      08-04-2012, 09:59 PM   #1
terivera
track Junkie
terivera's Avatar
Drives: 2011 1 Series M coupe AW
How Much Tire???
I am using 275X35X18 NT01s on 10"Apexes with ground control camber plates.
Car also has Dinan upgrade. REALLY tail happy and hard to drive full tilt. Considering going to stagger with larger rears. How much tire can I stuff in the rear on these wheels? Any suggestions?
      08-04-2012, 10:24 PM   #2
int2str
int2str's Avatar
Germany
80
Drives: 2008 135i
If 275's NT01s are tail happy, your tire pressure/alignment/suspension sucks or your throttle control needs help.
Sorry to be so blunt, but I really doubt that more tire would help you.
      08-05-2012, 02:45 PM   #3
terivera
track Junkie
terivera's Avatar
Tire temps are 39 hot, stock suspension with camber plates, and I probably have 1000+ laps at Putnam. Aligmment and toe are fine. running same lap times as previous 135??? back end is stepping out under acceleration only. thought stagger might help. by the way blunt is fine I am not a newbie.
      08-05-2012, 02:46 PM   #4
terivera
track Junkie
terivera's Avatar
maybe less in the front?
      08-05-2012, 06:35 PM   #5
Jet Mech
Jet Mech's Avatar
66
Drives: 2011 1M Coupe VO
Eddie, i will be going to VIR at the end of August and im running Hankook R-S3 shaved in 265/35/18 front and 285/35/18 back on Apex wheels. I dont have any suspension mods but do have a few other upgrades in the power department. I will let you know how it works out after i get back.
Not sure the max size you can run in back but it looks like there is still some room back there to go a little wider. Maybe though with suspension mods like yours you might be limited.
Eric
2024 X3 M40i
2011 1M Coupe VO (Sold)
2015 MB GLK 250 Blutec Deez (Sold)
2001 S54 M Coupe (Sold)
1998 M3/4 (Sold)
      08-09-2012, 05:16 PM   #6
terivera
track Junkie
terivera's Avatar
Originally Posted by seaqueen View Post
I think your better guide is your mechanic.
Sorry Seaqueen, My Mechanic does not drive a 1M or do track events and there is a separate area for ADVERTISING
      08-09-2012, 05:19 PM   #7
terivera
track Junkie
terivera's Avatar
Eric
Thanks Eric, Do you have my cell? and are you going to Octoberfest?
      08-09-2012, 06:38 PM   #8
Jet Mech
Jet Mech's Avatar
66
Yes, i have your number. I stopped in a few weeks ago but it was your day off. I cant get anymore time off for the rest of the year so VIR will be it for me., i would have loved to go to Octoberfest
2024 X3 M40i
1998 M3/4 (Sold)
      08-10-2012, 01:43 AM   #9
4thM3
4thM3's Avatar
Drives: 2020 M2 Comp. Alp. White
I have Arc-8s 9.5x18 front and 10.5x18 rears with Toyo R-888 265/35 front and 285/30 rear. All stock suspension (waiting to decide whose camber plates i want to get). Just did about two hours at Infineon (now Sonoma Raceway) and the car was incredibly neutral. Abrupt throttle could induce the tails to come out a bit but never unpredictably or excessively. First time for the car on track (had 3-M3s e30, 36 & 46 + a Jcws MINI previously). I love the car...and the staggered setup.
By the way, The Toyos are extremely wide for their numerical width. Did a side by side comparison with some others in the same size and they are definitely bigger. No clearance problems and Arc says I could have gone to 295 but I didn't want too much stagger.
      08-10-2012, 07:14 PM   #10
JSAN
Drives: BMW 1M
Will 265/35/19 fit on the front without rubbing or should I go 265/30/19.
Will 305/30/19 fit in the back with kw clubsports and lowered?
      08-10-2012, 07:55 PM   #11
terivera
track Junkie
terivera's Avatar
I left, I am now at Bluegrass
      08-10-2012, 10:24 PM   #12
///1M
Drives: On a good day, AW 1M coupe
Any rubbing at all?
Any pics?
      08-10-2012, 10:29 PM   #13
MDORPHN
Drives: AW 1M
Originally Posted by ///1M View Post
Any rubbing at all?
Any pics?
I'm running same size R888s on my slightly lowered 1M and have no rubbing.
Neil
      08-11-2012, 02:13 AM   #14
4thM3
4thM3's Avatar
No rubbing at all. I'll try to upload some pics but don't have any quality shots yet. Car is supposed to get photos take sometime soon.
      08-12-2012, 03:11 PM   #15
tunedone
Auto Enthusiast
Drives: 2011 1M AW
I am running the 10 inch Apex wheels squared with Nitto Nto1's 275/35/18 and GC Camber plates, however, I put JRZ RS1 suspension on at the same time. I am running 2.5 camber front and 2.0 rear. I also have the Dinan Stage 2 ecu tune and maddad mid pipe. I am not having the stepping out problem in the rear unless I am choosing to by mashing the accelerator.
      08-13-2012, 01:49 AM   #16
4thM3
4thM3's Avatar
Don't want to side track the discussion but really anxious to hear how the DINAN Stage 2 and Maddad mid pipe are working for you? I have the Maddad (love it) and thinking about going with the DINAN. How are power and lag?
      08-16-2012, 07:54 PM   #17
mattm
mattm's Avatar
Drives:
In the rear, I get 315/30-19 Hoosier Racing Tire on my 1M with a more or less stock set up using KW V3s. OEM sized wheel (10"x19") with 6mm offset.
Matt Murray
I am perfectly capable of learning from my mistakes. I will surely learn a great deal today.
      08-16-2012, 08:20 PM   #18
tunedone
Auto Enthusiast
Drives: 2011 1M AW
I dont have an issue with power lag with the Dinan. The maddad really allows the torque at the bottom to come on strong and pulls stronger higher in the revs that oem mid pipe. I am getting the Dinan muffler in two weeks when it comes out.
      08-16-2012, 11:10 PM   #19
4thM3
4thM3's Avatar
I've been waiting for their cold air intake to come out. Keeps getting delayed.
      08-17-2012, 01:36 PM   #20
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Driving skills and habits aside check your rear toe. We like at least 1/8" toe in but some cars use up to 1/4" toe in without ill affects to tire wear.
      08-18-2012, 12:45 AM   #21
M3 Adjuster
Albania
7906
Drives: 1M, X1 M Sport, E46 325ic
do you have the camber plates maxed? What camber? Ive noticed the rear end is definitely a little quicker to come around with mine at -2.5. I'm learning to use a little less steering input. I don't find there to be an issue with acceleration at all however.
I have a square setup with rs3 currently, but have run 275-35/18 all around previously. ( grand am continental take offs. ).
      09-07-2012, 08:32 PM   #22
terivera
track Junkie
terivera's Avatar
Hey Man, call me and tell me all about VIR??? 930-5413
1addicts
