      07-15-2013, 08:34 AM   #1
Thibs
Drives: 2011 BMW 1M
KW V3 install/ Torque specs
I finally installed my new suspension on the weekend. I ran into a problem snapping one of the studs off the stut mount spring perch
Does anyone know if I can replace the stud or will I have to get a whole new hat?
Also does anyone know the torque specs for the 3 nuts?
      07-16-2013, 03:10 PM   #2
mikewills
Drives: Ducati Hypermotard
2008 Duc 848  [0.00]
The vorschalg ones are around 16-18 ft lbs, but I'm not sure about stock. I would just pair these up with vorschalg camber plates for an additional cost, but I don't think the studs can be replaced.
BMWCCA #454364
      07-16-2013, 04:40 PM   #3
M3 Adjuster
Albania
7908
Drives: 1M, X1 M Sport, E46 325ic
agree.. sounds like a GREAT opportunity to just go with camber plates and do it right the first time..
      07-16-2013, 10:51 PM   #4
Thibs
Drives: 2011 BMW 1M
thanks. you are correct the studs are actually like a press pin/stud. I am not able to find anything like it. The dealer told me they only sell the unit as whole. I guess a camber plate will probably be my best option
1addicts
