11-12-2013, 03:36 PM | #1 |
Rep 10
BMW Advanced Battery Charger
Just bought a 2013 E93. (I'm 64 yrs old & it's the first new car I have ever owned) Since winter is on the horizon I expect the car will stay garaged for extended periods. Due to some electronics running 24/7 the battery will need to be maintained. Since a trickle charger is not an option I was hoping to get the BMW Advanced Battery Charger but when I go to the BMW website they claim this charger is not compatible with an E93. It is only intended for E90 / E92. My primitive research indicates all three cars have an AGM battery so why isn't this charger compatible with an E93? If not, what charging method do I use? Let it run for an hour every few days?
Your help in this matter will be greatly appreciated. |
11-15-2013, 02:26 PM | #2 |
Stop the hate, get a V8
3850
Rep 8,625
Why not get a Battery Tender Plus? It's well regarded and can 'float' the battery, which is the safer form of trickle charging. You can get it from various auto parts stores for around $30.
Letting the car idle to keep the battery charged is not the greatest idea.
Past: 2011.5 M3 sedan ZCP |
11-15-2013, 02:43 PM | #3 |
Rep 24,668
I think that i have the best solution for charging the battery...
Check out my pics and comment of # 26 on this page >http://www.m3post.com/forums/showthr...=872785&page=2 And what do you think about this system ?
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
11-20-2013, 07:50 PM | #5 | |
Rep 318
I have used the Battery Tender Plus extensively and have found it to be very reliable. Here it is; http://www.amazon.com/Battery-Tender...ry+tender+plus It is identical in appearance to the BMW system, so I would not be surprised if they were one in the same. Why you were told the system was not compatible with your E93 is a bit of a mystery... Hope this helps and good luck! Nice dog... |
11-20-2013, 08:17 PM | #6 | |
3850
Rep 8,625
It IS exactly the same. The vents on top and LEDs in front are in identical positions, and the shape/proportions are identical as well.
11-21-2013, 06:33 AM | #7 |
Rep 10
Battery Charger
Thank you quadpipes. According to BMW, the reason their charger was deemed incompatible with the E93 is this: originally it charged through the cigarette lighter (not any more) but the lighter is inoperative when the car is shut off, so charger is useless. BMW says now that is uses alligator clips there is no incompatibility problem. I don't know if this is true but this is what they claim.
I purchased the BMW charger at the dealer. When I opened it up, the paperwork was marked "Delran Battery Tender Chargers" so you are ABSOLUTELY correct. Having the BMW logo on my charger cost me about $25. Other than that it's the same machine as the Battery Tender. Thank you for your guidance. And your comment on my dog. |
11-21-2013, 04:31 PM | #8 | |
Rep 318
I also recommend the extension cables; http://www.amazon.com/Battery-Tender...=pd_sim_auto_1 This way you can thread the cable down thru the engine compartment and out the side and be able to completely close the hood. Good luck. |
