BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Mporium BMW
      06-29-2013, 06:20 PM   #1
Mrbig
Drives: 15 M3
Quick question car needs oil ?
What can I use just for a temporary fix driving says low oil and can't find exactly what BMW recommends ???
      06-29-2013, 06:32 PM   #2
ERinEC
Drives: '11 AW E92 M3
Castrol full synthetic. I forget the weight, but it wasnt something Advance Auto carried, so I went to the dealer and bought a quart there.
You should be okay in the meantime as long as you dont rack up a bunch of miles before topping off.
      06-29-2013, 06:37 PM   #3
Wei718
Wei718's Avatar
340
Drives: 718 GT4
10W60
      06-29-2013, 06:40 PM   #4
Mrbig
Drives: 15 M3
I know noone carries what oil the car needs auto zone doesn't have it either !!!
      06-29-2013, 06:45 PM   #5
nujabes24
Forever Rest In Beats
nujabes24's Avatar
73
Drives: 2014 MW M4
Creme fraiche is good
Jk 10w60
      06-29-2013, 07:02 PM   #6
Ashley Schaeffer BMW
Drives: E92 M3
No chain stores carry 10w60.... go to a dealership asap.
      06-29-2013, 07:09 PM   #7
kscarrol
kscarrol's Avatar
Drives: 2021 X3 M40i, 1974 2002 Tii
Exactly why I carry a quart in the trunk...
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual
BMWCCA # 327475
      06-29-2013, 07:17 PM   #8
nujabes24
nujabes24's Avatar
73
Drives: 2014 MW M4
I mean that's a must. I have two just Incase
      06-29-2013, 07:56 PM   #9
Mrbig
Drives: 15 M3
Amazing lol
      06-29-2013, 08:12 PM   #10
Koldun
Drives: 2011 E92 M3
Bearings shot in 5... 4... 3...
      06-29-2013, 08:22 PM   #11
09E92M34ME
Drives: 2009 E92 M3
your car holds 9 quarts of oil and the gauge only shows the final quart. If you are a little low that means you are some where between a quart low.
09 E92 M3,AW/FR. MODS:Performane Kidney Grills,Side Gills,Exhaust Tips,BMW Performance Pedals,359 Satin Black GTS Wheels,275/35/19R & 255/35/19F PSS's,Dinan Stage I Suspension,Macht Schnell Spacers 12mmF,5mmR,Rear Fogs,Euphoria 6k,LCI Tails,LUX v3,OEM IND Painted Alpine White CF Performance Spoiler, Front Splitters, and Front Reflectors,Gloss Black Hood Vents,M Performance Steering Wheel.
      06-29-2013, 08:24 PM   #12
09E92M34ME
Drives: 2009 E92 M3
Scratch that, it says you have a 335 so i don't know.
      06-29-2013, 09:38 PM   #13
Longwong
Drives: e92 m3 catless
regardless of what you have but especially the m3, you can add a quart of something similar as there are 9 friggin quarts. The slightly different weight will be neglible when mixed in. Autozone and stories carry a couple different 50 weight oils (only the top number matters at all especially for adding a quart) Sure its not ideal. If you can go to the dealer great. Carry a quart next time. But until then grab a 50 weight oil at the local auto store and you will be fine. Make sure its sythnetic obviously
      06-29-2013, 10:37 PM   #14
FVM3
FVM3's Avatar
273
Drives: e92 m3, f30 328i
top up, 10w60
      06-29-2013, 11:40 PM   #15
Nuke818
Nuke818's Avatar
Drives: 2013 E92 M3
The last time I got the warning I added castrol 5w-50. Just make sure you don't overfill it and get 10w-60 in as soon as you can.
2013 E92 M3
Space Grey/Fox Red Novillo
      06-29-2013, 11:53 PM   #16
mdosu
Drives: Double Vanos'd Civic-M3
Use Synthetic please, the closer the weight the better, you're adding less than a full bottle in a 9ish bottle engine...no biggie
      06-30-2013, 01:07 PM   #17
JWE90
2008 E90 M3 6 spd., no sunroof, no nav, no idrive
Drives: 2008 E90 M3
Do not blend oils as they all have different additive packages, some of which can react together. Just go to the dealer and get the right stuff when possible or order it online. This is not an emergency.
      06-30-2013, 01:58 PM   #18
Crypty
Drives: '08 e92 M3
My M3 needs a quart every 3-5k miles so I ordered several extras here:
http://www.ecstuning.com/BMW-E92-M3-S65_4.0l/ES10317/
      06-30-2013, 04:00 PM   #19
CBS
CBS's Avatar
Drives: F10535, E90M3, E30M3, E28M5
2017 Alpina B6 GC  [0.00]
2014 535xi M Sport  [0.00]
2014 X3 3.5 M Sport  [0.00]
2011 M3 E90  [9.74]
2007 Z4 M Coupe  [7.00]
1990 M3  [9.50]
1988 M5  [10.00]
This.
Get a BAV Auto Oil Travel Case for $5.95. Velcros to the trunk side wall.
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes
      06-30-2013, 05:57 PM   #20
Longwong
Originally Posted by Lute View Post
+1
6 years into the production run and people still asking which oil to use..wow
He did not ask which oil to use but rather which to use or what to do when no dealer is available or the right type readily available.
I think this comes up a lot for people.
And the additive packages in 1/9th of the oil after dilution will have zero impact on anything. I would not add 2 litres plus of a different oil but a half litre or litre is nothing
      06-30-2013, 09:05 PM   #21
jphughan
jphughan's Avatar
Drives: '16 Cayman GT4
Assuming this is for an M3 (despite the fact that your avatar indicates a 335is), read the M3 Supplement. Alternative oil weights are clearly listed: 10W-40, 5W-50, 10W-50, synthetic. Since it's summer I'd go with 10W-50 if possible. If this is for a 335is, the regular manual specifies approved weights: 0W-40, 0W-30, 5W-40, 5W-40.
And then yes consider keeping a bottle of the proper stuff in the car or at least at home. My dealer gives me a couple bottles when I run low between oil changes as part of Ultimate Service.
EDIT: Turns out the BMWUSA website has an even more detailed guide for this: http://www.bmwusa.com/Standard/Conte...ngineOils.aspx
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten:
'11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015)
      07-01-2013, 04:04 AM   #22
sensi09
Drives: .
Jphughan has all the info in his post, but also can be found here
http://www.m3post.com/goodiesforyou/e92-m3-manual.PDF
page 206
m3post
