08-03-2013, 03:16 PM | #1 |
///M
160
Rep 1,867
Battery tender
About to go buy a battery tender since my car going to be parked for a couple weeks, do I hook it up directly to the battery or the connections in the engine bay?
THANKS TO:~<RPM>~ ~<SONICMS>~ ~<MODECARBON>~ ~<McKennaPerformance>~
MODS: MODECARBON V2 GTS FRONT LIP & REAR DIFFUSER, AA GREEN FILTER, RPI SCOOPS, PSW, Verstraβe Extended DCT Shifter, ZCP WHEELS (SEMI-GLOSS), OHLINS R&T, Megan Exhaust, AKRA XPIPE, BMW LED INTERIOR, BLACKOUT W/ORION V4 LED AE, OSRAM CBI |
08-03-2013, 03:32 PM | #2 | |
Rep 24,668
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
08-03-2013, 04:10 PM | #3 |
11817
Rep 23,187
i have always connected under the hood but either should work fine. just pain that cover has to come off in the trunk area.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
08-03-2013, 04:38 PM | #4 |
Rep 781
I have mine plugged under the hood yesterday. Bought it and used it for the first time.
Just so you know, I had mine charged for 6 hrs and it did not change to green. Car was still showing low battery. Looks like i'll need to keep it on for more than 10+ hrs. |
08-03-2013, 04:43 PM | #5 |
Rep 24,668
No,no ....my central connector comes out under that cover it's just a little connector...and stay's there ...one click and i charge,very ..very easy
08-03-2013, 04:45 PM | #6 |
Rep 24,668
Direct on battery is way faster to charge ...i did the test
M3_Slayer22.50 |
08-03-2013, 07:17 PM | #7 |
///M
160
Rep 1,867
anyone use this tender before?
Battery Tender 021-0128 Battery Tender Plus 12V Battery Charger
08-04-2013, 12:57 AM | #8 |
Rep 349
I've used it for years but haven't hooked it up to the M3 yet since I just picked it up a week ago. Great charger! You'll love it and get a lot of use out of it.
08-04-2013, 07:55 AM | #9 | |
///M3
42
Rep 349
08-04-2013, 10:28 AM | #10 | |
Rep 586
I'm in a private parking garage with no access to electricity, so I am using a Battery Tender Solar 10 watt panel on the E92, and a 5 watt panel on the E46. The panels sit in a garage with frosted windows, and still gets enough light to trickle charge the cars. As a data point, the E46 started strong after 8 weeks of sitting idle on the solar charger with no issues. Normally at 4 weeks it would be a hard crank to start, and at 6 weeks the car would basically be dead.
2013 E92 M3 (the weekend good weather car), 2018 Tesla Model 3 Performance (the 20k mi/yr beater)
08-04-2013, 12:52 PM | #11 | |
Rep 24,668
08-04-2013, 01:12 PM | #13 |
Mr. Nice Says Hello
636
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
08-05-2013, 12:09 AM | #14 |
Rep 266
**Edit: To answer my own question. We have AGM batteries not Gel Cell batteries. The 021-0156 is for Gel Cell batteries. I believe the 021-0128 is the correct charger.**
I looked up the Battery Tender 021-0128 on Amazon and noticed just below it they now have a Battery Tender 021-0156 that is made for gel cell batteries. Sounds better suited to ours; anyone tried it? Last edited by White 13; 08-06-2013 at 10:50 PM.. |
08-05-2013, 12:53 PM | #15 | |||
///M
160
Rep 1,867
thanks Quote:
i can hook it up and leave it for weeks right? or do i have to unplug it once its full?
08-05-2013, 01:35 PM | #16 |
Rep 24,668
You asked...how long hooked up to the car ?
Actualy my CTEC Multi XS 7000 was hooked up to my battery for more than 4 months,i don't drive my car in wintertime (roadsalt !) and had no problems,my battery is still in top condition ,the CTEC is actualy a trickle charger,and prolongs the lifetime of our battery
08-05-2013, 05:06 PM | #17 | |
///M
160
Rep 1,867
sorry for all the question i never used a battery tender before
08-05-2013, 05:17 PM | #18 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Yes that is the whole point of the battery tender. It's not a quick charger. It for maintaining your battery charge without overcharging like some quick chargers will do. It can remain hooked up indefinitely.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
08-05-2013, 06:04 PM | #19 |
///M
160
Rep 1,867
Thanks!
08-08-2013, 12:07 PM | #20 |
Rep 781
this is how i keep my hooked up..
I keep the hood open since I park in a garage. |
08-08-2013, 01:38 PM | #21 |
///M
160
Rep 1,867
i hooked it up the same way but kept my hood semi closed, hooked it up for over 16hrs and its barely blinking green
08-08-2013, 01:47 PM | #22 | ||
Rep 781
