      08-26-2013, 07:56 PM   #1
Die ///M Rakete
Die ///M Rakete's Avatar
Drives: 2016 F80 ZCP 6MT
A moment of silence...
..for my original PS2s at 8200 miles. They were a lot like zombies...dead a few thousand miles ago but still rolling around
And a warm welcome to my new sticky OEM size new Super Sports. The increase in grip is sensational
      08-26-2013, 08:26 PM   #2
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
Wow, looks like you got the most out of them!
      08-26-2013, 10:48 PM   #3
Die ///M Rakete
Yeah...looking at them now makes me feel totally irresponsible for waiting this long
      08-27-2013, 10:10 AM   #4
PLAY_HRD
GOT M
PLAY_HRD's Avatar
Drives: 2023 BMW M550i xDrive Sedan
Mine look just as bad!!! I'm still debating between Mich Super Sport or Bridgestone S-04. What size did you go with?
      08-27-2013, 10:55 AM   #5
Die ///M Rakete
I went with OEM sizes all around. I wanted to increase grip while still maintaining the "balance" of the car...and avoid rubbing to boot
Mission accomplished! For the first time since I've owned the car, I'm able to accelerate at WOT with no discernible wheel spin in second gear...and this is with an ESS Stage 1.5 tune
This plus higher tread wear, excellent manners in the wet and relative low cost make them, in my opinion, the undisputed choice for the street
I plan to safely go through two sets of rears before needing to replace the fronts.
      08-27-2013, 11:10 AM   #6
Chapman1977
Drives: 1M Coupe
Congratulations of the tires!
Only thing I don't get is that I have the exact same setup, PSS in original sizes and NO tune and can't get the power down in second. Traction enabled and it barely moves at all just keeps on blinking - MDM on or all nannies off the rear just starts going really sideways.
Maybe I got a bad set of PSS..that's why I keep thinking about going Semi-Slicks oder superwide (285/295) in the back with PSS or a similar high performance tire.
Cheers
      08-27-2013, 11:11 AM   #7
flzrider
Drives: AW 1M
Whoa! I'm at 26k miles still on the original tires and they don't look that bad.
      08-27-2013, 11:28 AM   #8
Die ///M Rakete
Cheers
Hmmm...that's interesting. I will conduct some more "WOT research" and get back to you with my findings
      08-27-2013, 12:00 PM   #9
PLAY_HRD
GOT M
PLAY_HRD's Avatar
My other reason for looking at Bridgestone is that I HATE the stretched look that Michelin's have.
      08-27-2013, 12:14 PM   #10
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
Cheers
Hankook RS3s, Dunlop Z2s will get power down.
Remember though, a cold tire is a cold tire. You will not get grip.
      08-27-2013, 12:33 PM   #11
ozinaldo
ozinaldo's Avatar
Portugal
116
Drives: 1M
I have the stock size PSS on my car since December 2011. There is no comparison to PS2 or other real street tires (not streetable tires) in terms of putting power down. I am with stock engine tune and it just hooks at second with mild and pleasant tail movement with MDM on. Of course, if you go WOT and DSC on at the same time it will just blink and cut power. Also, they must be at operating temperature and with right pressures, as a matter of fact like all tires, so maybe a short commute and wrong pressures may be the reason for lack of grip?
On the other hand, I started to sense a slight bit of worsening in ride comfort and grip despite low mileage I have (just 7500 km.); thinking that tires are on since more than 1.5 year maybe they are heat cycled or really loosing their initial grip after some mileage. Honestly, I am not thinking about keeping them on till the end of tread life, will sell and put new ones (maybe again PSS) when they are like 50%.
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake.
      08-27-2013, 03:02 PM   #12
fastauto
fastauto's Avatar
Drives: AW 1M Coupe
that's exactly what I was thinking. I have 20k on mine and they don't look that bad. that 20k includes a lot of track time as well
      08-27-2013, 03:28 PM   #13
Die ///M Rakete
Lol...wow...maybe my wife wasn't exaggerating about my driving after all
      08-30-2013, 05:40 PM   #14
M3 Adjuster
Albania
7906
Drives: 1M, X1 M Sport, E46 325ic
run them til they cord!
my RS-3s have a LEEETLE bit of tread showing...
      08-30-2013, 05:42 PM   #15
M3 Adjuster
Albania
7906
Cheers
Originally Posted by ozinaldo View Post
I have the stock size PSS on my car since December 2011. There is no comparison to PS2 or other real street tires (not streetable tires) in terms of putting power down. I am with stock engine tune and it just hooks at second with mild and pleasant tail movement with MDM on. Of course, if you go WOT and DSC on at the same time it will just blink and cut power. ].
285 in the rear really makes a big difference. When I put a set on, I realized that I had been spinning my rear tires with 265s in the rear the entire time. I would bet that you would see the same improvement as you did from PS2 to PSS when going from 265 to 285 or 295 in the rear. It's a SIGNIFCANT improvement in rear grip.
I definitely recommend going bigger up front as well at the same time, if you value the ability to turn also.
      08-30-2013, 05:48 PM   #16
M3 Adjuster
Albania
7906
Hey, who gave grandma-ma a 1M ?
you have 26K on the REAR tires ........ seriously?
      08-31-2013, 04:41 PM   #17
octainejunkee
octainejunkee's Avatar
Drives: M3 f80 Comp, MPE, stage 1
Cheers
Mine was the same- now with the geometry tweeked the car puts down the 530lbftq better than the standard set up...
My advice would be to get your geometry set up with no camber on the rear
and some tow in dialed in, you'l get more grip/less wheel spin and less tire wear..
BSM 1M owned from new.
      09-03-2013, 03:15 PM   #18
flzrider
Drives: AW 1M
That's including half a dozen laps on the Nurburgring and some fun on the autobahn.
Seeing as how this is my daily driver, if I can't get ATLEAST 25k miles out of a set of tires, I am going to through a ton of $.
      09-03-2013, 04:16 PM   #19
Chapman1977
Drives: 1M Coupe
Thanks man, I'll try that after the winter.
Cheers
      09-03-2013, 04:51 PM   #20
Yellowceta
Yellowceta's Avatar
Drives: 2011 VO 1M
2011 BMW  [0.00]
I think I still hold the record for the most miles on the rear stock PS2's @ 36,000 miles. That does include one track day! Gotta love highway miles...
1996 Trans Am WS6 (RiP)
2002 Trans Am Collector Edition WS6 - Not Stock @ 425 rwhp
2006 VW GTi - APR Goodies - Sold
2011 1M - VO Florida pick up 11/4/11 #554 of 740 - Sold
2017 ATS-V Stock
      09-16-2013, 04:17 PM   #21
MEDMAN808
Drives: 2018 M240i
Driftin' the night away....
      10-15-2013, 08:30 AM   #22
kevin pecks
Drives: 1M
I am truely impressed by some mileages you guys got on your rear PS2. I had 2 Sets and they both were gone by km 20.000. Great all around tyre, but i didn't even drift massively and had only 40 laps on the Ring with the 1M
1addicts
