      02-12-2013, 02:29 PM   #1
Scott B
Drives: 1M
Rear Wheel Fitment Question: 18x11" ET18
Would a 18x11" ET18 wheel fit on my 1M properly? I'm assuming that a 295/30 tire on this rim would be too close for comfort, but that a 285/35 configuration would work with no rubbing on a stock suspension.
Can anyone confirm or refute before I drop the cash on non-refundable wheels?
Thanks in advance.
      02-12-2013, 10:08 PM   #2
robertm
Drives: 2020 M2 Comp
I don't know about the width of the wheel in that offset. I can tell you a 295/35 fits with lots of room to spare on the stock rear wheels.
      02-13-2013, 07:05 AM   #3
ozinaldo
ozinaldo's Avatar
Portugal
116
Drives: 1M
On stock wheels? On 19 inches a 295/35 seems to have a 27.1 inch diameter vs stock's 26.3, which is quite taller tire. Any chance you wanted to say 295/30? They should fit easy.
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake.
      02-13-2013, 09:59 AM   #4
bdaddylo
bdaddylo's Avatar
Drives: 2017 F80 M3
I have 275/35 and on stock setup there should be enough space for 295/35.
_______________________
1991 E30 M3/Brilliantrot
2017 F80 M3/AW
      02-13-2013, 10:50 AM   #5
ozinaldo
ozinaldo's Avatar
Portugal
116
Drives: 1M
I see your point; but 275/35 is only 26.6 inch diameter so merely 0.3 taller than the stock 265/35; there is an additional 0.5 inches with the 295/35 on top of your 275/35 set up. I suspect there might not be enough space back there, especially under load with a passenger or two at the rear.
      02-14-2013, 01:18 AM   #6
Scott B
Drives: 1M
Alrighty, so I guess I'll be the guinea pig on this one. Bought the wheels and am mounting 285/30/18s on them tomorrow. Will post my findings here.
      02-14-2013, 06:14 AM   #7
robertm
Right you are. Dam I hate spreading misinformation. Yes, I have 295/30 19s on the rear and they fit without issue. Thanks for the correction!
      02-14-2013, 09:22 AM   #8
bdaddylo
bdaddylo's Avatar
Drives: 2017 F80 M3
When determining clearance you compare the radius and not the diameter. An additional 0.25" is not going to be a problem.
No need to post your finding as 285/30/18 is shorter than the stock tire size. Below is a useful link to compare tire sizes if you don't know how to calculate by hand.
http://www.miata.net/garage/tirecalc.html
2017 F80 M3/AW
      02-14-2013, 10:10 AM   #9
MDORPHN
Drives: AW 1M
FWIW, I'm hoping to fit 295/35-18 BF Goodrich g-Force Rivals on the back of my 1M later this season with 275/35s in front.
Tire Rack is trying to get them to me in time for this year's One Lap of America (May 3-10) but it's a long shot.
The rear tires will be mounted on an Apex ARC-8 wheel that's 18 X 10.5 et 27. Fronts on 18 X10 et 25.
Neil
      02-14-2013, 01:23 PM   #10
M3 Adjuster
Albania
7908
Drives: 1M, X1 M Sport, E46 325ic
Neil
bought time you got some decent (wheel and tire) width up front...
      02-14-2013, 01:28 PM   #11
MDORPHN
Drives: AW 1M
Gotta step up my game -- or, at least, upgrade my hardware -- to defend my One Lap class title!
Neil
      02-15-2013, 01:27 AM   #12
Scott B
Drives: 1M
Update: The 285/30/18 Toyo R888s seem to work fine with the rear wheels on a stock 1M suspension. No rubbing under normal driving conditions. Will report back if there are any issues under heavy cornering conditions.
      02-17-2013, 07:31 PM   #13
M3 Adjuster
Albania
7908
There is plenty of room in the rear.
What did you run up front?
      02-18-2013, 01:14 AM   #14
Scott B
Drives: 1M
R888 255/35/18 on a 9.5 ET22 wheel. Since I don't have camber plates and wanted no chance of rubbing, Joe at Apex suggested I go with these.
On the 11" rim, the rears stick out quite a bit. So much so that I'm a little worried about rubbing the wheel arch under heavy cornering. We'll find out in about 10 hours .
      02-19-2013, 01:34 PM   #15
M3 Adjuster
Albania
7908
very interesting. I sure hope this is a show car or just doing this for looks... I just can't understand increasing the front to rear stagger on this car when it comes to performance... it's just an invitation for terminal understeer.
      02-19-2013, 01:59 PM   #16
Scott B
Drives: 1M
These are my track shoes, and they worked really well yesterday at Laguna. All I was trying to do was run the widest possible tires without rubbing. Since the R888's run a little bigger than non-R-compound tires, I went with 255s up front. I may have been able to get away with 265s, but wanted to play it safe. Maybe next time. The car tended to oversteer on the stock stagger/config, so my theory was that my combo would help balance it out. I was happy with it yesterday. YMMV.
As for the rears, there's no way that I could have done 295s without rubbing on this wheel offset. I can post fitment pics, but it looked like the 285s were going to rub the wheel well lip under full compression. I consider myself really really lucky that there wasn't any rubbing at all yesterday. This pic shows how little room there is left in the rear.
      02-19-2013, 05:58 PM   #17
M3 Adjuster
Albania
7908
SICK photo..
      02-19-2013, 11:06 PM   #18
Scott B
Drives: 1M
Here's the rear fitment
      02-28-2013, 01:21 PM   #19
Scott B
Drives: 1M
From Joe at Apex:
"It's a good thing that we ended up going with the smaller 285/30/18 rear tire because if we went with the 295/30/18 size there would have been rubbing for sure and this is all due to the Volk's much lower wheel offset. You very possibly could have sneaked by with the 265/35/18 front tire but there definitely would have been significant rubbing on the fender liners. Now even with camber plates there is still the possibility of grazing the fender liners but additional negative camber would minimize the grazing. This is a very minor thing though and indents in the liner should eventually wear away to wear it will not be a problem."
      03-01-2013, 12:56 AM   #20
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Thanks in advance.
295 fits if you have the right offset and assuming the tire does not run wide.
Here is 295/30 Hoosier R6 on OE rears.
http://www.1addicts.com/forums/showp...0&postcount=99
1addicts
