11-13-2013, 12:58 PM | #1 |
Rep 429
Angel Eyes Change
All,
Just getting my feet wet with the x6 and wanted to inquire about options for getting rid of the ugly yellow headlight halos. I know 1 option is the LED headlights but thats a pretty expensive upgrade. Are there other alternatives for a 2013 x6 ? What does everyone else without LEDs do ? I am basically just looking for the closest to LED look that can be achieved without the OEM LED upgrade. |
11-13-2013, 06:01 PM | #2 |
Rep 1,292
A lot of members are using Lux ver. 4.
_____________________________________ 2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4 |
11-14-2013, 12:06 AM | #3 |
Rep 376
i have the lux v3, they looks great. Not as bright as the new OEM ones but bright enough. Plus they dont have that purplish hue like the new ones, im not a big fan of that anyway.
11-15-2013, 09:10 AM | #5 |
Rep 772
I picked up the LUX V4 from their website. With the V4 you can control the color temp so you can range from a yellow to white to blue/purple.
Install is very easy and only takes a few minutes. All you need to do is open the hood, remove the cover at the back of the headlight, unscrew the stock yellow bulb and unplug from the harness. After you unplug the stock bulb, plug in the V4 and choose your color setting. Then drop the V4 control box into the headlight and screw the new bulb in. Replace the cover on the back of the headlamp and close the hood. The first time will take a little longer since you have never done it before. After that it will be real quick. It is a little tight trying to screw the bulb in so your hands may get a little cut up, but its an easy mod and looks better than the stock bulbs. Good luck! |
11-18-2013, 08:15 PM | #6 |
Rep 376
11-19-2013, 08:51 AM | #7 |
Rep 265
Here is what I'm using and I think they're great. And I tried the V3s, and some other crap from Lumen.
http://www.amazon.com/iJDMTOY-360-De...ngle+eyes+cree |
11-20-2013, 11:47 PM | #8 |
Rep 1,391
Just installed these on my X6:
http://www.umnitza.com/dtec-v7-h8-le...tt-p-6464.html FYI, Umnitza had a super-special 3-wks ago at other BMW forums, for $100/set. I called cause the promo-code doesn't work anymore on the web. The staff, Tim K, told me they are running black-friday for $120 shipped. I asked if I can get that now, he's in the good mood maybe and said sure. So not $199 but $120 shipped. I had the older gen H8 LED with 4 Cree XB-D LEDs(paid $80 a year ago on ebay) in my 535i, thought those were super-bright already but these are even brighter with 8 Cree XT-E LEDs. At this point, we hit the diminishing return, cause the optics (plastic rings) inside the headlamp becoming the limitation, not to mention the outer rings always way dimmer. If only LED headlights are more affordable. Last edited by HPIA4v2; 11-21-2013 at 07:47 AM.. |
12-23-2013, 06:48 PM | #10 | |
Rep 326
