BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Mporium BMW
      06-13-2013, 09:03 AM   #1
happos2
Dingleberries
76
Drives: Gray E92 M3
Exclamation 02 Sensors - Replace now?
Maybe I will get some more help in this forum:
MY 03/08 E92 M with pullies / test pipes / air filter / Stage II tune.
I had issues with my Throttle Valve Actuators and got them replaced under warranty (though had to pay a deductible). Now I have some O2 sensor faults (known to be problematic sometimes) so I just want some help deciphering which ones I need to replace. Here are the codes:
27C7 - Lambda sensor trim control AD diagnostic bank 2
2771 - Lambda sensor dynamic diagnostic VKAT bank 1
From my understanding:
VKAT = VOR (before) Cat
NKAT = NACH (after) Cat
bank 2 = drivers side
bank 1 = passenger side
Originally Posted by Sam@Alekshop View Post
2771 - P0133
Information saved in: DME
Fault code: 2771 - P0133
Fault text: Oxygen sensor dynamic diagnosis before catalytic
converter, bank 1
Fault description: O2 Sensor Circuit Slow Response (Bank 1 Sensor
1)
Condition for fault identification
Test condition: Amplitude of oxygen sensor less than diag. value
0.35 (K_LAVK_OBD_DYN_WERT_MAX)
Terminal condition: Engine running - Condition idle or partload
Voltage condition: none
Condition for fault memory entry: none
Action in service:
1. Clear fault memory, oxygen sensor system test
2. Check exhaust system for leaks
3. Replace pre-cat oxygen sensor LSVK B1
Fault effect and breakdown warning: MIL on after engine runs 2x /
possible mild effect on drivability...surge during steady-state
operation
Driver information Warning light: MIL
Service instruction: none
27C7 - P2099
Fault code: 27C7 - P2099
Fault text: Oxygen sensor, adaptation, trim control, bank 2
Fault description: Post Catalyst Fuel Trim System Too Rich (Bank
2)
Test condition: Adaptation value reaches max. limit and hangs in
this position
Condition for fault memory entry: Counter for recognition at
adaptation limit >= (2x) K_LA_TRIM_DIAG_I_AD_MAX_SCHW
Action in service:
1. Check the fuel system and the exhaust system for leaks
2. Check pre-cat and post-cat sensors and replace as indicated
First I should check for leaks, and if that doesn't fix it (which I don't think it will as I had this code when my Throttle Valve actuator went but was replacing that first to see if it cause erroraneous signals), then I should replace both Pre-Cat O2 Sensors. Just want some concurence prior to buying the following O2 sensors:
http://www.amazon.com/Bosch-17039-Ox.../dp/B000JZEXG8
Thanks for the reassurance!
      06-14-2013, 06:59 AM   #2
happos2
Dingleberries
76
Drives: Gray E92 M3
Anybody?
      06-14-2013, 07:22 AM   #3
elm3
///M Fan
elm3's Avatar
Drives: '09 E92 M3 IB/'17 f85 X5M LBB
2017 BMW / X5M  [9.00]
2009 E92 M3  [10.00]
2004 Yamaha R1  [10.00]
If it is throwing those codes, I would replace the O2 sensors. It looks like both banks are faulty. Most likely the pre-cat ones.
'09 E92 ///M3 Interlagos Blue,6MT,Silver Novillo Leather,CF Trim,Premium Package,Technology Package,Cold Weather Package,Premium Sound,19"Wheels,Moonroof-Toy/'17 X5M, Long Beach Blue, Executive Package,Technology Package, Lighting Package, Driver Assist, Full Mughello Red Interior, 21" wheels-Toy/'14 535i with M Sport and 19" wheels-Daily
      06-14-2013, 11:24 AM   #4
happos2
Dingleberries
76
Drives: Gray E92 M3
thanks! I am pretty sure this is what I am going to do!
m3post
