      10-09-2012, 06:54 AM   #1
37&TenCents
37&TenCents's Avatar
Drives: le mans 130i, e30 no more :(
E87 Wheel Offsets / fitment.
Hi all,
I'm looking at getting some wheels for my 130i and I'd just like to see if anyone knows if there would be any clearance/rubbing issues...
My current set up:
Suspension: stock M-sport
Wheels: BMW Style 208
7.5x18” et49 205/45 18 (Front)
8.0x18” et49 225/40 18 (Rear)
I'm thinking of getting some new wheels:
VMR VB3
8.5x18" et40 225/40 18 (Front)
9.5x18" et45 255/35 18 (Rear)
I am pretty sure these wheels & tyres will fit on the coupes E82/E88 alright, but I'm not 100% certain if the hatches E81/E87 will have any rubbing or not, particularly in the rear? Might I need to go with a 245/35 rear tyre?
Does anyone have anything to add? Any experiences?
Thanks!
Originally Posted by Blauweisser View Post
I know that progress has demanded the new blown 4's, but for me the N52 is the final, ultimate expression of the BMW NA straight 6.
      10-10-2012, 11:07 AM   #2
matteo1er
Drives: bmw 116i e87
The width and offset of your wheels are correct, but it is better if you mount tires 215/40 and 245/35!
I mount on my e87 8x18 et35 and 9x18 et33, rolled rear fenders and I don't have rubbing problems!
Maybe you need coilovers.....
      10-22-2012, 03:11 AM   #3
ealoken
ealoken's Avatar
Drives: E97 116D LCI
8x18" et 38
215/40-18 Falken ZE912 tires
i have some rubbing issue when doing some track use.
The car is lowered by H&R 60-40 mm
E87 116d Lci
9,33 BTG Nürburgring
E28 S50b32 +++
      04-01-2013, 10:05 AM   #4
vaskesh
Drives: BMW 120i 2008
      04-19-2013, 08:07 PM   #5
forresr
Drives: 2005 BMW 118i
i have an 05 118i, and looking to get black wheels for it. what offset do you think would suit best? im looking for that perfect fitment where, when lowered slightly, the guards hug the tyres. any advice!?
      04-24-2013, 05:31 PM   #6
37&TenCents
The offset will depend on the width of the wheel you want. Do you know what size wheels you want?
      04-26-2013, 05:39 PM   #7
dailydrifter99
Drives: E87 3dr msport
so what offset is right for the different sizes?
i have to order new wheels now but im still not sure about what to order.
after looking at a billion pictures, i think wide 18"s look better than 19.
so 18x8,5 et38-42 and 18x9,5 et 42-45. will this fit without mods?
i want to roll fenders to get a wider lip on the wheels, has anyone seen excactly how far you can go on the hatch? its supposed to support wider wheels in the back than the coupe.
im looking at Rota wheels now, since i cant find the correct size and offset in ok looking LM replicas.
does anyone know if this will fit:
ROTA MXR 18" Width 10" ET 45 Stud Pattern 5x120
ROTA MXR 18" Width 9" ET 40 Stud Pattern 5x120
      04-27-2013, 11:12 AM   #8
37&TenCents
The 9" will fit the front, but I doubt the 10" will fit at the rear. The offset is too low - the wheel will poke out beyond the rear fender.
The hatch does have a wider rear, you can fit maybe ~5mm lower offset than the coupe.
      04-27-2013, 04:23 PM   #9
dailydrifter99
you dont think its possible, even with tire stretching? and maybe combine with fender rolling? im looking at coilovers also that can help me with the camber. but if i can fit wide enough wheels without mods to the car id be happy
edit: do you know what et i need for 9,5" rears?
      04-28-2013, 10:56 AM   #10
37&TenCents
I'd think with stretching, fender rolling and extra camber the 10's could possibly work.
I know 9.5's et45 will fit without much trouble, but 10J et45 will sit 6 or 7 mm further out and I think thats just a bit too much, but if you're going to stretch the tyre, roll your fenders and add camber then it might (just) fit.
      04-28-2013, 01:59 PM   #11
maupineda
Drives: E86 Z4MC
8.0 and ET35 is right in the limit, I needed camber to stop rubbing and I am pretty sure that if I track the car it will rub.
The best offset would be 40 with 8.0in fronts, this will allow even 235 tires or 225 square tires.
At 8.5in width you should go 40 MAX! Wheels will look flush but you will need to use narrower tires which loses the point of going to a wider wheel.
      04-29-2013, 08:36 PM   #12
dailydrifter99
40 max? the higher offset, the more the wheel will stick out as i understand it? shouldnt you write minimum 40?
      04-29-2013, 09:31 PM   #13
maupineda
Drives: E86 Z4MC
Is the other way around. The lower The number the outer the wheels goes.
      05-02-2013, 07:56 AM   #14
dailydrifter99
sorry i explained it wrong, ill try again:
40 max? the more the "center" of the weel will stick out (as in where you put the bolts) not the lip. therefore i wonder why ha said 40 max, as more et should be more friendly towards the wheel fitment of the e87? it should be minimum ET40 imo?
      06-07-2013, 10:30 PM   #15
bradsm87
Australia
596
Drives: F25 LCI xDrive30d
I'd go 8.5 wide with 225's all round on a 130i. I doubt 255's really make a difference other than being heavier and slower with an engine that makes 315nm torque. I plan to go 18x8.5 +40 up front with M3 lower arms and 18x8.5 +35 rear and a Quaife LSD to assist traction. My main reason for posting is so I can get my first post and start a thread haha).
      02-28-2015, 04:47 AM   #16
nickobmwe87
Drives: e87
2009 bmw e87  [0.00]
i want to buy some new wheels.bmw 116i e87 stock height and stock everything.
ive found some new wheels
8x18 et 35 all around
will it rub?
      04-22-2016, 04:10 AM   #17
Hg
Drives: e87 130i M
seems I posted the below to wrong place (coupé forum instead)
copying to here too
I spent 3 hrs on it last week
e92 m3 style 260m rims on e87 130i M
the result is a failure without special measures
it looks damn sexy though, I will try fitting them with these "special measures" including machining the hub center, cambers, and flaring the arches maybe... will see...
next
I will try sequentially
1 - machining the hub center by 5mm
2 - Fitting 235 or even 225 mm tires instead of 255 at the back
3 - Camber adjustment
4 - Flaring the arches[/list]
Dont want no coil over or spring...
will keep you posted
      08-30-2016, 12:08 PM   #18
diigodr
Brazil
Drives: 335i
Originally Posted by ealoken View Post
8x18" et 38
I love ur wheels hahaha I want change mine oem
      11-18-2016, 09:24 AM   #19
Hg
Drives: e87 130i M
just fitted 216s from e90 with aggressive offset (34-37)
no rubbing so far but front seems likely on the track
eagle eyed ones of you wont miss the 370mm F30 Performance brakes on the front... rears are also on the way
1addicts
