11-11-2013, 11:42 AM | #1 |
Rep 268
oil warning then nothing next day
I got a warning about the oil level at minimum yesterday and told me to add a quart.
Today, no warning, nothing. Should I still add a quart? Last edited by Dougeefresh; 11-11-2013 at 12:23 PM.. |
11-11-2013, 11:53 AM | #2 |
Rep 1,275
How long did you drive today? It may have been a valid warning yesterday and may take some additional time to "register" today. I would keep a quart handy, just in case, but would probably wait until you see the warning again.
2022 M4 Competition ConvertibleDravit / Tartufo Full / Carbon Fiber Exterior...loaded
2020 X5:MW/Coffee Extended Merino, M Sport, B&W....loaded 2007 X3: Sapphire Black / Black loaded 6 speed Gone: M3 E93 Silverstone II over Bamboo |
11-11-2013, 12:09 PM | #3 |
Rep 2,982
Laggy crappy oil sensor. If it's a day from the first time you saw it, give it a bit more time and see where it registers a couple more times in local commuting. Also don't add the full quart immediately. Overfilling is a real issue. When you're down at the rock bottom minimum line on the instrument cluster, you can safely add a full quart. Engine holds a tick under 9 total quarts btw.
11-11-2013, 12:43 PM | #5 |
Rep 12,310
Never add 1 quart in one go. I always do 1/4 or 1/2 and see where the level is.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
11-11-2013, 12:46 PM | #6 |
Rep 73
I had this not too long ago. I got a message and then for 2 days nothing.... it comes back. If I were you I would keep a Quart handy and as soon as it comes up again I would put it in.
11-11-2013, 07:22 PM | #8 | |
Rep 4,488
OP, drive 5 miles, then pull over on a level surface and while the engine idles, tell the car to remeasure the oil -- twice. Then add 1/4 quart or even 1/2 quart LESS than what it wants.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
11-11-2013, 07:29 PM | #9 |
Large Member
295
Rep 979
Drives: '19 Porsche C2S Cab_M3 DCT ZCP
Sometimes with changing temperatures the oil quantity sensor gets confused. Although it's a 1,000 miles since the car's first oil change, it thought for a little while yesterday that it was overfilled.
11-12-2013, 12:13 PM | #10 |
Rep 708
I just had the opposite problem as you (meaning it's typical). I got the half-quart low warning, but having had some experience waited a few days to make sure it stayed there. It did, so I put in 1/4 quart to see how it changed.
No change... Odd, so a few days later put in a bit less than another 1/4 quart. Still nothing. Waited a few more days, and presto - suddenly the oil level jumps up to full! The guys recommending you wait, and warning you about overfilling are right on. Having an oil sensor with a dipstick would be useful - having an oil sensor without a dipstick is just a PITA. Cheers
Bye bye E93 M3 - Hello F83 M4! |
11-13-2013, 09:33 AM | #11 |
Rep 268
The warning came back and I added 1/2 L two days ago. Still getting the warning and no change to the level (still at min). Gonna wait a couple of days to see what happens
11-23-2013, 11:41 AM | #12 |
Stop the hate, get a V8
3850
Rep 8,625
Just keep an eye on it. Sensor might be a tad flakey.
Past: 2011.5 M3 sedan ZCP |
12-10-2013, 09:47 AM | #13 |
Rep 7,298
One time i had half level readout and when i updated to 240e jspec, it said full!! It took about 4 days to read half again. Then added 200mL then waited a few days ans added another 100mL and waited a few days. Then presto, reading at full.
12-12-2013, 07:30 PM | #14 |
Rep 5,498
The gauge is such a pain. I believe its crucial to keep the oil at the top of the range but the difference between min and max appears to vary. During my last oil change the oil went from min to max with probably 1/8th of liter. I spent hours filling a little at a time after the first 8ish liters, driving a few miles, checking the reading and then filling a little more.
Instagram: jellismotorwerks |
02-12-2014, 10:23 PM | #15 |
Rep 860
Our lousy sensor can only calculate 1/2 L adjustments to the oil level so I try to only make changes 1/2 L at a time then let it re-calculate for a day of driving to make sure it got a good read. Sometimes it won't change for 2 drive cycles and then will decide to change on the next drive. It's a real pain.
