1 |
///M
158
Rep 3,195
30k Service
30k Service is up in a month or so... right before warranty ends later this year.
What goodies should I ask them to do besides the norm? wipers? brakes?
2011.5 AW/FR E92 M3 6MT
02-21-2014, 07:30 PM | #5 |
Rep 1,275
2022 M4 Competition ConvertibleDravit / Tartufo Full / Carbon Fiber Exterior...loaded
2020 X5:MW/Coffee Extended Merino, M Sport, B&W....loaded 2007 X3: Sapphire Black / Black loaded 6 speed Gone: M3 E93 Silverstone II over Bamboo |
02-21-2014, 08:59 PM | #6 |
Rep 4,488
Power steering fluid, diff oil, trans oil if 6MT (and maybe even DCT if you can get them to), coolant if you've never flushed it, engine air filter, cabin microfilter, and spark plugs. They'll likely tell you that you can wait longer on all of those or never do them at all (and thus Ultimate Service won't cover it), but remember that advice comes from the school of 15K oil changes.
Brakes are a condition-based wear item. Take a look at the pads, replace them if needed, don't if not needed. Same with wipers. If they make a lot of noise while sweeping the windshield and/or leave water streaks, replace them. Otherwise, they're fine. Mike Miller's Old School BMW Maintenance Schedule is a great reference if you intend to keep the car longer-term. I keep a list of all maintenance items with the mileage and/or time intervals they should be performed if you want it; it's largely based on Mike Miller's list but of course filtered down just for E9x M3 items.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 02-21-2014 at 09:07 PM.. |
02-21-2014, 09:08 PM | #7 | |
Rep 1,381
02-21-2014, 09:09 PM | #8 |
Rep 4,488
Ah screw it, may as well post my maintenance bible. Here goes:
Battery (incl. Registration): Every 48-60 months Brake fluid + clutch bleed: Every 24 months (more if tracked semi-regularly) Cabin air filter: Every 30,000 miles or 24 months Coolant: Every 24 months Differential oil: Every 30,000 miles or 36 months Engine air filter: Every 30,000 miles or 36 months Engine drive belt: Every 60,000 miles Engine oil + filter (8.8 L / 9.3 qt): Every 7,500 miles or 12 months Fuel filter: Every 60,000 miles Hoses (coolant + fuel): Every 150,000 miles Oxygen sensor: Every 120,000 miles Power steering fluid: Every 30,000 miles Spark plugs: Every 37,000 miles Transmission oil (6MT, and ideally DCT if you can get the fluid): Every 30,000 miles or 36 months Vehicle check (dealer checklist, on iDrive): Every 30,000 miles or 48 months Water pump and thermostat: Every 90,000-120,000 miles
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 02-21-2014 at 09:17 PM.. |
02-21-2014, 09:10 PM | #9 | |
Rep 4,488
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
02-22-2014, 05:19 PM | #11 | |
Rep 4,488
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 02-22-2014 at 05:33 PM.. |
02-22-2014, 07:25 PM | #12 | |
Rep 486
http://www.m3post.com/forums/showthread.php?t=778602 |
02-23-2014, 12:04 AM | #13 | ||
Rep 4,488
02-23-2014, 09:20 PM | #14 | |
///M
158
Rep 3,195
02-23-2014, 11:30 PM | #15 |
Rep 182
I know spark plugs recommended every 35k orso but iI can tell you iveI've logged data every 70k plus miles at varying age of plugs and after 15k it becomes almost impossible to hit max timing. Plugs for this car aren't just plugs but they regulate timing by being the measurement tool for knock. It uses the current between plug to measure this and thus any little deposits start to effect that signal...
So every 15 k is what I do. Probably lose 10-15 HP if you don't change based on being about 3 degrees less timing on average. I agree normally changing plugs this often would be silly but since they are measuring ionic currentand that is what dictates ignition retardation, its really a sensor too . I also change air filter every 5-10 |
