05-18-2013, 10:05 PM | #1 |
SCCA B Street
117
Rep 660
Ordered some 275/30/19 re11s for the front
Test fit next week.
Due to a limited options i am trying a 275 on the front. If it dors not work out, i will use them as rears on a different set of wheels. If they work i am going with a 305 on the rear.
05-19-2013, 11:28 AM | #2 |
Rep 3,070
So if it works you will put different tires on the rear? Wasn't aware RE-11 comes in 305 size.
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake. |
05-19-2013, 02:38 PM | #3 |
SCCA B Street
117
Rep 660
Yes, but they are not listed on tire rack anymore. They were on there a couple of weeks back.
05-21-2013, 05:57 PM | #5 |
SCCA B Street
117
Rep 660
Mark, they test fit tomorrow.
05-21-2013, 07:09 PM | #7 |
SCCA B Street
117
Rep 660
No, the a6 265/35 and the 275/30 re11's look like they will fit according to tirerack.
05-21-2013, 07:14 PM | #8 |
SCCA B Street
117
Rep 660
Re11 10.7 on a 9.5 wheel
A06 10.4 on a 9" wheel So, how much is the move to a 9" wheel on the re11 worth? Does it bring it down to 10.5?
05-22-2013, 09:55 AM | #9 |
SCCA B Street
117
Rep 660
Dropped the wheels off and should know something later today.
05-22-2013, 05:20 PM | #11 |
SCCA B Street
117
Rep 660
They are having a hard time getting the tire on the 9 inch wheel.
Report back tomorrow.
05-22-2013, 08:50 PM | #12 |
Sold: E46 330CI, E90 320dA with 270000km
9
Rep 187
Drives: 1M
could you recommend Michelin PSS 295/30 R19 for the original rims in the back or is the clearance not wide enough??
cheers |
05-22-2013, 08:55 PM | #13 |
Rep 2,898
05-22-2013, 09:28 PM | #14 |
Rep 170
I have the 295/30/19 PSS on a Stock 1M with stock with OEM wheels and they rub over compression bumps and there is some rubbing over bumps if the suspension is loaded... I plan to add camber and expect that to solve the issue, but this weekend we will see how they do at the track... MAHHAHA
2011 1M, Valencia Orange
2002 IT2 Nissan Sentra, Racecar Green Board Member, Western Canada Motorsport Association http://www.wcma.ca/new/ |
05-22-2013, 10:00 PM | #15 |
SCCA B Street
117
Rep 660
You can get a 315 on the stock wheel with a 5mm spacer in the rear.
05-23-2013, 11:15 AM | #16 |
SCCA B Street
117
Rep 660
Still having a hard time getting them on the 9 inch wheel. Hopefully later today.
05-23-2013, 03:29 PM | #17 |
SCCA B Street
117
Rep 660
Day 2 of cant get them on the wheels hmmm,.......
05-23-2013, 07:02 PM | #18 |
SCCA B Street
117
Rep 660
Entering day 3.....
05-24-2013, 07:38 AM | #19 |
Rep 1,358
05-24-2013, 12:05 PM | #20 |
SCCA B Street
117
Rep 660
The tire is on the wheels now but it will be tuesday before the test fit. The tire is almost an inch wider than a 265/35 hoosier so this may not work.
05-24-2013, 06:34 PM | #21 |
9
Rep 187
Drives: 1M
I was hopping for than answer! I just ordered them ystrd....it was about time!!!
