12-16-2013, 03:38 PM | #1 |
Stop the hate, get a V8
3850
Rep 8,625
BMW DCTF-1 used transmission fluid analysis
OIL BMW DCTF-1 (Pentosin FFL-4)
MILES IN USE 51,108 MILES 51,108 SAMPLE TAKEN 12/13/13 MAKEUP OIL 0 ALUMINUM 12 CHROMIUM 0 IRON 34 COPPER 5 LEAD 0 TIN 0 MOLYBDENUM 0 NICKEL 0 MANGANESE 5 SILVER 0 TITANIUM 0 POTASSIUM 3 BORON 67 SILICON 11 SODIUM 5 CALCIUM 41 MAGNESIUM 2 PHOSPHORUS 263 ZINC 11 BARIUM 0 SUS VIS @ 210ºF 50.9 cSt @ 212ºF 7.55 FLASHPOINT ºF 405 FUEL NA ANTIFREEZE 0.0 WATER 0.0 INSOLUBLES 0.2 TAN 1.5 This is the factory-fill DCTF-1, aka Pentosin FFL-4 (basically a 75w85 GL-4). Worth noting that I usually drive the car in the more aggressive shift settings and am not shy about downshifting to get some engine braking. I've never used launch control but who knows what the previous owner did -- 44k on the clock when I bought the car. Blackstone actually does have data from this fluid/vehicle thanks to some of the folks on here and showed my wear to be much better than their averages! They specifically called out the copper and lead (from brass/bronze parts) as "amazingly low". They agreed that it's probably not a lifetime fluid, but said it could go to 70k or further. I replaced it with Motul Multi DCTF, but due to the change process, we only got 4 of the 7.8L out though after seeing the analysis I have no worries about that. We changed the filter to be safe too. So like my engine UOAs have shown, I definitely got a good one!
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 12-16-2013 at 03:46 PM.. |
12-16-2013, 05:59 PM | #2 |
Rep 767
Congrats man! That's always good news received my Blackstone kit last week. Will get it sent off after the next oil change.
2019 McLaren 720s / 2018 Lamborghini Huracan Performante / 2019 Porsche Macan Turbo / 2016 BMW M3/// IG @jon.hagerty
12-18-2013, 07:53 AM | #4 |
3850
Rep 8,625
No, I had a local indy shop do it.
Past: 2011.5 M3 sedan ZCP |
12-18-2013, 11:48 AM | #6 | |
3850
Rep 8,625
Somewhat. Since we only got half of the OEM fluid out (normal), that means I don't have a full crankcase of it. What I will say is that the higher viscosity index is apparent when it's very cold: the car is less sluggish going into gear. Of the 4 L we drained, the viscosity of the factory fill came back on the very high side of the "acceptable" range. Here's a thread about the Motul Multi DCTF that I made recently: http://www.m3post.com/forums/showthread.php?t=909687
12-18-2013, 05:02 PM | #7 | |
Rep 2,339
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
12-18-2013, 09:20 PM | #8 |
3850
Rep 8,625
Try XTR Performance. Tell Chris that Dan P referred you.
01-01-2014, 06:34 AM | #10 |
Rep 24,668
Mine was done last year preventive at my BMW dealer with Pentosin .(30K miles)
Filter set was replaced too .
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. Last edited by ///M Power-Belgium; 01-01-2014 at 06:39 AM.. |
