BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Mporium BMW
      09-09-2013, 11:59 AM   #1
apecush
Drives: 2008 E90 M3
Redline Fluids - A quick empirical report
A few months back I decided to deviate from the BMW recommended TWS motor oil and OEM transmission fluid. My car is an 08 with 40k miles on the clock and tracked 5-6 times a summer. I change my oil at double the recommended interval, and I believe my trans fluid change was the first since the 1200 mile change.
Using TWS, I would burn a litre of oil every 3 track days. After 3 track days using my Redline blend (8 quarts 10W60 with one quart of 5W40), the car hasn't registered any oil loss. I blended the two grades in an attempt to match the 100C kinematic viscosity of TWS, as the redline is a bit thicker. I'll do a blackstone analysis of the redline when I drain it. FWIW, I have noticed absolutely no change in mileage after switching oil (a good sign IMO).
As far as the transmission is concerned, I went to Redline D4 fluid. Initially, i noticed no difference in shifting compared to the fluid I pulled out. A couple track days and a thousand miles and the transmission now shifts a bit smoother.
For anybody considering Redline, I've noticed no noticeable drawbacks of using the fluids.
      09-09-2013, 12:14 PM   #2
CIFUM3
CIFUM3's Avatar
Drives: 08 E92 M3
Good to know! I just ordered to gallons of 10w60 from the redline website!
Performance
ESS 625 VT2 Supercharger - CAE Shifter - Revinora race+ axle back - Macht Schnell down pipes - SOSI X-pipe
Looks
M colors grill - CF trunk - Sapphire Blue Forgestars F14
      09-09-2013, 12:22 PM   #3
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Agree on the Redline. I've run the 10w60 and MTL for a while now. You're right, the 10w-60 appears to be thicker as the oil temp is a bit higher with it compared to TWS.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
      09-09-2013, 02:08 PM   #4
FogCityM3
FogCityM3's Avatar
499
Drives: M3 (E90) & Porsche GT3 RS
Used the 10W-60 and seemed fine, though in retrospect should probably be using something thinner after all the interesting comments (the credible ones that is) from earlier posts. What do you guys think of using Redline 5w-50?
http://www.redlineoil.com/product.aspx?pid=135&pcid=21
      09-09-2013, 02:40 PM   #5
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
I think, after reading as well, the thinner oil would only benefit the rod bearings, and that's just a theory. As to the other areas of the engine, designed for 10w-60, like the hydraulic lifter assemblies, who knows the effect of thinner weight on those critical areas.
      09-09-2013, 02:54 PM   #6
Z K
Z K's Avatar
1889
Drives: E90 M3, G20 M340i
TWS thins down after driving a while. Redline seems to hold its weight better. Mixing in 1 quart of lower weight oil with Redline 10W60 seems like a good idea to get closer to TWS.
Auto Detailing Enthusiast!
      09-09-2013, 06:02 PM   #7
Billj747
Billj747's Avatar
Drives: Everything
Someone should send in a sample of virgin redline 5W50 and 10W60 to see how the SUS Viscosity @ 212*F compares to TWS.
IMO if the 5W50 has a similar viscosity @ operating temp, then the benefit of the lighter base weight for cold starts and flow would just be huge positive. radiatorjoe? uses a blend of redline 40W and 5W30 with great blackstone reports but it's quite a bit lower SUS V than TWS. (68-73 vs. TWS's ~87).
      09-10-2013, 10:36 AM   #8
Porschefile
Porschefile's Avatar
59
Drives: E92 M3
I run redline diff fluid (and have for several thousand miles and several track days) and it has worked well.
      09-10-2013, 11:09 AM   #9
apecush
Drives: 2008 E90 M3
Did you find that you needed to add any LSD modifier to the fluid to prevent chattering around corners? I bought fluid intending to make the change, only to realize that I bought 75W90, not 75W140.
      09-10-2013, 12:17 PM   #10
Porschefile
59
Drives: E92 M3
Nope, no unusual noises or performance.
      10-22-2013, 10:39 AM   #11
MVEED3
Drives: '16 GT4
Ape,
Do you have a 6spd or 7spd? Your comment of smoother shifts has my attention.
Allen
2021 ZR2 Airborne certified
2019 GTS PCCB 5x130 Slick
2016 Agate Grey GT4 PCCB LWB
2013 HP4 Competition
      10-22-2013, 11:13 AM   #12
Z K
Z K's Avatar
1889
Originally Posted by MVEED3 View Post
Ape,
Allen
The Redline D4 ATF the poster mentioned is only for use in the manual transmission.
      10-22-2013, 01:03 PM   #13
dparm
Stop the hate, get a V8
dparm's Avatar
Drives: C7 Corvette GS, AMG C63 S
Red Line 10w60 is already thicker than TWS and is more shear stable, meaning that you're running something HEAVIER than stock. You need to ignore the kinematic viscosity values and focus more on the oils' HTHS value as it is more indicative of the operational viscosity.
TWS has a virgin HTHS of around 5.2 and shears to around 4.5ish, then holds steady for the remainder of the change interval. Red Line 10w60 has a virgin of HTHS of 5.8 and probably only shears to the mid- or low-5s over its service life.
That means the Red Line is some 15% heavier than the already-heavy TWS. Personally, I would've just run the Red Line 5w40 (HTHS 4.4) -- it's basically the same weight in-operation as TWS.
Past: 2011.5 M3 sedan ZCP
m3post
