07-05-2012, 12:15 PM | #1 |
Rep 344
X pipe install on ramps possible?
For anyone who's installed HFC's and an x pipe, is it possible to do this just by putting the front wheels on ramps, or am I going to have to go with jack stands?
07-05-2012, 12:16 PM | #2 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
Depends on the size of the ramps.
07-05-2012, 12:35 PM | #4 |
307
Rep 13,093
07-05-2012, 02:35 PM | #5 |
Rep 2,792
It can be done (I've done it a few times) but it's a colossal bitch! I'm 6' and 180 and I barely had room to slide under there. You have to work with your hands over your head (tiring) because there isn't enough room to work above your body. The x-pipe is heavy so it's difficult to maneuver it in and out while laying on your back with so little space. If you're lowered, it's even worse. At the very least, I would put the rear of the car on stands.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R |
07-05-2012, 10:53 PM | #8 |
So Kewl Guy
49
Rep 619
Take it to a shop and pay the hundred bucks. I tried swapping out just the hfc part (I have the active pipe) and it took way to long and is very difficult to work on your back. I'm assuming you have rhino ramps and the actual lift is only a little over 6 inches. If you still try, save yourself a day and get a friend to pass you tools. Getting in and out is a bitch! Quick tip: don't tighten anything until everything is in place and save the header tightening for last and do the part attached to the catback first. Happy DIYing!!
2010 E93 M3 / MS Catless X-Pipe / AA Catback / Vorsteiner Vented Hood and Bootlid E93 Trunk / ADV1 7.1 Wheels GB / LS3 LED Lights / Harrop Supercharger
07-05-2012, 11:10 PM | #9 |
Rep 2,736
Drives: 2008 E92 ///M3 Alpine White
I've done 2 rear sections on ramps....never attempted an X-pipe though.
Just drive up the ramp, jack up the car by the diff and put it on jack stands. Should be doable...pain in the ass though.
07-06-2012, 12:07 AM | #10 |
So Kewl Guy
49
Rep 619
Isn't the rear section shorter than the xpipe? And easier?
07-06-2012, 06:00 AM | #11 |
Rep 10,614
Yes. The x-pipe is long. With just the front elevated, the two connections at the rear exhaust will be more difficult to get to. It can be done, but like others have said, it will be less comfortable and take longer. Even a couple more inches would help. Maybe you could take a jack, jack one rear side, slip a plank under the wheel, lower off the jack and then do the same on the other.
07-06-2012, 08:24 AM | #12 |
Rep 344
Well, I've got Race Ramps, so the height is actually 8". My brother is helping me out and we do have jackstands, so I think we can manage between the two of us. An extra set of hands definitely helps out with this kind of stuff.
07-06-2012, 08:27 AM | #13 | |
Rep 344
07-06-2012, 08:39 AM | #14 |
Rep 385
I think the front could be ok, but the rear connections will be a pain without being lifted. It is also more time consuming and laborious as you will have to remove o2 sensors, and maybe front felt pieces and skid plate to access the header bolts. I recentley did mine and it was a major PITA even on 6 ton snap-on jack stands because a creeper wouldn' fit. I was alone though.
07-06-2012, 10:41 AM | #15 |
Rep 10,614
I don't use a creeper when there is limited clearance. Cardboard on the floor. Front felt can stay and the very front skidplate bolts can stay. 3 ton jackstands work fine. 6 ton would be luxurious.
07-08-2012, 07:40 PM | #17 | |
So Kewl Guy
49
Rep 619
07-09-2012, 11:11 AM | #18 |
Rep 385
Agreed cardboard would have been best, but I didn't have any around and hadn't planned on getting it. I just layed on the ground and then walked around with what appeared to be a large skin rash on my left arm/shoulder for a few days. I only use 6 ton because I'm very paranoid about being crushed, I've heard horror stories of even craftsman 3 tons failing. One in particular because the lip snapped that comes in contact with the jacking point. The actual arm didn't break, but the car still slipped off as a result.
07-09-2012, 12:12 PM | #19 |
Rep 10,614
I had my share of bruised shoulders and other body parts, but have the ultimate in luxury now. Unfortunately, I did not get it installed until after my x-pipe work, though.
07-17-2012, 12:27 PM | #22 |
So Kewl Guy
49
Rep 619
hehe JK. But that is awesome! I wish I had one lol
