      02-01-2013, 08:00 AM   #1
ace11
ace11's Avatar
Drives: 1M - A1 quattro - S3
tire/wheel fitment
hello to everyone
was just wondering what the bright heads in this forum think of the following:
i'm about to purchase a set of adv5.0 in 9,5x19 and 11x19 for my 1m. i also want to install a bilstein b16 pss10. now where i'm not 100% sure yet is on the dimensions of the tires so that there will def not be any rubbing once the car is nice an low.
i was thinking of:
245/35s at the front, and 275/30s at the back.
what are your thoughts on this?
      02-01-2013, 08:32 AM   #2
MDORPHN
Drives: AW 1M
Originally Posted by ace11 View Post
hello to everyone
i was thinking of:
With the proper offsets, it should work.
You'd definitely want to go at least 275 in back with a 11" wide wheel.
Neil
      02-03-2013, 10:03 AM   #3
Rhys Jones
Drives: red 2008 135
Why waste those wheel widths on skinny rubber.265/30-19 front and 295/30-19 rear will work even with stock wheels
      02-03-2013, 10:11 AM   #4
MDORPHN
Drives: AW 1M
While it could be mounted, the width of the stock rear wheel is not optimal for a 295 tire.
EDIT: Just checked and the stock rear wheel is 10" wide -- which is enough for a 295 tire (although 10.5 would be better)
Neil
      02-03-2013, 02:50 PM   #5
ozinaldo
ozinaldo's Avatar
Portugal
116
Drives: 1M
Yes, even 275/30 19 should work at the front without any adjustments.
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake.
      02-03-2013, 05:49 PM   #6
ace11
ace11's Avatar
thanks for the info...
im only worried that if i put on 275s and 295s i wont be able to lower the car anymore without rubbing issues...
any experiences?
      02-04-2013, 08:52 PM   #7
Em/1
Em/1's Avatar
Drives: 2011 1M VO
2019 VW GTI SE  [0.00]
2020 Tesla M3P  [0.00]
2011 BMW 1M  [0.00]
hello to everyone
i was thinking of:
Lot of good suspension options out there that you might consider before jumping into the Bilsteins. JRZ, Ohlins, KW...
      02-05-2013, 01:28 PM   #8
ace11
ace11's Avatar
thanks - are you sure that öhlins make suspension kits for the 1m?
anyway, that doesnt really change my question.
1addicts
