02-10-2014, 06:49 AM | #1 |
Rep 893
DCT Fluid change, 4qts out, 2.5 in?
I changed my DCT fluid this weekend. When I drained it, a little over 4 quarts came out. When I tried to fill it, ~2 quarts went back in. I leveled the car, ran it at 2,000rpm for a minute, then let it cool off. After this I could only get another .5 quart in.
I've driven the car the past day trying to get the fluid to get through all the passages and was going to attempt to put more fluid in it tonight. Has anyone else had similar issues? What are the chances the fluid was overfilled from the factory? |
02-10-2014, 08:22 AM | #2 |
Rep 1,673
Not sure about dct but my diff was way overfilled. I took the top plug out first and the fluid just poured out. All over my arm, floor you name it. So I guess it is possible for sure.
Electronics Junkie, Engine Builder.
02-10-2014, 08:52 AM | #3 |
Stop the hate, get a V8
3850
Rep 8,625
That's really weird. When I had mine changed late last year they got 4 quarts out and put 4 quarts in.
How do you know that 4 quarts came out? Did you measure it? Also, did you replace the filter?
Past: 2011.5 M3 sedan ZCP |
02-10-2014, 08:59 AM | #4 |
Rep 893
I also removed the fill plug before the drain plug but none came out. When I unscrewed the drain plug, it made a big mess and fluid went everywhere.
02-10-2014, 10:38 AM | #5 |
Putcha ang ganda...
281
Rep 5,441
im not sure how you over fill a diff doesnt it have an overfill. well when filling it up it still start to drip out when its full.
so how do you overfill it? unless its not level to the ground. maybe DCT is different.
02-10-2014, 11:39 AM | #6 | |
Rep 893
I did not change the filter. |
02-10-2014, 01:26 PM | #7 | |
Rep 545
Read this thread (important post #4 & 5) includes the PDF directions. http://www.m3post.com/forums/showthr...t+fluid+change Be sure to follow the directions or you will not have the correct fluid level. |
02-10-2014, 01:29 PM | #8 | |
Rep 1,673
Even not changing the filter you would think put the same back in. Unsettling because you really don't have a clue where you are now
02-10-2014, 02:09 PM | #9 | |
Rep 893
02-10-2014, 06:36 PM | #10 | |
Rep 545
Go back and read step #2 in the directions. "Make sure that the transmission is at ambient temperature (engine should not be warmed up)." |
02-10-2014, 08:00 PM | #12 | |
Rep 893
So in conclusion, 4 quarts originally came out and 3.5 are in. I'm happy with that. The car was driving strangely earlier today (hard shifts from 1->2) but that seems to have been fixed now. Last edited by vastano; 02-11-2014 at 06:26 AM.. |
02-10-2014, 08:29 PM | #13 | |
Rep 120
Did you check the level with the engine running? Plus you should find a shop to run the test plan for oil Adjustment and teach in valve curves makes the trans feel amazing. The picture is of the Autologic I use.. also the bmw GT1 some private shop might have.
02-11-2014, 06:26 AM | #14 | |
Rep 893
Would the Bavarian Auto tool have this functionality? |
02-11-2014, 02:01 PM | #15 | |
3850
Rep 8,625
Interesting, haven't seen that. What does the "teach" functionality do, exactly? I don't believe the shop did this on mine when the fluid was changed.
02-11-2014, 10:08 PM | #16 | |
Rep 545
If certain service procedures were completed beyond the oil change or the transmission needed the test plan then it would be done. There are two Piezo pressure sensors one for each clutch. The electronic pressure control valves convert an electric current specified by the DKG control module into a proportional hydraulic pressure. The electronic pressure control valves operate the valves that belong to the shift elements. See below from the technical manual. "Learning the valve characteristic curves on the twin-clutch transmission. With the service function 'learn valve characteristic curves', the reference points of the valves are activated and the associated pressure is measured; the values are stored in the EEPROM. The service function 'learn valve characteristic curve' must be carried out after the following tasks: • Replacing the clutch • Replacing the mechatronics • Replacing the oil pump • Replacing the DKG combined sensor The service function 'learn valve characteristic curves' runs automatically. Duration: approx. 2 minutes. The instructions of the BMW diagnosis system must be followed without fail, as this is the only to ensure a correct operation. The following environmental conditions must prevail when learning the valve characteristic curve: • The engine must be running • Parking brake activated • Gear selector switch in position N Sequence of the service function: • Check of the environmental conditions • Start learning valve characteristic curves (automatic sequence, no other intervention by the operator is necessary). The reference points of valves PV1 and PV2 are activated in succession. The corresponding pressure is measured in the clutches. The values determined are then stored in the EEPROM. • Termination of the service function after successful completion • In the event of faults, the service function is repeated" |
02-11-2014, 10:37 PM | #17 |
Rep 120
its not mandatory but i find it makes them feel better. the "teach" test plan starts with the car stationary in N and holding rpm at 2000rpm then it builds trans line pressure and starts activating the valves for the first clutch and second clutch packs. viewing there characteristic. the old SMG trans has more test plans options but again only is you replace parts or needed to bleed the system after repair. doing a couple select ones made start off clutch engagement speed and overall driving feel smoother anything to help them out.
02-12-2014, 12:04 PM | #18 |
3850
Rep 8,625
Interesting, thanks. I remember something like that being popular for the SMGs to resolve clunking or slow shifting. Sounds like I probably didn't need it (51k when the fluid was changed). If I did want to have it performed, is this common for shops or is it really a dealer-only thing? Does the car need to get up on the lift, or are they doing it purely through the diagnostic port?
02-12-2014, 04:14 PM | #19 | |
Rep 545
04-15-2014, 03:03 PM | #20 |
Rep 387
04-15-2014, 06:42 PM | #21 |
Rep 4,001
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
