10-15-2013, 10:33 AM | #1 |
Rep 318
Catless DPs /w PE + Y-Pipe
Anyone in the GTA running catless dps and an aftermarket exhaust (assuming the answer is yes)?
Right now I'm running the PE + Y-Pipe with stock dps and n54 mids (minus the resonator). Looking to install VRSF 3" DPs, I want to know how much louder it will be. Love the sound of my current set-up and I could tolerate a little more but I don't want the car to sound like a riced out civic. I want to know if anyone has something similar to my proposed set up and would share their thoughts and a sound clip. Thanks |
10-15-2013, 10:50 AM | #2 | |
Rep 291
BMS DCI / BMWP Exhaust / JB4 G5 / VSRF DPs ... for now!
10-15-2013, 10:59 AM | #3 |
Rep 318
Too bad you're not in Toronto haha!
I already got the pe n y pipe so I don't want take a step back. Hoping the dps don't make the sound unbearable... Hoping someone has already done it haha |
10-15-2013, 02:16 PM | #4 |
Rep 2,388
Drives: M2 Competition
I am not local but here's what I noticed after installing my DPs after the car already had the PE.
1. A bit more drone 2. A bit more bark in the power band (4k-5.5k) 3. A lot more pops,burbles,gurgles(whatever onomatopoeia you would like to call it) on downshifts and upshifts 4. Turbo spool will be more audible along with a whoosh noise since the PE isn't a terrible loud exhaust 5. Cold starts were the only really dramatic change, took a little getting used to when starting the car in the garage. Hope that helps |
10-15-2013, 02:21 PM | #5 | |
Rep 291
10-15-2013, 02:25 PM | #6 | |
Rep 2,388
That combination is very clean. I highly recommend it. |
10-15-2013, 02:34 PM | #7 | |
Rep 318
10-17-2013, 10:58 AM | #11 |
Rep 291
How's that setup? Loud, drone, rasp? Thanks!!!
10-17-2013, 03:03 PM | #12 |
Rep 566
My first exhaust mod was golf-tee mod. Noticed a sound difference for roughly 2 days, then gotten used to it.
My next mod was downpipes. Definately improves throttle response and that "the turbos don't have to work as hard to churn out the power" (that may be a placebo effect) With golf-tee mod and dp, I was already satisfied with the exhaust tone - it was "loud" and "deep" enough for increased performance sound and for some to notice on the road; added driving pleasure; all while staying very compliant for daily driving. I then came across a PE and bought it, seeing how there was so much hype for it on the forums. I've only installed the PE, without the Y-pipe. The exhaust feels slightly more free-flowing; tone got slightly deeper; volume has increase less than ~10%. It's only louder and has a slightly different tone than original exhaust above 3700rpm - as another member has said above, "more bark in the midrange above 4K". Cold start is a LOT louder. It BOOMS on start, and when cruising gently away while still not fully warmed up, what used to be "pops burbles, and gurgles", has now become "PAHs, POWs, and !!!POPs!!!" - sounds pretty badass I must say. It 100% turns the heads of car enthusiasts in parking lots. No droning whatsoever. |
10-17-2013, 03:11 PM | #13 | |
Rep 291
10-17-2013, 03:54 PM | #14 |
Rep 318
Awesome feedback ASPEC appreciate you taking the time to let us know your thoughts!
Since I've already got the y pipe installed, might as well just keep it in. Once I get the dps in, I'll be sure to get a write a review and post a sound clip! |
