XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
Register FAQ Calendar Today's Posts
      02-07-2014, 12:25 AM   #1
Alanintx
ATAP
Alanintx's Avatar
Drives: 2017 Midnight Blue 430xi GC
Overhead console removal
Has anybody done this in the x1 yet? Usually it's just a series of well hidden clips. Need to get up there to find a switched power source for my v1 radar detector.
      02-10-2014, 04:13 PM   #2
p@dre
Poland
Drives: 2014 BMW X1
maybe it will help ...
http://www.motor-talk.de/forum/anten...-t2920288.html
      06-05-2014, 12:08 AM   #3
Alanintx
ATAP
Alanintx's Avatar
Figured it out. Thanks for your response
      09-05-2014, 09:27 AM   #4
Mr Kleen
teh porcupine
Mr Kleen's Avatar
South Korea
97
Drives: 2020 Tesla 3 LR AWD
2013 BMW X1  [10.00]
Looking to remove the overhead console to repair a broken dome light.
Any tips on the removal?
EDIT: found a couple links with good info
http://www.1addicts.com/forums/showthread.php?t=209491
http://www.e90post.com/forums/showpo...2&postcount=29
      09-05-2014, 01:25 PM   #5
themishmosh
Drives: BMW X1 xDrive35i
Stick your hand between the headliner and glass in front of the console. You can release the clips in front with your fingers. Look at the pics in those threads for where the two clips are and how they hold the console in. Pretty easy and takes seconds.
      09-07-2014, 10:02 PM   #6
Alanintx
ATAP
Alanintx's Avatar
Another option.
Remove the black plastic rings around the map lights. They just snap out and pop back in. If you look through the hole, towards the windshield, you can see the back of the clips, with a small gap on the side. Straighten a paper clip with a small right angle bend, stick it carefully in the gap and position it so you can pull back the clip (away from the windshield), and pull. Do the same for the second clip and get ready to catch the console when it drops.
When replacing it, align the rear of the console first, then push up on the front till the clips engage.
      09-08-2014, 04:09 AM   #7
Mr Kleen
teh porcupine
Mr Kleen's Avatar
South Korea
97
2013 BMW X1  [10.00]
Thanks for the tips, will try them out one night this week.
      09-16-2014, 02:30 PM   #8
Mr Kleen
teh porcupine
Mr Kleen's Avatar
South Korea
97
2013 BMW X1  [10.00]
I was able to remove the console, thanks for the tips.
Now I have to source the bulb fitting. I managed to break one of the little metal tabs while trying to install an LED lamp.
BMW parts lists it for €0.61. Not expensive, I just hope they've one in stock.
      05-25-2018, 11:54 AM   #9
sayemthree
sayemthree's Avatar
597
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
Originally Posted by Alanintx View Post
Another option.
I found this to be the most helpful
      05-25-2018, 12:33 PM   #10
sayemthree
sayemthree's Avatar
597
I hardwired might the V one with the green and yellow wire it is switched off the ignition
xbimmers
