BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
      11-28-2013, 12:22 AM   #1
thegad
Drives: Jerez Black E92 M3 (sold)
Question Dealership inspection results -- what's real what's BS?
Unfortunately I threw a CEL while fairly far away from home, so rather than risk limping back so I could go to my regular (trusted) shop, I took it to the local BMW dealer. It ended up being a coil pack which they ended up charging just shy of $550 for finding the CEL cause, parts, and labor (after checking the threads I see I could have bought the part for $60 and done the install myself one weekend...)
While they had my car they performed the standard Free Courtesy Inspection and came up with the following. I'm wondering a) how much of this is something I should be worried about and b) what (if any) items would be easy for a relatively inexperienced person to DIY:
-Rehose cooling hoses with expansion tank and cap*
-A/C Evap Service
-Power steering fluid service, both hoses leaking from reservoir*
-Belt driven component noise on cold start, most likely idler on passenger side belt*
-Fuel Injection service
-Brake fluid
-Microfilter
*These are the three that were unexpected and that have me mildly concerned., I was already planning on having the brake fluid & microfilter changed out.
      11-30-2013, 04:12 PM   #2
dparm
Stop the hate, get a V8
dparm's Avatar
Drives: C7 Corvette GS, AMG C63 S
I would definitely get those leaks verified by an indy shop, and have them replaced/repaired. Can't comment on the cold start noise since that's pretty vague.
Not sure what you mean by A/C evap service. Do they mean recharging the system?
Fuel injection service = pass. Easy moneymaker for the dealer. Minimal benefit on a port-injected car that gets 91+ octane.
Brake fluid should be changed regularly, yes. Microfilter (cabin filter) needs to be changed too. You could do both of those yourself in under an hour in your own garage. BMW specifies change intervals for those two things, so yes, you need to have those changed.
Past: 2011.5 M3 sedan ZCP
      12-04-2013, 03:13 PM   #3
thegad
Thanks for the reply, I'm getting some quotes now and am going to get everything fixed up!
      12-21-2013, 11:22 PM   #4
thegad
Good news, I took it to my trusted shop. Turns out there were no issues with my power steering or cooling hoses, and the belt driven component noise was just a loose pulley. I got that and everything else need fixed up for a fraction of what the dealer quoted, and things are running great now!
      12-21-2013, 11:36 PM   #5
tinman831
Drives: M3
      12-22-2013, 01:02 PM   #6
smellfish
No one on the corner has stagger like us
50
Drives: '11 AW E90
Glad you got it sorted on the cheap. If you had to do those things they aren't too tough. Had to replace a leaking PS line on my 335. Changed and bled the whole system DIY. Had to disassemble and clean out the coolant res after I broke the bleed screw. All easily DIYable. Just messy.
Tags
cooling hoses, fuel injection service, power steering
m3post
