12-29-2013, 05:05 PM | #1 | |
Rep 816
Changing the DCT Fluid Question
12-29-2013, 05:35 PM | #2 |
Stop the hate, get a V8
3850
Rep 8,625
You'd get more replies if you put this in that same thread, or in the maintenance section.
Past: 2011.5 M3 sedan ZCP |
12-29-2013, 06:31 PM | #4 | |
Rep 545
See attached PDF |
12-30-2013, 07:01 PM | #5 |
Rep 545
Thought I better explain why:
The internal hydraulic pump runs whenever the engine is running, this changes the level in the sump (lower part of the transmission). When the engine is turned off there will be drain back into the transmission raising the fluid level higher than normal running level. This happens also in automatic transmissions that often require a running level check. |
01-01-2014, 04:55 AM | #6 |
Rep 996
