      10-16-2012, 01:59 PM   #1
mrspin
mrspin's Avatar
Drives: .
Tyre Dilemma - PS2 or PSS on front only
      10-16-2012, 02:03 PM   #2
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
I would buy two new PSS for the front. generally speaking by the time your front tires are worn out you will have replaced your rear tires at least twice! Maybe two and half times!
      10-16-2012, 02:38 PM   #3
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Originally Posted by sladeywadey View Post
hmm thanks. Will the stickier tyres on the front cause more oversteer?
I would think so, at least on dry roads at the limit. Or think if them causing less understeer!
      10-16-2012, 03:07 PM   #4
mlhj83
Scythe-Meister
mlhj83's Avatar
Drives: '11 E92 M3 ZCP | F80 M3 CS
PM'ed
      10-16-2012, 03:39 PM   #5
doublevanosrc
Loves his G20
doublevanosrc's Avatar
265
Drives: 2020 330ix M sport
2013 BMW  [0.00]
I would stick with PS2s, I think they're better than the PSS.
2020 330ix-Msport
Past-
2013 135i
2011 135i
      10-16-2012, 05:04 PM   #6
Wild Bill
Old Guy
Wild Bill's Avatar
Drives: JCW Clubman, 1M, 2007 Vette
2007 Corvette  [0.00]
2011 1M Coupe  [10.00]
2010 MINI JCW Clubman  [10.00]
Based on all the other glowing reports on the PSS model, I would be interested in hearing your criteria for deciding the PS2 tires are better.
Bill
      10-16-2012, 05:15 PM   #7
Vrumpkin
Seymour J. Vrumpkin
Vrumpkin's Avatar
15
Drives: BMW 1M
Bill
+1 on what Bill said, only rave reviews for PSS in all my findings and talking with other drivers.
Thinking I might go with PSS just for the rears if and when the go. Let the front PS2s run a while longer and replace with PSS when they go, is that too simple
      10-17-2012, 09:22 AM   #8
ChrisBuer
ChrisBuer's Avatar
This is completely my personal opinion, but I don't think that mixing tyres is a good idea. When my rears are cooked, I'll be replacing all four corners with PSS!
      10-17-2012, 10:11 AM   #9
ozinaldo
ozinaldo's Avatar
Portugal
116
Drives: 1M
I have to say that PSS and PS2 are pretty different tyres in terms of grip and handling behaviour so changing all four should be the ideal thing to start with. If I would be forced to change just 2 in my car, then I would put PSS at the rear since PS2 on the front are not that bad, at least on dry weather conditions. On the other hand, traction capacity is vastly different between the two. As a result, your plan of PS2 rear and PSS front does not sound very well to my ears.
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake.
      10-17-2012, 06:57 PM   #10
bdaddylo
bdaddylo's Avatar
Drives: 2017 F80 M3
thanks guys, ultimately I didn't want to upset the handling balance.
I've opted for a replacement PS2 on the front and like others, I will replace all 4 for PSS when the rears are gone
These PSS are certainly not cheap though!
In the States, the PSS are cheaper than the PS2.
_______________________
1991 E30 M3/Brilliantrot
2017 F80 M3/AW
1addicts
