10-26-2013, 10:45 AM | #1 |
Stop the hate, get a V8
3850
Rep 8,625
Are dealers using the new Pentosin CHF202 now?
These cars (and pretty much all BMWs) came with Pentosin CHF11S as their factory-fill power steering fluid. While CHF11S is still available, it has been superseeded by CHF202. Pentosin says it is 100% compatible with CHF11S and can even be mixed.
Are the dealers transitioning to this newer fluid, or are they still on CHF11S? Only significant difference I see is that 202 is a touch thicker at very cold temps (-40 C) and hence has a slight drop in viscosity index. Pour point is also down a bit too, but the ignition point has risen. I have no doubts that it is totally safe to use, but I'm just curious about what the dealers are doing. Oddly the CHF202 carries fewer manufacturer specs but I suspect that's because it's new enough that it hasn't been thoroughly tested. For those curious... CHF11S technical datasheet: http://www.pentosin.net/pressrelease..._CHF11S_V3.pdf CHF202 technical datasheet: http://www.pentosin.net/specsheets/Pentosin_CHF_202.pdf Proof of compatibility: http://www.pentosin.net/pressrelease...luid_Guide.pdf "Note: CHF 11S and CHF 202 are fully compatible and mixable. Pentosin CHF fluids should not be mixed with ATF fluids"
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 10-26-2013 at 11:01 AM.. |
