BMW X5 and X6 Forum 2014-Current
      01-20-2014, 12:52 AM   #1
garylamusa
Drives: x5
Parked-car heating remotely from iPhone
is this working for anyone and how do I activate this?
your insight is highly appreciated.
      01-20-2014, 03:53 AM   #2
Baunton
Baunton's Avatar
England
320
Drives: X5 45e 2021
In UK if you have the Auxiliary Heating option its:
http://www.bmw.co.uk/en_GB/new-vehic...tml#remoteserv
Dunno about NA.
      01-20-2014, 11:21 AM   #3
originalgoods13
Drives: Chevy Spark
Required is ConnectDrive Professional Services ARTTI Subscription, which is separate from your standard BMW Assist/ConnectedDrive subscription.
It is Auxillary heating, using the heat from your engine/coolant.
      01-20-2014, 02:08 PM   #4
someguy
someguy's Avatar
Drives: 2014 X5 3.5d
Your vehicle would require the auxiliary heating unit (not available in the USA).
There was a recent thread about "remote Start" where this was discussed.
thanks,
someguy
      01-21-2014, 07:55 AM   #5
el-nino
Drives: 2014 X5
It works for me.
The app will point out where I last parked my car. It will also allow me to lock/unlock my doors, remotely honk the horn and remotely flash the headlights. This will only point out where your car is if you had the iphone hooked up prior to exiting your car.
It will also allow me to google search an address and send the info to the car. I have tried this but was unsuccessful in retrieving the address? Maybe I am doing it wrong?
Also, the Auxiliary Ventilation works. You can set it to a certain time to go off. I set it for 3:15pm. Sat in my car at 3:14pm and sure enough it turned on shortly after 3:15. I did not sit around and wait for the car to get warm. The app it self says "Auxiliary ventilation" and not "Auxiliary heating". I do not know if this will heat the car or just circulate the air?
I hope this info helps.
      01-21-2014, 05:12 PM   #6
newbimmerx5
Drives: BMW X5
Aux heating with extra price and only available in Europe. The alternative would be Remote Start which will turn on your car engine and thus heating.
You may get this feature after market and not from factory in USA
xbimmers
