      07-16-2012, 10:39 PM   #1
luial
Drives: 1///M, e46 M3, e30 320is ///M3
Anybody tried 285/30-19 Pilot Sport Cups on stock 10" rims?
My tire installer can't seem to do it.
Anybody tried? Is it possible?
      07-17-2012, 06:05 AM   #2
gtslacker
Drives: 1M
You might need a new installer. Correct me if I'm wrong, but I think285/30-19 is the factory size on the M3 GTS on the same wheel (just in black). I'm not sure what model of tire it uses, but I can't see that making the tire unmountable.
      07-17-2012, 02:32 PM   #3
Das Ein
Das Ein's Avatar
Drives: '16 Audi TTS, '17 500 Abarth
Would like to know this as well...
      07-24-2012, 08:08 PM   #4
mattm
mattm's Avatar
Drives:
Hoosier Tire East (Manchester CT) slaps on two 295/30-19" A6 tires in minutes without blinking. You need a new tire shop. HTE even balances them. I seem to remember mounting the 295s and 265s in about 20 minutes (two guys).
Matt Murray
I am perfectly capable of learning from my mistakes. I will surely learn a great deal today.
      07-25-2012, 07:01 PM   #5
luial
If I may add they are ZP (run flat) Sport Cups.
      07-26-2012, 12:19 AM   #6
Pete_vB
Pete_vB's Avatar
Drives: '69 GT3, GT4, 1M, 912
The recommended rim for that tire per Michelin is 10", so you're using the rim the tire was designed for. I can imagine it's a stiff sidewall and not easy to mount, but the issue it with the installer, not the rim or tire.
I'll also mention that I personally wouldn't use that tire, for two reasons:
First, it was developed for the ZR1 as a front tire. Tires that are designed to be fronts have different construction (optimized for braking, etc) than tires designed to be rears (optimized for putting power down, etc). Generic tires are usually in the middle and can be used in either place, but the ZR1 will have front tires that don't work as well when used in the rear, which can lead to funny handling.
Second, the stiffer sidewall of a run-flat doesn't really play nice when mixed with a non run-flat. Tire response will be quite a bit faster with the stiff sidewall in the rear assuming you use a non run-flat in the front. This is why the tire rack says "NOTE: Pilot Sport Cup ZP run-flat tires cannot be mixed with non-run-flat Pilot Sport Cup". You might also need to adjust camber settings as the run-flat rolls over less than the non run-flat.
Might not be too bad, but if the car handles funny especially on turn-in keep in mind that the tires could be the issue.
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
      07-31-2012, 08:22 AM   #7
mattm
mattm's Avatar
Drives:
FWIW, you can get a 315/30-19 to mount and fit cleanly (no rubbing/contact) in the back. The wheels are Forgestar 10" x 19" with a 6mm offset from the OEM (25mm). Hoosier Tire East did the mounting on them, too.
1addicts
