BMW M3 Forum (E90 E92)
BPM
      08-03-2012, 03:12 AM   #1
Bully
Drives: 2009 Black M3 Vert
DIY:Customized Carbon Fiber Center Console
I had my interior swapped out for the BMW Carbon package.
Then I had them install the steering wheel aftermarket
piece . But the important Center Console cover was not produced by anyone. Eventually AutoTecknic had the piece available. But it was not available for the E-93 Vert because
it did not have a hole made for the Convertible Top switch.
AutoTecknic told me that they were aware that someone had
cut the hole in their piece to install into the Vert. BMW quoted me a labor charge of 3.5 hours for cover removal and electronics swap into the Carbon Fiber cover and re installation .
I decided to DIY. I ordered a set of Trim Removal tools.
My hands are arthritic. I could not get enough leverage
and the slim set tools would bend. So, I used A Lowes
Kobalt Flat Margin Trowel with a surface height of .055 inches (1.40 mm ) --it worked very well.
Since my hands are bad and this was my first attempt, i think I should be given more time than 1/2 the BMW estimate which would be 1.75 hours. My elapsed time for total separation was 23 minutes.
The Cf piece had four mounting posts near the Controller
snap clamps that did not have any purpose in this situation.
The GREAT news is that the CF piece had mounting posts for the Convertible Switch ( which i thought I was going to have to build myself !
      08-03-2012, 03:28 AM   #2
Bully
Next I scribe the out line of the Vert switch with a hobby
knife. Then proceed to drill 44 holes with a micro hobby
bit 0.0745 inch ( 1.89 mm). The important issue here is not to drill at the scribe line but rather about 1/4 inch inside
to avoid having Carbon Fiber deflection /de-lamination problems. I then used a bigger drill .1065 inch ( 2.73 mm )
to reduce the gap between the holes for easier cutting.
      08-03-2012, 03:40 AM   #3
Bully
Next I used a Dremel cut off wheel to connect the holes.
I suggest being more careful that I was about letting the drill chuck touch the mounting posts ! Luckily no structural
harm was done here.
Those snap ring pliers ( set to external ) is a great tool for easy removal/ re- installation of the cover retention clips.
      08-03-2012, 03:59 AM   #4
Bully
BMW cheats by molding the top cover material around the
stock hole to provide a smooth fit. My fit wasn't as nice.
I used 3M Tremflex Rubber Splicing Tape ( which only sticks to itself) to surround the switch so I could more easily remove
it later if necessary . I used Gardner Bender Liquid Electrical
Tape to fill the gap between the switch and the Carbon Fiber.
Interesting to note that the CF plate is a different thickness
here so the switch is mounted slightly lower than the stock position( which might be a good thing here ).
A rotary Dremel file ( .124 inch ( 3.15 mm)) and a 0.60 ( 2.7 mm) sanding drum were used to smooth out the hole edges. However I don't think there is a way to bevel the
CF plate itself.
      08-03-2012, 04:05 AM   #5
Bully
The ash tray cover taps pry off from the hing side at the five tabs shown ( small trim tools handy here.
      08-03-2012, 04:16 AM   #6
Bully
As a bonus I ordered InDustry e-brake and DCT custom boots. Here finished with Chemical Guys conditioner .
Original Shift boot was produced August 10, 2000.
The InD was produced September 9, 2011.
The original brake boot was produced in August 2008 while its replacement is July 2011.
      08-03-2012, 04:22 AM   #7
Bully
Re-installation of the cover and components ( the remaining
1.75 BMW labor estimate) was none in in 16 minutes.
      08-03-2012, 07:40 AM   #8
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
Nice job.
      08-03-2012, 09:18 AM   #9
Bully
Thanks for the comment "The Tech"
I forgot to add a #15 Torx is needed for the Vert switch .
The hand brake boot install was 20 minutes because my weak hand had trouble holding the boot and zip tie in a good position.
About two hours of drilling/cutting/sanding and switch opening, which I did in 20 minute interval, in order to minimize mistakes.
      08-03-2012, 03:59 PM   #10
montreal red
chris
montreal red's Avatar
Drives: White Boat
wow awesome job. must have taken you quite a few hours to do that from start to finish.
Current: 2013 F10 M5 & 2016 Mini JCW
2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone)
      08-03-2012, 04:27 PM   #11
Porschefile
Porschefile's Avatar
59
Drives: E92 M3
Looks great, I plan on doing real CF interior pieces in mine eventually.
      08-23-2012, 11:06 PM   #12
kosmo69
Drives: e39
great job
      11-21-2012, 12:02 AM   #13
carbon//m3
carbon//m3's Avatar
Drives: m4 vert
Looks great
      11-21-2012, 06:09 PM   #14
BlackE93
Drives: Man
hey was just wondering what screw driver u used to remove the screws holding the vert button and the controller from the centre console?
      11-22-2012, 06:32 PM   #15
e92livin
e92livin's Avatar
Drives: M3
everything is cool expect the steering wheel, try a BMW performance one
      11-23-2012, 01:51 AM   #16
BlackE93
Drives: Man
hey how did you get the coin lid to come off? i got the big piece but cant seem to reach the 5 tabs?
      11-24-2012, 02:16 AM   #17
And1M3
And1M3's Avatar
28
Drives: 2013 M3 MR FR/Bk
Good job and great write up.
      11-24-2012, 02:38 AM   #18
OerdingE93
OerdingE93's Avatar
Drives: 2011 Mineral White E93 M3 DCT
a buddy of mine is about to install the auto technic carbon interior parts...i think it looks fabulous. great diy btw
|ESS VT1-550 510whp|MRF MID|AKRA REAR|CKS COILS|FORGESTAR|CSL TRUNK|GT4 Lip|3D-DESIGN
      11-24-2012, 06:13 AM   #19
Bully
#15 torx for the vert switch. i don't remember the size of the controller tool. it may have been the very small ( not labeled) torx from my computer tool kit.
I had to use the slim interior panel tools for the coin holder.
      11-24-2012, 08:45 AM   #20
JR M3
Member
JR M3's Avatar
11
Drives: E46 M3
great job
      11-24-2012, 02:48 PM   #21
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
Looks great
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
      11-24-2012, 03:01 PM   #22
phrozen06
phrozen06's Avatar
229
Drives: 328it, RIP M3, E46 Sold
w0w that is nicely done.
m3post
