08-10-2007, 01:28 AM | #1 |
Free taco with stolen base
30
Rep 639
Another 900+whp Evo
Yeah, that's right another 900+whp Evo!
This one was just finished up very recently, pretty impressive. http://forums.evolutionm.net/showthread.php?t=288561 More info on the turbo kit; http://forums.evolutionm.net/showthread.php?t=284469 Maybe the 335i will get here someday..
lllM |
08-10-2007, 03:18 AM | #6 |
Rep 5,497
If the N54 ever reaches that level, good luck with traction. Remember an Evo is AWD so they will never have the problems we do.
2007 E92 Montego Blue 335i
08-10-2007, 04:12 AM | #7 |
e92
Rep 391
08-10-2007, 06:02 AM | #8 |
Rep 5,497
08-10-2007, 06:52 AM | #9 |
Rep 17,447
i don't know...Mitsu motors are pretty strong out of the box. At least their bottom end is. BMW has two more cylinders. I think it can be done in time. Give it a few years.
AA has a e46 M3 turbo that pushes out 1000hp. |
08-10-2007, 01:50 PM | #10 |
Rep 1,938
Have you ever seen an evo with more then 800hp at the 1/4 mile? Even on slicks that thing jumps all over he place before actually getting some grip. It looks like it is much harder to control then a high powered RWD car off the line.
08-11-2007, 01:10 AM | #11 |
Rep 3,200
Under 200hp at 5,000 RPM, nice. Turbo lag much?
328xi Coupe, Montego Blue on Black with Alum, Step, Sport, Premium, CA, PDC, Cold Weather (Damn Pennsylvania winters)
Current Mods: Heavy right foot - Planned Mods: Lightweight right foot |
08-11-2007, 02:22 AM | #13 |
30
Rep 639
Well sure, there's not much you can do about that when you stick a GT42R on a 2.0L motor. Fortunately shifting at 9500rpm you'll never drop out of boost.
IMO, you ruin what the Evo is when you put a turbo that big on it. Evo's are supposed to be fast in a straight line, but also brake and turn. Once you go with a turbo this big, it becomes straight line only. I just think it's amazing how strong the motors are. The stock block will handle 550whp all day long if you keep the revs down. The Evo trans is just as impressive. All these 900-1000whp Evo's are on the stock trans. They are rebuilt with tighter tolerances, but that's about it. Stock gears, stock synchros... This car does have a $4000+ clutch on it though.. Anyway, just wanted to share the latest monster Evo with you guys!
lllM |
08-31-2007, 09:21 PM | #15 |
30
Rep 639
Just wanted to update this a little bit.
The car was recently tuned, as well as changing the hotside and cams. Result? Maxed out the dyno at 1000whp... Below is the dyno sheet and video of the pulls, you can see it goes flat for a few hundred rpms. I would guess it's pushing 1015whp - 1020whp or so.. Should get into the 8's without too much trouble. The video says this is a world record. Most of the other 1000+whp Evo's are running a 2.1L or 2.3L, this one is still on the 2.0L. Oh, and ETS, is looking to develop 335i parts.. Video http://s92.photobucket.com/albums/l8...ORD1000WHP.flv Dyno Sheet
lllM |
08-31-2007, 09:31 PM | #16 |
Commander in Chief
38
Rep 1,034
Wow
What was that flame that shot out of the front of the car at the end of the dyno run?
2008 BMW 535i Space Gray, Black Leather, Dark Bamboo Trim| Sport Automatic with Paddles | Sport Package
2008 BMW M5 (gone, but not forgotten) Space Gray, Silverstone Merino Leather, Madeira Walnut Wood Trim | 7speed SMG | All options Mods: Corsa Exhaust | RPI Ram Air Intake | H&R Sport Springs | Rogue Engineering 12mm spacers |
09-01-2007, 10:19 AM | #17 | |
D to the X to the B!
352
Rep 2,106
09-01-2007, 10:13 PM | #18 |
Rep 1,719
Posts Drives: modded e92 335i coupe Join Date: Jun 2007
insane evo. big props to mitsu
e92 335i jet black, coral red, aluminum, sport, step, paddles, heated seats, pdc, bmw aluminum pedals, oem aero kit front lip, 19' miro type 366 hamann race edition reps, H&R sport springs, 15% tints, vorsteiner rear deck spoiler, custom front pdc
"The only cars that should be yellow are taxi cabs and school busses." |
