BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
BPM
      11-25-2013, 12:25 PM   #1
Harpua
Drives: 2008 E90 M3
Winter oil recommendation?
Apologies for the repeat thread originally posted in the Canada forums. I thought that this might reach a bigger audience.
I was wondering if any fellow winter drivers are using a lighter weight oil during winter use.
The 10w60 is great for high revving, high temp track days but I would guess not so much during a -10 degree cold start up and short DD commute.
I was thinking about switching to 0w40, either Mobil 1 or Castrol -- Both of which are fine by BMW's LL01 standards.
Opinions/experience/expert advice appreciated
PS My '08 E90 M3 is out of warranty.
      11-25-2013, 12:40 PM   #2
elm3
///M Fan
elm3's Avatar
Drives: '09 E92 M3 IB/'17 f85 X5M LBB
2017 BMW / X5M  [9.00]
2009 E92 M3  [10.00]
2004 Yamaha R1  [10.00]
BMW recomends 10w60, stick with 10w60. Please do not change the viscocity of your oil. That engine was built to use 10w60.
'09 E92 ///M3 Interlagos Blue,6MT,Silver Novillo Leather,CF Trim,Premium Package,Technology Package,Cold Weather Package,Premium Sound,19"Wheels,Moonroof-Toy/'17 X5M, Long Beach Blue, Executive Package,Technology Package, Lighting Package, Driver Assist, Full Mughello Red Interior, 21" wheels-Toy/'14 535i with M Sport and 19" wheels-Daily
      11-25-2013, 01:29 PM   #3
dparm
Stop the hate, get a V8
dparm's Avatar
Drives: C7 Corvette GS, AMG C63 S
False. BMW has now said it is okay to use LL-01 oils, meaning you could run something like Mobil 1 0w40 or Castrol Edge 0w40. Those would be noticeably better for ultra-cold starts. Nod goes to M1 for its ultra high viscosity index of 185, but in Canada it's expensive. You could also consider Red Line 0w40.
Past: 2011.5 M3 sedan ZCP
      11-25-2013, 01:29 PM   #4
W///
W///'s Avatar
7494
Drives: F82GTS, E36/E92M3, Z4M
I run M1 0W-40. Warms up to about 1/3 mark quicker than 10W60 used to, then it acts the same. There's quite a few members that have switched over.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT
08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT
07 E85 Z4M Roadster, Alpine White/Red, 6MT
99 E36 M3, Techno Violet/Dove Grey, 6MT
      11-25-2013, 01:43 PM   #5
speedaddictM3
Drives: 2008 E90 M3
I have TWS but will change it soon. I migh actually even go with 0W30.
      11-25-2013, 01:54 PM   #6
speedaddictM3
Drives: 2008 E90 M3
TWS is a garbage oil for the winter. It has terrible cold flow properties as it just gets too thick and viscous. I never liked using such a thick oil in the winter but that was the only option from bmw. But recently with the revised LL01 recommendations and the bearing wear thread, it makes more sense to switch to something much lighter, especially for those of us out of warranty and have no concern about using a possibly unapproved oil.
      11-25-2013, 01:56 PM   #7
dparm
dparm's Avatar
Make sure it's an ACEA A3/B4 0w30 (which means HTHS >3.5). There are a lot of 0w30s with HTHS of 3.1ish, which is way too thin. You probably won't generate sufficient oil pressure.
Only ones that come to mind are Castrol Edge 0w30, Renewable Lube 0w30, and Total Quartz 9000 0w30.
      11-25-2013, 11:02 PM   #8
JEllis
JEllis's Avatar
532
Drives: E36 M3, E92 M3
I switched to M1 0W-40 and I live in AZ where its always warm/hot. No issues so far.
http://www.m3post.com/forums/signaturepics/sigpic14547_7.gif
Instagram: jellismotorwerks
      11-26-2013, 05:30 AM   #9
Harpua
Drives: 2008 E90 M3
The price difference b/t the "European Formula" Mobil 1 and Castrol 0w40 is minimal (about $1 per litre). Is the Mobil 1 the superior option between the two?
Thanks again for everyone's input
      11-26-2013, 07:08 AM   #10
dparm
dparm's Avatar
Yes, the M1 is the superior oil.
      11-26-2013, 09:33 AM   #11
Rostasteve
Drives: 08 E90 Jerez Black M3
Only Castrol Edge 5W30 is LL01 approved. This very same oil used to be marketed as "Castrol Syntec 0W30". Castrol may market this oil differently in Canada, just look for LL01 approval.
Personally, I've had better luck with Castrol 5W30 than M1 0W40 on my E46 -- the engine ran quieter and oil analysis showed less wear. Viscosity wise, they're very similar -- Castrol is a thick 30 when hot and M1 is thick 0 when cold.
At the end of day they're both great oils with many miles on them.
      11-26-2013, 10:29 AM   #12
dparm
dparm's Avatar
Incorrect. There are several Castrol Syntec/Edge oils that carry LL-01, which you can verify on the Castrol datasheets:
0w30
5w40
0w40
The Edge 5w30 you refer to is NOT LL-01. It is LL-04 and is targeted at diesels. Do not confuse off-the-shelf Edge with Edge Professional, which is an OEM product only available at dealers (i.e. Castrol Edge Professional TWS, Professional OE, Professional Long-Life, etc).
      11-26-2013, 11:57 AM   #13
apecush
Drives: 2008 E90 M3
Anybody who made the switch to 0W40 notice less "lurching" at low speed (1st/2nd gear) when the car is cold? I noticed a significant reduction when switching from 10W60.
      11-27-2013, 05:49 PM   #14
bde
bde's Avatar
48
Drives: 2024 X3 M40i, AW
I drive with 10-60 and don't have any issues with cold starts.
I always let it idle for at least a couple of minutes in sub-zero temps regardless of what the manual says in order to make sure oil gets distributed around properly.
I try not to rev it past 3k rpm until the temps reach 90C - takes about 10-15 mins of driving.
Oil change intervals 6-7.5k KM.
      11-27-2013, 07:46 PM   #15
red330i
Drives: 2009 AW M3 Coupe
Question for those using an oil other than 10w-60, what are you using for oil change intervals?
      11-30-2013, 04:05 PM   #16
dparm
dparm's Avatar
Only way to determine a good interval is to try 5k and pay for an oil analysis with TBN + TAN.
Some members have settled on 5k, some on 7.5k, others on 10k. It just depends on your driving habits and driving style. A person making a lot of short trips needs the shorter interval, but a person who is on the highway most of the time can go to 7.5k and beyond very easily.
m3post
