09-28-2012, 12:24 PM | #1 |
Rep 388
Oil Changes: DIY or dealer?
I surpassed 10k miles the other day and it's time for another oil change. My question is, should I do it myself or have the dealer do it?
The dealer quoted me a bit over $100 to do the change with BMW Performance 5W-30 oil. For $105 I can get Motul 8100 X-cess 5W-40 oil, BMW filter, and the filter cap tool from Turner Motorsports. So for the same price I get a much better oil in my car but at the expense of not having bonafide service records. What do you all do? Service records or better oil in the motor? PS: I'd be doing the oil change in my father's garage which has a 4-post lift, tools, oil drain, etc. so its a 1/10 in terms of difficulty. |
09-28-2012, 12:39 PM | #2 |
Rep 1,479
Drives: 2017 F80 M3
You should have changed it at 8,000 miles. If you have all the equipment to change it yourself then go for it. For one, you'll need to buy an oil filter housing tool and then you need a way to get under your 1M. The front bumper is too low to drive up most ramps, so you will need a floor jack to lift the car and then place the ramps under the tires.
If you decide to use an indy shop or the dealership, remind them not to reset the oil service meter.
_______________________
1991 E30 M3/Brilliantrot 2017 F80 M3/AW |
09-28-2012, 12:56 PM | #4 |
Rep 1,479
Drives: 2017 F80 M3
Just keep the receipt for the oil and filter as proof that you serviced it yourself. I guess I should keep my receipts next time.
09-28-2012, 01:04 PM | #5 |
Rep 140
I personally despise dealers/service but for a car under warranty I would have it serviced for that record. Even though I am sure you would win if it came up, I would not want the headache of the dealership arguing you did it improperly and deny the warranty.
09-28-2012, 02:15 PM | #6 | |
Rep 795
Plus...the oil changes are free if you bought it new. I just had my 1 year oil change yesterday. |
09-28-2012, 04:18 PM | #7 |
Rep 360
Drives: 1M; E90 M3 ZCP; M4 GTS
I rely on the dealer for the aforementioned reasons of being free and having service records. My 1M just needs an annual change for the low miles I drive. After warranty, I would probably do it myself because I have nice facilities to do so....climate controlled garage, lift, etc.
For cars like our X3 that accrues more miles, I do incremental ones on my own between what BMW covers, because I personally believe the intervals are too lengthy (also did a break in oil change since BMW won't cover a car like that....but it doesn't negate the need IMO)
-kskpsu
09-28-2012, 04:45 PM | #8 | ||
Rep 1,035
09-28-2012, 06:04 PM | #9 |
European Editor
10616
Rep 22,992
DIY and keep the receipts for the oil and filter - just in case of any warranty problems down the road.
Not only will you have changed the oil correctly, but your car will not be damage in the process. PLUS... you will KNOW the job was done right. The DIY oil change kits that Tischer and United offer are priced very low. The best oil is fresh oil. Here is a very good DIY step by step thread. Even though Jim has a 128i... its basically the same. I posted my 135i oil change pics on page two. First Oil Change on my 128i Convertible http://www.1addicts.com/forums/showt...hange+diy+135i
09-28-2012, 10:59 PM | #11 |
bimmerphile, technogeek
1000
Rep 3,785
Drives: 2012 E82 6MT Sport
Just changed my oil today after the break-in period, about 1500 miles... Took all of 30 minutes and only because it was the first time for this car and I was being methodical.
The trickiest part was driving the car up on the ramps.
09-29-2012, 06:23 AM | #13 |
European Editor
10616
Rep 22,992
Noop! The trickiest part is stuffing some rags inside the belly pan or using a splash shield(my new prefered method) to divert the oil from getting inside the belly pan. I always leave the oil cap on and the oil filter sealed when draining the oil. Otherwise it will really shoot up inside the belly pan. Ask me how I know!
PS: I don't use ramps... I just use a big(2 ton) floor jack to life up the car with jack stands.
09-29-2012, 06:28 AM | #14 |
SCCA B Street
117
Rep 660
If it only 100 bucks take it the dealer. The oil and filter could be in the $60 to $70 range alone.
09-29-2012, 09:21 AM | #15 | |
Rep 2,819
Drives: e82 1M, f87 M2cs
09-29-2012, 10:08 AM | #16 | ||
1000
Rep 3,785
A little oil splashed on the belly pan when I initially removed the plug, but that was easily cleaned up. Quote:
One other thing: I noticed that the drain plug was rather short, about 1/2-inch long... My E36's drain plug was easily 1-inch long, if not a little more.
09-29-2012, 12:10 PM | #17 | |
European Editor
10616
Rep 22,992
I replaced my OE drain plug with a magnetic one from UUC. It has a very strong magnet on it and it really grabs lot of little bits of metal floating around the oil. I always change my oil every 6K miles or even less. And for my first three oil changes after using this UUC magnet it was really grabbing lots of metallic particles. Have a look for yourself! After being installed for 5K miles(I think?)...
09-29-2012, 12:16 PM | #18 | |
1000
Rep 3,785
09-29-2012, 12:29 PM | #19 | |
European Editor
10616
Rep 22,992
No, not on a 1M. But I have a N54, so its basically the same motor there. (at least as far as oil changes are concerned). Both hold the same amount of oil. When I change my oil... I use a suction pump/tool to remove the old oil from the oil filter housing. It holds about ~200ml to 300ml of oil. I then add some NEW oil before installing a new filter. But don't add too much other wise your new filter won't fit in there! lol The problem with the electronic dipstick is it will register full with 6L or 6.5L of oil. It is not really that accurate. PLUS... I have noticed that when you only add say 6L (during an oil change) when you start up the engine and drive a short distance... it might read "full", but after you drive for say 30 to 60 minutes... it will read low. I always believe the electronic dip stick (more) when the engine is fully warmed up and hot. Say after a long drive of 60 minutes. Also... when you do lots of short trips with the car... and the oil has lots of water/condensation in it(and unburnt gasoline!) the dipstick can read off. Here is a interesting pdf on how the dipstick works. Be sure to read page five of this pdf about condensation and how it effects the oil level readings.. BMW_oil_condition_sensor.pdf
09-29-2012, 04:33 PM | #20 |
1000
Rep 3,785
I just use an old turkey baster.
09-29-2012, 05:36 PM | #21 | |
Rep 2,819
09-29-2012, 07:27 PM | #22 | |
Rep 13,139
Also indicated in the manual: "Checking oil levelFor anyone's convenience: below are pages 217-219 of the "BMW 128i/135i Owner's Manual 2012" (USA) (which was supplied with the 1M, together with the "BMW 1M Supplementary Owner's Manual"). For the complete manual (as well as other manuals and basic info), see the "BMW 1M Manual | Catalogue | Presskit | Pricelist" sticky (http://www.1addicts.com/forums/showp...82&postcount=1). I will post this three page manual excerpt (128i/135i) also in the "Correct 1M Fluids List" sticky.
///M is art ↔ Artemis
