ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Track / Autocross / Dragstrip / Driving Techniques
  TireRack
      09-02-2012, 02:53 PM   #1
pal
pal's Avatar
433
Drives: Z4 M Coupe
Slightly odd pad wear ...
I am running StopTech 4 piston brakes all around. Just pulled off the front Hawk DTC-60 pads that were worn past halfway and noticed the the driver side outside pad was more worn than the inside. Passenger side was about even inside/out.
Any thoughts on why?
My guess is that most tracks I run are clockwise and hence trail braking into right handers puts more wear on the outside. I also tend to tap the brake pedal coming out of esses to compensate for knockback esp as pass start to wear. Does this make any sense?
      09-02-2012, 03:06 PM   #2
Beedub
Drives: 2007 Z4 M roadster vt2-500
im not to sure pal, my AP bbk setup shows pretty even pad wear, did you take some pics??
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com
      09-02-2012, 04:17 PM   #3
pal
pal's Avatar
433
Drives: Z4 M Coupe
Here is a picture of the pads. Nothing unusual from a braking perspective - car stops well, no pulling one side or the other, consistent pedal feel.
Just curious if there is anything going on here?
PS. I dropped a note to StopTech with this picture as well to see what they come back with.
      09-04-2012, 02:46 PM   #4
pal
pal's Avatar
433
Drives: Z4 M Coupe
Got back a response from StopTech that validates my thinking-
There appears to be radial taper wear on the pads that could be indicative of pad knockback
They dont think anything is wrong with the brakes and is a function of clockwise tracks and knockback. This would explain why only the driver side outer pad sees it most. Their recommendation is a race hub that is stiffer or just get hun serviced when I am ready.
      09-04-2012, 07:21 PM   #5
Barryb97
Drives: 2006 M coupe
A bit of newbee to track scene. Knockback is what?
CDV delete, clutch stop, BMW pedals, Strongstrut bar, CF rad & coil cover, M3 reps, roundel under hood, Intravee II, air bag sticker delete, first aid storage, painted reflectors, headlight washer disable, Skyer CF front lip, Short shift kit, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings, TC Kline DA coilovers, PB big brake kit, Skyer CF rear spoiler and diffuser, oil pressure and water temp guages.
      09-04-2012, 07:38 PM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
flex in the stub axle due to cornering loads.
usually when running dedicated track rubber & stiff suspension setups.
The flex causes the rotor to tilt slightly pushing (knocking) the pads back.
You then have to tap the brakes to bring them back to the rotor face.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      09-05-2012, 12:41 PM   #7
Barryb97
Got it. Thanks
zpost
