      01-04-2013, 12:52 AM   #1
domani 1m
Drives: 2011 bmw 1m
M3 coilovers fit the 1m!?!?
Will m3 coilovers fit my 1m ?
      01-04-2013, 01:05 AM   #2
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
I don't know. But I do know of a German friend who has transplanted the M3 edc shocks to his 1M! He is a car coding genius to get the entire system to work!!
      01-04-2013, 01:35 AM   #3
domani 1m
Drives: 2011 bmw 1m
My buddy has h&r coils off him e92 m3 it's non edc so I'm hoping it works
      01-04-2013, 03:31 AM   #4
eeghie
Kind of a big deal
300
Drives: an 1M not often enough
I need to talk to your friend!?
As it shows from WDS, 1 series electric platform was prepared for EDC (or perhaps because it was just copied form 3 series), but commercially it never made it. KW DDC being readily available aftermarket solution, but an existing implementation of the BMW OEM alternative is too good to not look into.
      01-04-2013, 03:43 AM   #5
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
He had a lot of trouble getting the M3 EDC (electronic damping control) to work properly. At first he only got the shocks to work in the "on" and "off" settings. ie too soft or full hard. Now he all three settings.
He had trouble with the 1M steering unit since it was different from the M3 one. He told me he ended up using a com box from a X5M that has a similar problem with all the electronic boxes talking to each other. Once he had all the "right" hardware... he was able to do the rest with simple "coding".
Dack
      01-04-2013, 05:34 AM   #6
eeghie
Kind of a big deal
300
Mechanically yes, which means you'll be able to fit all the parts. The M3 front competition package dampers are in fact equal to the 1M dampers. However M engineers vary the spring rates with every 50 Kg of load. So depending on your cars (corner) weight, you will likely change the suspension behavior.
Assuming the weight of the M3 being higher than the 1M: when using M3 intended springs/coilovers, your 1M suspension will at least feel more firm that it would on the M3.
      01-04-2013, 10:29 AM   #7
domani 1m
Drives: 2011 bmw 1m
Bump
      01-04-2013, 12:23 PM   #8
EINSER M
EINSER M's Avatar
Drives: BMW i3 rex
+1
      01-07-2013, 10:44 AM   #9
Em/1
Em/1's Avatar
Drives: 2011 1M VO
2019 VW GTI SE  [0.00]
2020 Tesla M3P  [0.00]
2011 BMW 1M  [0.00]
And have a relatively higher static ride height.
      01-17-2013, 02:54 PM   #10
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Sorry for this tease-r pic of my buddy's 1M with EDC transplanted. Sorry I can't give you guys much info on this EDC (shock)project - its kind of top secret. As you can see EDC can be transplanted onto a 1M!
1addicts
