M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Engine, Exhaust, Drivetrain Modifications
      06-27-2013, 12:24 PM   #1
blackjack7779
Drives: M5 F10
HELP akra exhaust noise
exhaust noise! i got my full akra intalled few months ago. but sometime when i just start the engine(cold) theres a metal noise form my akra exhaust. is like 2 aluminium papier hittin each other. Only happen when is cold-start. And i when to garage the enginer checked allrdy. They didint find anything! So im wonderin if anyone have the same problem.
Thx
      06-27-2013, 02:32 PM   #2
M54ccibo
M54ccibo's Avatar
Drives: '16 GT4
Is it a high-pitched rattle coming from the muffler?
To see if this is it, fire up the car, go to the side making the noise, and push the valve open and then let it close. Push the valve all the way closed. If it goes away when open and then when pushed closed you found the issue.
That is what mine was doing. I tried to extend the ball and socket to close it further but it was almost all the way out already - so I just bent the actuator bracket a bit to close off the valve all the way, voila - no more rattle.
Current: '16 GT4
Past ///Ms:
'13 F10 M5, Alpine Weiss III/Sakhir Orange Full
'10 E60 M5, Space Gray/Black
      06-27-2013, 09:52 PM   #3
blackjack7779
Drives: M5 F10
I see... Let me check on that. Thx alot really helpful!
      06-27-2013, 10:04 PM   #4
Hunter5179
Hunter5179's Avatar
Drives: 2013 M6 Coupe
Where do you hear the noise? In back or more toward the driver?
2013 M6 Coupe SG, VSE 003's 21, Akropovic Evo Carbon, KW V3, AMS DP's, Vorsteiner Full Aero, Gruppe M Intake, Bel Stir Plus & V1 with HP Laser Interceptors, P3Cars Gauges, JL 2X12W6Subs, 35%tints.
My Thread:
http://www.6post.com/forums/showthread.php?t=794659
      06-28-2013, 06:54 AM   #5
noushy
///M Fan
noushy's Avatar
1657
Drives: M8 Comp, X5M Comp, iX M60
Noise
Interesting my Akra on M6 does not make any such noise. I wonder if it was an install problem? There are multiple brackets that have to be removed and properly reinstalled. I would make your mechanic check each one of these as well. There could be one not properly torqued down and it only vibrates at certain frequencies.
Noushy
2019 BMW X5 50i Mineral White/Tartufo all options including M Sport
2022 Porsche 911 C4S Silver/Brown
2023 BMW iX M60 Black Sapphire/Amido, Titanium Bronze trim/22
2023 Audi RS6 Avant Daytona Gray/Black
2024 BMW X5M Comp Brooklyn Gray/Taruma Brown, Titanium Exhaust on order
      06-28-2013, 10:15 AM   #6
M54ccibo
M54ccibo's Avatar
Drives: '16 GT4
Noushy
True, there are other things...but it seems that exhaust valves (across the manufs.) can rattle. Mine was fine for 2 months, then started. Been fine since the adjustment.
Current: '16 GT4
Past ///Ms:
      06-30-2013, 05:48 PM   #7
stealth.pilot
Knight Commander
stealth.pilot's Avatar
Drives: 2014 911 Turbo S
Your exhaust valve needs to be adjusted. It's too loose correctly.
Eisenmann/IND has instructions on how to fix this on Eisenmann exhausts. Its a simple adjustment.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray
      07-01-2013, 02:59 AM   #8
blackjack7779
Drives: M5 F10
on the back.
      07-02-2013, 08:08 PM   #9
blackjack7779
Drives: M5 F10
Where can u find these intructions?
Thx
      07-02-2013, 08:24 PM   #10
stealth.pilot
Knight Commander
Thx
Ask IND-Distribution. I also posted it on a previous thread about the Eisenmann Sport rattle so you could search.
      07-20-2013, 01:22 AM   #11
luigimaster24
luigimaster24's Avatar
Mexico
159
Drives: 2020 X7 M50i & 2021 X6M Comp
Did you get this resolved?
m5post
