      01-24-2013, 05:40 PM   #1
timbo_3101
Australia
18
Drives: Slow
Pilot Sport Cup +
Have taken delivery of (F245/R265) PSCup+ for my stock 1M.
Any experience or advice would be most welcome including optimum pressures on track.
Thanks,
Timbo
      01-24-2013, 09:09 PM   #2
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
What are the full size specs? (profile and diameter)
      01-24-2013, 10:28 PM   #3
timbo_3101
Australia
18
Drives: Slow
Specs are stock ie F245/35/19, R265/35/19.
      01-27-2013, 12:26 PM   #4
bdaddylo
bdaddylo's Avatar
Drives: 2017 F80 M3
Hope you have camber plates.
_______________________
1991 E30 M3/Brilliantrot
2017 F80 M3/AW
      01-27-2013, 12:44 PM   #5
MDORPHN
Drives: AW 1M
+1
To get decent life out of them, you'll need to run at least 3 degrees camber in front.
Neil
      01-27-2013, 01:17 PM   #6
nachob
Drives: 2004 330i ZHP, 2022 Cayman T
That is the exact setup I had in my 1M. Tire pressures made a big difference and I realized I started too high. Here is the recommended pressures direct from Michelin's documentation on the Sport Cup. I found them to be very good:
The complete PDF of this document is located at:
http://www.tirerack.com/tires/tirete...nd_Feeding.pdf
This is really good info, make sure you read it as it comes from the people that built and race these.
Below is an excerpt from page 14:
ROAD RACING (psi)
Front: 25 cold; 32 hot
Rear: 28 cold; 36 hot
Note: If your road-racing hot pressures are too high, start
with slightly lower cold pressures.
AUTOCROSS (slalom)
32–36 psi hot (front/rear)
Note: Though autocross hot target pressures are the same
as those for road racing, you may need to start at a higher
cold inflation pressure to compensate for the lower pressure
gains in autocross racing.
ROAD
OE pressures (Consult your vehicle Owner’s Manual.)
RAIN
For both autocross and road racing, you may need to
increase tire pressure 6 – 10 psi over cold, dry pressures.
Vehicle and driving style are important factors, so some
testing may be necessary.
      01-27-2013, 10:20 PM   #7
timbo_3101
Australia
18
Drives: Slow
Thanks for the advice. I ran according to the recommendations and it did provide improved grip and confidence in braking-cornering than stock PS2.
1addicts
